Exit Print View
When installing the module, follow antistatic precautions:
Use an antistatic mat as a work surface.
Wear an antistatic wrist strap that is attached to either the mat or a metal portion of the switch chassis.
Order Additional Hardware
Supported Cables
Cable Cautions
Remove the Filler Panel
Install the Module
Connect Cables
Verify Module Installation
