| Siebel CRM System Administration Guide Siebel Innovation Pack 2015, Rev. A E24823-01 |
![]() Previous |
![]() Next |
View PDF |
You can monitor Application Object Managers at the following levels:
The server level using Siebel Server
The component level using Application Object Manager components
The task level using Application Object Manager tasks
At each of these levels, you can do the following:
Use the server administration views to monitor the following:
State values
Statistics
Log files
Use the Siebel Server Component Parameters view to set the component-specific parameters for the Application Object Manager.
Start, stop, pause, or resume any Application Object Manager tasks.
For more information about Application Object Manager state values, statistics, and log files, and about monitoring an Application Object Manager server component, see Siebel System Monitoring and Diagnostics Guide.
At the component event level, you can enable SQL tracing to view the SQL that is generated for the specified Application Object Manager. You can enable SQL spooling on the Application Object Manager task by setting the Object Manager SQL Log event parameter to 4 at the component event level. For more information about event logging, see "Event Logging Commands". See also Siebel System Monitoring and Diagnostics Guide.
