Environmental
Specifications
The Oracle Flash Accelerator F320 PCIe Card operates and is stored in an environment defined
by the parameters and specifications that are shown in the following table:
Operating temperature
0 to 55° C at 300 LFM minimum airflow
Non-operating temperature
Storage and transit environment: –-45 to 85° C
Altitude (Simulated)
Operating: -1,000 to 10,000 ft
Non-Operating: -1,000 to 40,000 ft
Relative humidity range
Temperature monitoring
Thermal sensors
Airflow requirement
More than 300 LFM (linear feet/minute, at 25/35° C, airflow
towards the IO bracket)
Shock
Non-operating 1,500G
Vibration
Operating:
2.17G RMS PSD (random 5 to 700Hz, zero to peak in x, y or
z-axis, flat response)
Non-operating:
3.13G RMS PSD (random 10 to 800Hz, zero to peak in x, y or
20G RMS (10~2,000Hz, Sweep sine)
Note -
For specific site planning guidelines and best practices, refer to the server documentation
and product notes for your server. Refer to the system site planning guide, if available.
