Siebel CRM Integration to Oracle FLEXCUBE Universal Banking Implementation Guide > Performing Batch Data Loading and Synchronization > About Batch Data Loading and SynchronizationOracle Data Integrator is used to perform the initial and on-going batch synchronization of data between Oracle FLEXCUBE Universal Banking and Siebel CRM. Oracle Data Integrator synchronizes data for the following entities: During the Oracle Data Integrator configuration process, you generate scenarios for the Oracle Data Integrator packages that are provided with the Integration, as described in Generating Scenarios for Integration Packages. NOTE: In this guide, the term, the Integration, refers to Siebel CRM Integration to Oracle FLEXCUBE Universal Banking. As shown in Figure 3, the scenarios perform the following steps:
Figure 3 illustrates the batch data synchronization process. For each entity that is batch loaded, Table 4 lists the Oracle FLEXCUBE Universal Banking staging table that stores the data that is transferred to Siebel CRM. Table 4 also lists the corresponding Siebel EIM table that the staging table data is loaded into. Table 5 lists each of the packages used by the Integration and the task performed by each package.
The way in which data in the staging tables is mapped to data in the Siebel EIM tables during the batch integration process is described in Data Mappings to Siebel EIM Tables. |
| Siebel CRM Integration to Oracle FLEXCUBE Universal Banking Implementation Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
