Siebel Installation Guide for UNIX > Requirements for Installing and Configuring Siebel Business Applications > Requirements for Installing and Configuring Siebel Enterprise Server Components > Requirements for Installing and Configuring the Siebel ServerThis topic is part of Requirements for Installing and Configuring Siebel Enterprise Server Components. Review this topic before installing and configuring the Siebel Server. See also General Requirements for Installing and Configuring Siebel Enterprise Server Components.
About Clustering the Siebel Gateway Name Server and Siebel ServerIf you will operate certain servers as part of a cluster, then it is strongly recommended that you install and configure the Siebel Gateway Name Server and the Siebel Server on separate resource groups. For information about clustering, see Siebel Deployment Planning Guide. Language and Locale RequirementsMake sure that you have the appropriate locales installed on the computers on which you intend to deploy Siebel Server. Siebel log and configuration files use UTF-8 with Byte Order Mark as the default encoding. If these files contain any non-ASCII characters, then proper viewing and editing requires a UTF-8 locale. For more information about supported locales, see the Certifications tab on My Oracle Support. The locale can affect how dates and times are displayed. For more information, see Siebel Global Deployment Guide. NOTE: Make sure that the locale that you are using matches the locale set at your operating system level. For details, see Specifying the Locale for Your UNIX Operating System. Guidelines for Installing Multiple Language Packs on the Siebel ServerIf you will install multiple language versions of Siebel Business Applications on your Siebel Servers, then review the following configuration guidelines:
Search ServerA Siebel Server computer can be configured to execute searching using a locally installed search server or can be pointed to a remote search server to handle search execution tasks. NOTE: For search-related installation guidelines and requirements, see Siebel Search Administration Guide. Database RequirementsMake sure that your database administrator has installed the RDBMS that your site will use and created the Siebel database instance and that you meet all of the database connectivity requirements. For more information, see Configuring the RDBMS including Configuring Siebel Server Connectivity to the Siebel Database. See also Planning RDBMS Installation and Configuration. The RDBMS that you are using must support the same languages and code pages that you install on the Siebel Servers. For Siebel CRM language support, Unicode support, and legacy code page support, see 1513102.1 (Article ID) on My Oracle Support. NOTE: After performing a migration installation of the current release, then you must run Incremental Repository Manager. For more information, see About Database Updates for the Current Release. Siebel Repository Files RequirementMake sure that you have the Siebel Repository files (SRF files) that are correct for your installed Siebel CRM version and the version of your Siebel database, such as Siebel CRM version 15.0. For the current release, updated SRF files are provided with new installations and migration installations of Siebel CRM. Third-Party Software RequirementsMake sure that you have already installed the appropriate version of all of the third-party software products required. Otherwise, the Required Software Components prompt appears. For more information, see the Certifications tab on My Oracle Support. Temporary Disk SpaceReview the issues described in Managing Temporary Disk Space Required by Siebel Installers and Wizards. For example, make sure that you have adequate disk space, and make sure that the login ID running the installer has write permissions to this directory. |
| Siebel Installation Guide for UNIX | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
