Database Connection Timeout |
DBConnectionTimeout |
Optional |
Determines if the Siebel Server attempts to prevent automatic closure of an idle database connection. In some situations, your database software might automatically close the connection if it is idle longer than an amount of time. This might occur when Siebel Remote initializes a local database when there is a slow communications link to the Siebel database (server database), such as might be the case with some connections to IBM DB2 on z/OS. If the Database Connection Timeout for parameter is 0, then the Siebel Server does not attempt to prevent database connection timeouts. If the Synchronization Manager server component reaches the timeout, then it exits with an error message. To configure the Siebel Server to prevent a database connection timeout, you can set the value of the Database Connection Timeout parameter to a value that is smaller than the timeout period for your database software. If the idle time reaches the value that you assign to this parameter, then the Siebel Server creates activity on the Siebel database connection to prevent a timeout. To set this parameter, you can use the Server Manager command line or the administrative screens. If you use the administration screens, then you must click the Advanced button in the header of the Component Parameters list. For more information, see Making Advanced Server Parameters Visible. |
Domain Name |
NTDomain |
Optional |
If your implementation uses AppServer authentication, then the Domain Name parameter specifies the Windows domain name for the user name and password. To use password authentication with Windows, you must provide the Windows user with rights to the Siebel Server. |
