Siebel VB Language Reference > Methods Reference for Siebel VB > Mathematical Methods > Get Rounded Integer MethodThe Get Rounded Integer method removes the fractional part of a number. It returns the integer part of a number. For positive and negative numbers, it removes the fractional part of the expression and returns the integer part only. For example: For more information, see This method uses the same arguments as the Get Absolute Value method. For more information, see Get Absolute Value Method.. FormatThis method uses the same arguments as the Get Absolute Value method. For more information, see Get Absolute Value Method. How The Get Integer Method Handles Variant TypesThe data type of the return value matches the data type of the numeric expression. This includes variant expressions unless the numeric expression is one of the following:
For more information, see Variants. ExampleThe following example returns the integer portion of a number that the user enters: Sub Button_Click |
| Siebel VB Language Reference | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
