Siebel VB Language Reference > Methods Reference for Siebel VB > Mathematical Methods > Get Logarithm MethodThe Get Logarithm method returns the natural logarithm of a number. For information on how this method handles the data type, see How Some Math Methods Handle the Data Type. FormatThis method uses the same arguments as the Get Absolute Value method. For more information, see Get Absolute Value Method. ExampleThe following example uses the Get Logarithm method to determine which of the following numbers is larger:
You cannot use the exponent (^) operator for very large numbers, such as 999^1000. |
| Siebel VB Language Reference | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
