Parent topic: Enterprise Back Office on a Server Cluster
microsConfig.properties
file:
myInsightRootDir=Drive:/myMicros/myInsight
reportDefPath=Drive:/myMicros/myInsight/org
OBIEE.ImageTempPath=Drive:/myMicros/myPortal/imagesTemp
mySecureDocXDir=Drive:/myMicros/myInsight/secureMyDocX (if you are using the docViewer portlet)
/Weblogic/
Install_version.exe
Install_version.exe
to launch the installation wizard.Table 5-6 Oracle WebLogic Application Server Information
Field | Description |
WebLogic User Name and WebLogic Password |
Create the login credentials for an administrator account on the WebLogic application server. The password must be eight to 20 characters, must not contain special characters, and must include at least one number. |
Local JVM Path |
Verify the folder path to the local Java Development Kit installation. This install path must not contain spaces. |
WebLogic Admin Server Host Name and WebLogic Admin Server Port |
Enter the hostname and port of the primary Oracle Business Intelligence server, typically 7001. |
App Server Host Name |
Enter the hostname of the primary Reporting and Analytics WebLogic application server. |
Node Manager port |
Enter the port used by the Node Manager, typically 9556. |
E:
drive, you can create the mapped drive Z:\
and enter the path as shown in the following image:
Figure 5-3 Mapped Network Drive to OBI Server
myMicros
installation folder. For example, Z:\myMicros\
Make sure the filepath includes the following components: folder_path/file_name.extension
Normal: Review the install folder, features, and disk space requirements.
Advanced: Review and edit individual variables in the installation files, then review the install folder, features, and disk space requirements.
root\temp\MM_Log.log
root\temp\MMInstaller.log
root\myMicros\Uninstall_myMicros\Logs\myMicros_Install_datetime.log
Primary OBI server hostname:7001/console
and log in using the WebLogic administrator account credentials created during the installation.The status may be set to Starting if you check the WebLogic console immediately after completing installation. Verify that the status changes to Running.
beasvc_bifoundation_domain_AppServer
Oracle WebLogic NodeManager(path to Oracle Middleware wlserver installation)
Related Topics
