To uninstall the connector, you must first delete all defined instances of the connector, and then you must delete the connector from the Self Update page.
To uninstall the connector:
From the Setup menu, select Extensibility, then Management Connectors.
Select an instance of the connector you want to delete, then click Delete.
On the Confirmation page, click Yes.
Repeat steps 2 and 3 until all instances of the connector have been deleted.
From the Setup menu, select Extensibility, then Self Update.
Click on the Management Connector link in the Type column.
A list of updates appears for Management Connectors.
Click on the connector you want to delete, select Actions, then select Delete.
The Delete Update window appears.
Click Delete to delete the connector.
The confirmation window appears.
Click OK.
