| Siebel CRM System Administration Guide Siebel Innovation Pack 2015, Rev. A E24823-01 |
![]() Previous |
![]() Next |
View PDF |
After the Siebel Server Manager has been started, you can execute administrative tasks by using the commands described in this topic.
These commands can also be written into an ASCII text file, exactly as you execute them through the Siebel Server Manager, and used as a batch input file by running srvrmgr by using the /i or -i flag. Running the batch input file is especially useful in the administration of similar Siebel Server component definitions for multiple Siebel Servers.
Note: You must have the Siebel Administrator responsibility to connect with the srvrmgr command-line tool. |
The Siebel Server Manager commands are divided into the following categories:
Help. For more information, see "Help Commands".
Environment. For more information, see "Siebel Server Manager Environment Commands".
List. For more information, see "List Commands" and "List Command Configuration".
Siebel Server management. For more information, see "Siebel Server Management Commands".
Component group definition. For more information, see "Component Group Definition Commands".
Component definition. For more information, see "Component Definition Commands" and "Reconfiguring Component Definition Commands".
Component management. For more information, see "Component Management Commands".
Task management. For more information, see "Task Management Commands".
Parameter management. For more information, see "Parameter Management Commands".
Named subsystem management. For more information, see "Named Subsystem Management Commands".
System alert notification. For more information, see "System Alert Notification Commands".
List definition. For more information, see "List Definition Commands" and "List Parameter Override Commands".
Event logging. For more information, see "Event Logging Commands".
Preferences. For more information, see "Server Manager Command-Line Preferences".
This topic lists the command-line syntax and usage for Siebel Server Manager commands.
Component names and parameter names used in the command-line interface differ from the Siebel Server Manager GUI. To get the actual component and parameter names used in the command-line interface, use the list commands. For information about using the list commands, see "List Commands".
For user-defined values such as siebel_server_name, component_alias_name, and parameter_alias_name, you must enclose these values in quotes if the value:
Contains spaces
Is a keyword such as server or component that you do not want to be parsed
For example, you must enclose the Siebel Server name in double quotes for the following command, because the Siebel Server name contains a space:
start task for component EIM server "North America" with Config=default.ifb
Note: If a srvrmgr command contains nested quotes, that is, quotes contained within quotes, then precede the inner quotes by the backslash escape character (\). |
Use the Help command to retrieve a list of commands or obtain help on a specific command.
To obtain help
Enter the following command:
help
For a specific command, enter a command like the following:
help command
Use environment commands to set the Siebel Server Manager environment variables, which control the current Siebel Server Manager session.
To set the current working Siebel Server
This command works only if you did not specify a Siebel Server when executing the srvrmgr program using the -s flag.
To unset (clear) the current working Siebel Server
To show the environment variables
show
To show an individual environment variable
show variable_name
To spool output to a file
To stop spooling to a file
spool off
To read commands from a file
To refresh the Siebel Enterprise Server connections
refresh enterprise
The refresh enterprise command closes all of the connections to the existing Siebel Servers and creates new connections to these servers.
To remove header and footer information from srvrmgr command-line output
set header false
and
set footer false
Removing the header and footer information is useful if you are trying to parse the output of srvrmgr commands.
To add header and footer information to the srvrmgr command-line output
To exit the srvrmgr program
exit
or
quit
To save any configuration changes prior to exiting, use a backup command listed in "Siebel Server Management Commands".
Use the list command to display current data only. This command does not change any data.
To list available Siebel Servers
For a component, enter the following command:
list servers for component component_alias_name
For a component group, enter the following command:
list servers for component group component_group_alias_name
To list component groups
For a particular Siebel Server, enter the following command:
list component groups for server siebel_server_name
If you are connected to the Siebel Server, then the list commands list only component groups from shared memory. Otherwise, it lists the component groups assigned to that Siebel Server from the Siebel Gateway Name Server. See also the describe command in "Component Group Definition Commands".
To list current component group status
For all instances of the component group, enter the following command:
list component group component_group_alias_name
list component groupcomponent_group_alias_namefor serversiebel_server_name
To list current component status
For all components, enter the following command:
list component
For all instances of the component, enter the following command:
list component component_alias_name
list component for server siebel_server_name
For a particular task, enter the following command:
list component for task task_number
To list values for a particular task, you first must set the current working Siebel Server by using the set server command. For information about this command, see "Siebel Server Manager Environment Commands".
