Siebel CTI Administration Guide > Configuring Siebel CTI > Exporting and Importing Communications Configuration DataThis topic describes how to export and import configuration data. It contains the following information:
Siebel Communications Server provides import and export mechanisms that enable administrators to move communications configuration data between the database and ASCII text files. You can use these mechanisms to:
For more information about adding custom communications drivers, see Configuring Communications Drivers and Profiles. The basic options for exporting and importing are as follows:
For more information about the DEF file format, see Communications DEF Files. NOTE: Using the Export Configuration and Import Configuration features, you can transfer all types of communications configuration data from one configuration to another except data for agents (and ACD queues) and telesets (and extensions). |
| Siebel CTI Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
