| Siebel CRM System Administration Guide Siebel Innovation Pack 2015, Rev. A E24823-01 |
![]() Previous |
![]() Next |
View PDF |
At startup, Application Object Manager components accept several parameters that determine their behavior. Parameters that affect the operation of Application Object Managers can be modified in:
Component parameters for the Application Object Manager using the Siebel Server Manager. For more information about this task, see "Configuring Siebel Server Component Parameters".
Named subsystem parameters using Siebel Server Manager. For more information about this task, see "Configuring Siebel Enterprise Server Named Subsystem Parameters".
This topic provides a partial list of component-specific and generic parameters you set for the Application Object Manager. You configure Application Object Manager parameters in the same manner as those for any server component. To configure Application Object Manager parameters using the Server Manager GUI, see "Configuring Siebel Server Component Parameters". To configure Application Object Manager parameters using the Server Manager command-line interface, see "Parameter Management Commands".
See the following parameters:
Compression Type (alias Compress)
Encryption Type (alias Crypt)
Error Flags (alias ErrorFlags)
Language Code (alias Lang)
Log Print Timestamp (alias LogTimestamp)
Maximum MT Servers (alias MaxMTServers)
Maximum Tasks (alias MaxTasks)
Minimum MT Servers (alias MinMTServers)
Multi-Threaded (alias Threaded)
Number of lines after which to flush the log file (alias LogFlushFreq)
Password (alias Password)
Trace Flags (alias TraceFlags)
User Name (alias Username)
Use Shared Log File (alias LogUseSharedFile)
For a description of each parameter, see "Siebel Enterprise, Server, and Component Parameters".
For information about locale-specific Application Object Manager parameters, including information about regional standards for currency, time, date, and so on, see Siebel Global Deployment Guide.
The Application Object Manager can maintain several different values for a particular parameter by using named subsystems. For more information about named subsystems and named subsystem parameters, see "About Named Subsystem Parameters". For information about configuring Application Object Manager named subsystem parameters, see "Configuring Siebel Enterprise Server Named Subsystem Parameters".
Table 10-1 provides a partial list of named subsystems used by Application Object Managers.
Table 10-1 Named Subsystems Used by Application Object Managers
| Named Subsystem | Alias | Type | Description |
DataMart Datasource |
DataMart |
InfraDatasources |
Datamart data source used by Application Object Manager components |
Gateway Datasource |
GatewayDataSrc |
InfraDatasources |
Gateway data source used by Application Object Manager components |
Object Manager Cache |
ObjMgrCache |
InfraObjMgrCache |
Cache parameters for Application Object Manager components |
Server Datasource |
ServerDataSrc |
InfraDatasources |
Server data source used by Application Object Manager components |
LDAP Security Adapter |
LDAPSecAdpt |
InfraSecAdpt_LDAP |
LDAP security adapter used for Application Object Manager authentication with directory servers |
Table 10-2 provides a partial list of named subsystem parameters.
Table 10-2 Named Subsystem Parameters
| Parameter Alias | Named Subsystem | Data Type | Description |
DSConnectString |
GatewayDataSrc |
String |
Specifies the host name of the Siebel Gateway Name Server. The value $(GatewayAddress) for the parameter ConnectString of the GatewayDataSrc section of the Application Object Manager's configuration file is replaced at run time with the value for the named subsystem parameter DSConnectString. An incorrect setting for DSConnectString results in server administration being inaccessible from the Siebel Web Client. |
DSConnectString |
ServerDataSrc |
String |
Specifies the database connection information. On Oracle Database (native), this information is the service name from tnsnames.ora. On Microsoft SQL Server and IBM DB2, this information is the ODBC Datasource Name. |
DSDockedFlg |
ServerDataSrc |
Boolean |
When you create a new named subsystem for an Application Object Manager, you must set this parameter to True. |
DSFileSystem |
ServerDataSrc |
String |
Set this parameter to *FSM* to allow the use of the File System Manager server component for standard Siebel Web Clients. |
DSMaxCursorSize |
ServerDataSrc, GatewayDataSr, or DataMart |
Integer |
Sets the total number of rows that can be returned in a result set. The parameter MaxCursorSize is set for the Application Object Manager component by using the named subsystem parameter DSMaxCursorSize. (The applicable subsystem corresponds to the component parameter OM - Data Source.) This parameter is valid only with IBM DB2 for OS/390 and z/OS. For more information, see the description of the MaxCursorSize parameter in "Parameters for Individual Data Source Sections". |
DSPreFetchSize |
Integer |
Sets the number of rows that the Siebel application reads initially as part of a query execution. The parameter PreFetchSize is set for the Application Object Manager component by using the named subsystem parameter DSPreFetchSize. (The applicable subsystem corresponds to the component parameter OM - Data Source.) This parameter is valid only with IBM DB2 for OS/390 and z/OS. For more information, see the description of the PreFetchSize parameter in "Parameters for Individual Data Source Sections". |
DSEnterpriseServer |
ServerDataSrc, GatewayDataSr |
String |
Specifies the name of the Siebel Enterprise Server used by various named subsystems. The value in the Application Object Manager is replaced at run time with the value set for the named subsystem. |
DSRequestServer |
ServerDataSrc |
String |
Specifies where asynchronous calls are redirected, for example when using Interactive Assignment. Set this value to the logical name of the Siebel Server, not the computer name. The default value is null. |
DSTableOwner |
All named subsystems of type InfraDatasources |
String |
Specifies the table owner for this data source. Application Object Manager server components, such as Call Center Object Manager, read the value of this parameter. Siebel Server infrastructure and system management components, such as Server Request Broker (SRBroker), read the value of the TableOwner enterprise parameter. |
DSDisableExecuteRetry |
ServerDataSrc |
Boolean |
When set to True, this parameter prevents the Application Object Manager from resending a query to the database layer if an error occurs such as a network error or session kill. |
To configure named subsystems using the Siebel Server Manager command-line interface, see "Named Subsystem Management Commands".