To list subsystems
To list named subsystems
For a particular subsystem, enter the following command:
list named subsystem for subsystem subsystem_alias_name
list named subsystem for server siebel_server_name
To list the status of current tasks
list tasks for server siebel_server_name
For a particular component, enter the following command:
list tasks for component component_alias_name
For a particular component group, enter the following command:
list tasks for component group component_group_alias_name
list task task_number
Note: The number of tasks returned is determined by the Maximum Tasks parameter for that component. For more information about the Maximum Tasks parameter, see "Siebel Enterprise, Server, and Component Parameters". |
To list tasks for session mode components
list sessions for server siebel_server_name
list sessions for comp component_alias_name
For a particular Application Object Manager login, enter the following command:
list sessions for login object_manager_login
For a list of hung tasks, enter the following command:
list hung sessions for serversiebel_server_name[or] compcomponent_alias_name[or] loginobject_manager_login
For a list of active tasks, enter the following command:
list active sessions for serversiebel_server_name[or] compcomponent_alias_name[or] loginobject_manager_login
To list current parameter values
For all Siebel Servers, enter the following command:
list parameters
list parameters for server siebel_server_name
For a particular component on all Siebel Servers, enter the following command:
list parameters for component component_alias_name
For a particular component on a particular Siebel Server, enter the following command:
list parameters for componentcomponent_alias_nameserversiebel_server_name
list parameters for tasktask_numberserversiebel_server_name
To list current advanced parameter values
Use the previously documented commands for listing parameters, but preface advanced before parameters. For example:
list advanced parameters for server siebel_server_name
To list current state values
list state values for server siebel_server_name
list state values for task task_number
To list current statistic values
list statistics for server siebel_server_name
list statistics for component component_alias_name
list statistics for task task_number
The following commands modify or configure the output for the list commands described in "List Commands".
To modify the output of an individual list command
To display specific columns, enter the following command:
list list_object show column_1, column_2, ..., column_n
For example:
list components show SV_NAME, CC_ALIAS
To display specific columns with a for clause, enter the following command:
list list_object for for_object show column_1, column_2, ..., column_n
For example:
list components for SRVR_1 show CC_ALIAS
To list available columns for a list command
To configure the output of the list command
To display only specific columns, enter the following command:
configure list list_object show column_1, column_2, ..., column_n
This command changes future list list_object commands to display only those columns defined.
Note: Once you configure a specific list command for a given srvrmgr session, it cannot be configured again in that session. A new session must be started to view other columns for that list command. |
Use the server group management commands to manage the assignment of Siebel Servers with server groups. A Siebel Server can only be assigned to one server group at a time. A server group can contain many Siebel Servers.
Once you assign Siebel Servers to a server group, you can specify the server group name as a parameter for the /z or -z flag when starting the srvrmgr program. Specifying the server group connects the srvrmgr program to all of the Siebel Servers assigned to the specified server group.
For example, on a Windows server, enter a command like the following:
srvrmgr /g gateway1 /e enterprise1 /z server_group_name /u sadmin /p pwd
On a UNIX server, enter a command like the following:
srvrmgr -g gateway1 -e enterprise1 -z server_group_name -u sadmin -p pwd
For more information about starting the srvrmgr program, see "Starting the Siebel Server Manager Command-Line Interface".
To assign a Siebel Server to a server group
change attribute groupname=server_group_namefor serversiebel_server_name
To unassign a Siebel Server from a server group
change attribute groupname=" " for server siebel_server_name
Note: Make sure to include a space between the quotation marks. |
Use the Siebel Server management commands to start or stop a Siebel Server or to back up the Siebel Gateway Name Server.
To start a Siebel Server
To shut down a Siebel Server
To back up Siebel Gateway Name Server information
Enter one of the following commands:
backup nameserver [file_name] backup namesrvr [file_name]
If a file name is not specified, then the backup file name includes the date and time, using the format siebns.dat_yyyymmdd_hhmmss. The location of the backup file varies by operating system, as follows:
On Windows, the backup file is saved into the admin directory on the Siebel Gateway Name Server installation (GTWYSRVR_ROOT\admin). This directory is also the directory that contains the siebns.dat file that you backed up.
