Siebel Order Management Infrastructure Guide > Service-Oriented Architecture > How Siebel C/OM Can Be Integrated with Other SOA ApplicationsWeb Services is the most common enabler of SOA. Siebel Business Applications support both inbound and outbound Web Services. The Siebel application can:
Outbound Integration of C/OM ServicesYou can call an external service from C/OM. Predefined integration interfaces can be implemented or hosted by an external application. Service can be provided by an external application, an integration server, a Siebel business service, or a Siebel business process (workflow). Figure 2 illustrates services integration for outbound integration. Calling an External Service from C/OMThe workflow process shown in Figure 3 provides an example of calling an external service from Siebel order management. The figure shows a workflow process that includes a subprocess called Check Inventory Levels. The subprocess includes a step called Perform Inventory Check, which involves a Web service invocation. Web Service PerformanceC/OM services such as Pricer or Eligibility are designed to work on batches of data to improve end-user response times. Any external service called by Pricer or Eligibility must support a batched interface that processes an entire set of data (such as all line items in an order) in a single invocation. Thus the overhead associated with Web Service invocation and with context establishment within the Web Service is only incurred once instead of, potentially, hundreds of times. |
| Siebel Order Management Infrastructure Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
