Parent topic: Enterprise Back Office on a Server Cluster
/OBIEE/
/OBIEEPatch/
/Weblogic/
Install_version.exe
Install_version.exe to launch the installation wizard.Table 5-7 Oracle WebLogic Application Server Information
| Field | Description |
WebLogic User Name and WebLogic Password |
Create the login credentials for an administrator account on the WebLogic application server. The password must be eight to 20 characters, must not contain special characters, and must include at least one number. |
Local JVM Path |
Verify the folder path to the local Java Development Kit installation. This install path must not contain spaces. |
WebLogic Admin Server Host Name and WebLogic Admin Server Port |
Enter the hostname and port of the primary Oracle Business Intelligence server, typically 7001. |
BI Server Port |
Enter the port used by Oracle Business Intelligence, typically 9704. |
Node Manager port |
Enter the port used by the Node Manager, typically 9556. |
Make sure the filepath includes the following components: folder_path/file_name.extension
Normal: Review the install folder, features, and disk space requirements.
Advanced: Review and edit individual variables in the installation files, then review the install folder, features, and disk space requirements.
WebLogic Domain folder.
oracle.bi.enterprise folder, select mail.server, and then click Delete.
root\temp\MM_Log.log
root\temp\MMInstaller.log
root\myMicros\Uninstall_myMicros\myMicros_Install_datetime.log
root\Program Files\Oracle\Inventory\logs\ for error messages.Primary OBI server hostname:7001/console and log in using the WebLogic administrator account credentials created during the installation.beasvc_bifoundation_domain_bi_serverservernumber
Oracle Process Manager (hostname_ORCLRNA)
Oracle WebLogic NodeManager(path to Oracle Middleware wlserver installation)
root\myMicros\Oracle\Middleware\instances\hostname_ORCLRNA\bin\Figure 5-4 Non-Primary OBIEE opmnctl Status
Related Topics