On AIX, Linux, and Oracle Solaris, the backup file is saved into the admin directory on the Siebel Gateway Name Server installation (GTWYSRVR_ROOT/admin). This directory is not the same location as the directory that contains the siebns.dat file that you backed up. (The siebns.dat file is located in GTWYSRVR_ROOT/sys.)
On HP-UX, the backup file is saved into the sys directory on the Siebel Gateway Name Server installation (GTWYSRVR_ROOT/sys). This directory is also the directory that contains the siebns.dat file that you backed up.
Use these commands to create, delete, assign, remove, enable, and disable component groups.
To create a component group
create component groupcomponent_group_alias_namefull name "descriptive_name" description "description_of_component_group"
To assign a component group to a Siebel Server
assign component groupcomponent_group_alias_nameto serversiebel_server_name
To unassign a component group from a Siebel Server
unassign component groupcomponent_group_alias_namefrom serversiebel_server_name
Note: Unassigning a component group from a Siebel Server results in a loss of component group customization, for example, parameter settings. Before unassigning a component group, review "About Assigned and Unassigned Component Groups". |
To enable a component group for the Siebel Enterprise Server
enable component group component_group_alias_name
Stop and restart the system service to make the changes take effect.
For more information about how to stop or start the Siebel Server system service, see "Administering the Siebel Server System Service".
This procedure works only if you did not run Siebel Server Manager command-line interface using the /s or -s flag.
Note: Before you enable a component group for the Siebel Enterprise Server, at least one component in the group must be active. |
To enable a component group on a Siebel Server
enable component groupcomponent_group_alias_nameto serversiebel_server_name
Note: Use this command when enabling a component that was previously disabled on a particular server. Newly created component groups are enabled by default. |
To disable a component group for the Siebel Enterprise Server
disable component group component_group_alias_name
To disable a component group for a Siebel Server
disable component groupcomponent_group_alias_namefor serversiebel_server_name
To list component groups from the Siebel Gateway Name Server
describe component group
The describe command lists the component groups from the Siebel Gateway Name Server.
To remove a component group from a Siebel Server
remove component groupcomponent_group_alias_namefrom serversiebel_server_name
delete component group component_group_alias_name
In order for you to delete a component group, the component group cannot contain any server components or component definitions.
Use the component definition commands to create, activate, or delete defined components. Component definitions are contained in component groups, both of which are defined at the Siebel Enterprise Server level. To use a new component, make sure that the component definition is activated and the component group containing the new component is assigned to the appropriate server. For component group commands, see "Component Group Definition Commands".
Note: When working with component definition commands, start and run the srvrmgr program for the enterprise. That is, do not start srvrmgr with the /s or -s flag and do not run the commandset server. |
To create a new component
create component definitioncomponent_alias_namefor component typeexisting_component_type_alias_namecomponent groupexisting_component_group_alias_namerun moderun_modefull name "component_full_name" description "description_of_component" with parameterparameter_alias_name=valuefixparamfixed_parameter_alias_name=fixed_value
The run mode options are:
Batch
Interactive
Background
The component alias must:
Be unique across the enterprise
Contain no more than 30 characters
You must enclose in quotes any keywords that you use in the component description, such as the keywords for or component. The alias or short name is required for the component group that you specify for this component definition. For a list of existing component groups and their corresponding aliases, see Table A-2. For more information about component types, see "About Server Component Types".
After running the create command, use the activate component definition command to enable the component definition at the enterprise, component definition level, and to enable and assign the component to the component group that you created. This action only occurs if the component definition is in the creating state. If the component definition is not in the creating state, then the command only enables the component definition at the enterprise level.
To activate a component definition
After defining the component, activate the defined component by entering:
activate component definition component_alias_name
Note: If you receive an error when attempting to activate a new component definition, then make sure that you did not start the srvrmgr command-line interface program by using the /s or -s flag, which targets only a specific server. |
To deactivate a component definition
To delete a component definition
To copy a Siebel Server component definition
To reconfigure component definitions, you must start the component reconfiguration, make the necessary configurations (for parameter configuration, see "Parameter Management Commands"), and then commit the reconfiguration. See the following procedures for these commands.
