Using Siebel Tools > Customizing Objects > Overview of Customizing ObjectsThe work that you can do with an object varies depending on whether or not the project that this object references does the following:
Table 10 summarizes the work that you must do for various tasks, such as creating an object that references a project that allows object locking. For more information, see the following information:
Using Siebel Tools | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
