Oracle Real-Time Integration Business Insight Home page varies based on the user’s privileges logged in to the application. A super user can see the following tabs or navigational shortcuts on the Home page:
Home — used to navigate to the Home page.
Designer — used to create models, milestones, and indicators, that represent critical components of key business processes. This tab is visible only to users with the roles InsightBusinessUser/InsightIntegrationArchitect/InsightAdmin/InsightModelCreator.
Console — allows business performance tracking, trend identification, and the discovery of outliers using both custom and pre-defined dashboards. This tab is visible only to users with the roles InsightExecutive/InsightAdmin/InsightModelCreator.
Reports — creates and analyzes detailed data captured by models. This tab is visible only to users with the roles InsightExecutive/InsightAdmin/InsightModelCreator.
Administration — configures connections to application implementations to facilitate milestone and indicator mappings. This tab is visible only to users with the roles InsightAdmin/InsightConnectionCreator.
Guided Tour — walks you through the product using a set of videos. This tab is visible to all user roles.
Help Drawer — helps you to quickly access the documentation, videos, and tutorials of the product. This tab is visible to all user roles.
The Home page also displays Model Summary Cards, Reports, and Recent Models.
For more information about the role privileges of the users, see User Personas.