Caution: Review the background information about component definition reconfiguration before performing this task. For more information, see "Reconfiguring Siebel Server Component Definitions". |
To start a component definition reconfiguration
reconfig compdef component_alias_name
To commit a component definition reconfiguration
commit reconfig compdef component_alias_name
To cancel a component definition reconfiguration
cancel reconfig compdef component_alias_name
Use component management commands to start or shut down Siebel Server components.
The startup systemcomps, shutdown systemcomps, startup systemauxcomps, shutdown systemauxcomps, startup nonsystemcomps, and shutdown nonsystemcomps commands manage the components in the System Management (alias System) component group or the Auxiliary System Management (alias SystemAux) component group, as follows:
The components in the System component group include Server Manager, Server Request Broker, and Siebel Connection Broker.
The components in the SystemAux component group include File System Manager, Server Request Processor, Server Tables Cleanup, and Siebel Administrator Notification Component.
To start a Siebel Server component
To shut down a Siebel Server component
To configure a Siebel Server component to start automatically
To start a Siebel Server component manually
To start Siebel Server components for the System component group
To shut down Siebel Server components for the System component group
To start Siebel Server components for the SystemAux component group
To shut down Siebel Server components for the SystemAux component group
To start Siebel Server components for all components except those in the System or SystemAux component group
To shut down Siebel Server components for all components except those in the System or SystemAux component group
Use task management commands to manage tasks for components running in batch or background mode.
You can start a new process by using the start task command or the run task command. Use the start task command if you plan to start multiple processes and use the run task command if you want to make sure that a process has run to completion.
The following are the two task management commands:
Start task. The start task command starts a new process and allows you to execute a new command immediately. You are not notified of the task status, nor are you alerted if the task fails to perform. Instead, use the list task command to check the status of processes that were started by using the start task command.
Run task. The run task command starts a new process that runs to completion (or exits with an error). You cannot execute a new command until the process has run to completion. The task status is displayed as the process is running.
To use multiple task parameters in a task command, list the parameters in a comma-separated list. The following example shows how to start a new process using various values for a given parameter:
start {task | server} for component component_alias_name with parameter_alias_name=value1, value2, value3
To start a new task in batch mode
start task for componentcomponent_alias_nameserversiebel_server_namewithparameter_alias_name1=value1,parameter_alias_name2=value2
This command starts a new task in batch mode and returns to the Siebel Server Manager immediately.
To start a new task in background mode
start server for componentcomponent_alias_nameserversiebel_server_namewithparameter_alias_name1=value1,parameter_alias_name2=value2
This command starts a new task in background mode and returns to the Siebel Server Manager immediately.
To run a new task in batch mode
run task for componentcomponent_alias_nameserversiebel_server_namewithparameter_alias_name1=value1,parameter_alias_name2=value2
This command runs a new task in batch mode to completion before returning to the Siebel Server Manager.
To pause a running task
pause tasktask_IDfor serversiebel_server_name
Note: Only tasks from certain component types can be paused. For a list of these component types, see Table 7-2. |
To resume a paused task
To stop a running task
To terminate a running task using the kill command
kill tasktask_IDfor serversiebel_server_name
The kill task command signals the Siebel Server to use operating system control to terminate the task. This command replicates the GUI procedure of clicking Menu and then Stop Task three times in succession on a running task.
Use the parameter management commands to change the values of a parameter.
To change an enterprise parameter
change ent paramparameter_alias_name1=value1,parameter_alias_name2=value2
To change a component definition parameter
change parameterparameter_alias_name1=value1,parameter_alias_name2=value2for compdefcomponent_definition_name
To change a component type parameter
change parameterparameter_alias_name1=value1,parameter_alias_name2=value2for comptypecomponent_type_namefor serversiebel_server_name
To change a Siebel Server parameter
change parameterparameter_alias_name1=value1,parameter_alias_name2=value2for serversiebel_server_name
To change a component parameter
change parameterparameter_alias_name1=value1,parameter_alias_name2=value2for componentcomponent_alias_nameserversiebel_server_name
Note: If you started srvrmgr with the /s or -s flag, then you do not have to includeserver siebel_server_name for this command. |
To change a task parameter
change parameterparameter_alias_name1=value1,parameter_alias_name2=value2for tasktask_number
Note: After a server, component, or named subsystem parameter is modified, it ignores future parameter changes at higher levels. That is, future parameter changes at higher levels in the hierarchy do not cascade down to lower levels. Use the following commands to delete overrides and reinstate this functionality. |
To delete an enterprise parameter override
To delete a Siebel Server parameter override
delete parameter override for serversiebel_server_nameparam "parameter_alias_name"
To delete a named subsystem parameter override
delete parameter override for named subsystemnamed_subsystem_alias_nameparam "parameter_alias_name"
To delete a server component parameter override
delete parameter override for compcomponent_alias_nameserversiebel_server_nameparam "parameter_alias_name"
To delete a server component definition parameter override
Use named subsystem management commands to create, delete, and modify named subsystems. For more information about named subsystems, see "About Named Subsystem Parameters" and "Application Object Manager Named Subsystem Parameters".
