Remove the Filler Panel
Use this procedure to remove a filler panel or existing module from the slot where you are
installing the module.
Note -
To maintain thermal stability, never operate the switch with an empty slot.
Remove filler panels only as you replace them with an I/O module in a
one-for-one basis.
Identify the prerequisite and subsequent installation tasks that you must
perform in conjunction with this task.
See Installation Task Overview.
If the rack rear door is installed, open it.
At the location where you are installing the module, remove the filler panel,
if installed.
Squeeze the top and bottom of the release lever, and pull the lever in
a downward motion.
The filler panel is unseated from the slot connection.
Use the release lever to pull the filler panel from the switch
chassis.
Use your free hand to take the weight of the filler panel, as it comes
free of the chassis.
Set the filler panel aside and save it for future use.
Install the module.
See Install the Module.
