| Siebel CRM System Administration Guide Siebel Innovation Pack 2015, Rev. A E24823-01 |
![]() Previous |
![]() Next |
View PDF |
Table 1-3 lists the changes in this revision of the documentation to support this release of the software.
Note: Siebel Innovation Pack 2014 is a continuation of the Siebel 8.1/8.2 release. |
Table 1-3 What's New in Siebel System Administration Guide, Siebel Innovation Pack 2014
| Topic | Description |
"About the Siebel Management Pack" |
Modified topic. Updated information about the Siebel Management Pack. |
Modified topics. Updated information about Siebel Open UI. Added information about the Session Keepalive Timeout parameter, which is a hidden parameter. |
"Using the Browser Health Check" |
Deleted topic. The browser health check formerly provided for high interactivity clients is obsolete. |
"Administering the Siebel Management Agent System Service" "Administering the Siebel Management Server System Service" Appendix E, "Siebel Management Framework API" |
Removed topics or modified topics. Siebel Management Server and Siebel Management Agent, which were formerly used with Siebel Application Deployment Manager, are no longer provided or supported for the current release. The server components in the Application Deployment Manager (ADM) component group no longer apply. For more information, see the statement of direction on My Oracle Support, 1640801.1 (Article ID). For more information about Siebel Application Deployment Manager, see also on Siebel Bookshelf. |
"Siebel Server Management Commands" |
Modified topic. On Linux, the Siebel Gateway Name Server backup file that you create with the |
"Siebel Server Component Groups" |
Modified topics.
MobileSync contains the Mobile Data Extraction component (alias MobileDbXtract), which is new. These four components were moved from the Siebel Remote component group: Database Extract, Parallel Database Extract, Transaction Processor, and Transaction Router. The BatchSync component was moved from the Handheld Synchronization component group.
"Siebel Enterprise, Server, and Component Parameters" (see "Generic Parameters") |
Modified topics. Updated the information about the parameter Maximum depth of the query (alias MaxDepthOfTheQuery). |
"Parameter Descriptions of the eapps.cfg File" |
Modified topic. Updated the description of the SessionTracking parameter to note that Siebel Open UI requires the use of cookies and does not support cookieless mode. For more information about this parameter, see Siebel Security Guide on Siebel Bookshelf. |