To create a new named subsystem
create named subsystemnamed_subsystem_alias_namefor subsystemsubsystem_alias_namewithparameter_alias_name1=value1,parameter_alias_name2=value2
To list all named subsystem parameters
For a particular named subsystem, enter the following command:
list parameters for named subsystem named_subsystem_alias_name
To list a particular named subsystem parameter
list parameterparameter_alias_namefor named subsystemnamed_subsystem_alias_name
To modify one or more named subsystem parameters
Use the following commands to configure system alert notification for server components. For more information about system alert notification, see "About System Alert Notification".
To troubleshoot any problems with system alert notification, see "Troubleshooting System Alert Notification".
To set the administrator email address
change param AdminEmailAddress=Admin_Email_Address for named subsystem AdminEmailAlert
where Admin_Email_Address is the email address that receives the alert notification email.
To set the SMTP host and port number used for email notifications
change param SMTPServer=SMTP_Server for named subsystem AdminEmailAlert
where SMTP_Server is the email server that routes the alert notification email.
To set the From email address
change param FromAddress=Server_Email_Address for named subsystem AdminEmailAlert
where Server_Email_Address is the email address that sends the alert notification email.
To test the system alert notification
start task for comp AdminNotify server Siebel_Server_Name
where Siebel_Server_Name is the name of the Siebel Server that hosts the AdminNotify server component.
Use list definition commands to list definitions for components, parameters, state values, and statistics.
To list component definitions
list component definitions for component component_alias_name
list component definitions for task task_number
Use list parameter override commands to list parameter overrides for an enterprise, a Siebel Server, a component, a component definition, or a named subsystem.
For more information about parameter overrides, see "About the Siebel Enterprise Server". See also "Deleting System Parameter Overrides".
To list parameters for the enterprise
list entparam overrides
To list parameters for a Siebel Server
list param overrides for server siebel_server_name
To list parameters for a component
list param overrides for compcomponent_alias_nameserversiebel_server_name
To list parameters for a component definition
list param overrides for compdef component_definition_alias_name
To list parameters for a named subsystem
list param overrides for named subsystem named_subsystem_alias_name
To list parameters for component definitions
list param overrides for component component_alias_name
Use the event logging commands to list event types for components and to change the values for event log levels. For more information about event logging, see Siebel System Monitoring and Diagnostics Guide.
To list event types
list evtloglvl for component component_alias_name
To change the event log level for a component
change evtloglvlevent_alias_name=levelfor componentcomponent_alias_name
To change the event log level for a component on a Siebel Server
change evtloglvlevent_alias_name=levelfor serversiebel_server_namecomponentcomponent_alias_name
To change the event log level for a Siebel Server
You can create aliases for commands and configure list commands to return specific columns. These can be saved in a preferences file which is available to load the next time that you open a Siebel Server manager session. The preferences file is stored in the same directory as the Server Manager program. For the location of the Server Manager program, see "Starting the Siebel Server Manager Command-Line Interface".
To create an alias for a command
alias alias command_name
For example, the following command creates an alias lc for the command list components:
srvrmgr> alias lc list components
To delete an alias for a command
To list the columns returned for a list command
To configure a list command to show specific columns
configurelist_commandshowcolumn1,column2,column3...
For example, the following command configures the list components command to return the component name column only.
srvrmgr> configure list components show CC_NAME
To configure a list command to show all columns
configure list_command show all
For example, the following command configures the list components command to return all columns.
srvrmgr> configure list components show all
Note: The columns that are returned might not contain useful data. However, by using subsequent commands, you can specify which columns to display. |
To save preferences
Preferences are saved in the same directory as the Server Manager program.
To load preferences
