Siebel CRM Integration to Oracle FLEXCUBE Universal Banking Implementation Guide > Installing and Configuring the Integration > Process of Implementing the Integration in an Oracle Data Integrator Production Environment > Importing Scenarios to the Production EnvironmentThis topic describes how to export the Integration scenarios from the Oracle Data Integrator development environment and import the scenarios into the production environment. It also describes how to modify scenario variables in the production environment. For detailed information on importing and exporting Oracle Data Integrator objects, see Oracle® Fusion Middleware Developer's Guide for Oracle Data Integrator. This task is a step in Process of Implementing the Integration in an Oracle Data Integrator Production Environment. When Oracle Data Integrator scenarios are generated in a development environment, the default values of the global and project variables used in the scenarios relate to the development environment. When Oracle Data Integrator is then deployed in the production environment, these default values might not apply. To ensure that the values of the variables used in scenarios are appropriate when scenarios are transferred to the production environment, use one of the following methods:
Transferring Scenarios Between RepositoriesThe following procedure describes how to export scenarios from the Oracle Data Integrator development environment and import the scenarios into the production environment. To transfer scenarios between repositories
Modifying Scenario Variables in the Production EnvironmentYou must update the variables in the scenarios that are imported to the production environment by replacing any variable value that contains information specific to the development environment with the corresponding values for the production environment. The following procedure describes this task. To modify scenario variables in the production environment
| Siebel CRM Integration to Oracle FLEXCUBE Universal Banking Implementation Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
