Siebel VB Language Reference > Methods Reference for Siebel VB > Code Control Statements > Do Loop StatementThe Do Loop statement is a control structure that repeats a series of code lines as long as an expression is TRUE. It does not return a value. If an Exit Do statement runs, then control flows to the statement that resides immediately after the Loop statement. If you use an Exit Do statement in a nested loop, then it moves control out of the immediate loop. Format ADo [{ While|Until } condition] Format BDo ArgumentsThe following table describes the arguments that you can use with this method.
ExampleFor examples, see Get File Names Method, Erase Array Method, and Get Error Code Method. |
| Siebel VB Language Reference | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
