Parent topic: Enterprise Back Office on a Server Cluster
/OBIEE/
/OBIEEPatch/
/Weblogic/
Install_version.exe
Install_version.exe to launch the installation wizard.Table 5-1 Oracle WebLogic Application Server Information
| Field | Description |
WebLogic User Name and WebLogic Password |
Create the login credentials for an administrator account on the WebLogic application server. The password must be eight to 20 characters, must not contain special characters, and must include at least one number. |
Local JVM Path |
Verify the folder path to the local Java Development Kit installation. This install path must not contain spaces. |
WebLogic Admin Server Host Name and WebLogic Admin Server Port |
Enter the hostname and port of the primary Oracle Business Intelligence server, typically 7001. |
BI Server Port |
Enter the port used by Oracle Business Intelligence, typically 9704. |
Node Manager port |
Enter the port used by the Node Manager, typically 9556. |
Table 5-2 Oracle Business Intelligence Enterprise Edition Database Information
RCU Database Location |
Enter the hostname of the Enterprise Back Office database containing the Repository Creation Utility installation. |
SQL Server or Oracle |
Select the database type. |
Port and Database Service Name |
Enter the network port used by the database, and any additional connection parameters as necessary. |
BIPLATFORM Schema Password |
Enter the schema password you created for the Repository Creation Utility (RCU) during database installation. |
MDS Schema Password |
You must adhere to the Universal Naming Convention if you are manually entering the path: \\StorageName_or_IP\shared_folder_path\
Make sure the filepath includes the following components: folder_path/file_name.extension
| Oracle Database | Microsoft SQL Server |
Table 5-3 Online Analytical Processing Database Connection
OLAP Login and OLAP Password |
Enter the login credentials for the OLAP database. |
OLAP Server name or IP |
Enter the hostname of the OLAP database. |
OLAP DatabasePort |
Enter the OLAP database server port. |
OLAP DB SID |
Enter the SID for the OLAP database. |
| Connection | Page | Information |
IceWarp Mail Server |
Portal Mail Server |
Enter the Simple Mail Transfer Protocol (SMTP) hostname and port of the server that will host the IceWarp Mail Server, and then enter the mail domain, such as example.com. |
InfoDelivery Service |
InfoDelivery Mail Server |
Enter the hostname of the IceWarp Mail Server, or enter the hostname for the separate InfoDelivery server. Enter the SMTP port. |
RTA Master Server |
Location of Master Server |
Enter the hostname of the RTA Master Server. |
Table 5-4 Reporting and Analytics Configurations
Names of all Portal Application Servers |
Enter the hostnames of all Reporting and Analytics web application servers in a comma-separated list. |
Administrator e-mail address |
Enter the email address, without the domain, of the administrator account. |
What email user will the Portal use to send mail? |
Enter the email address, without the domain, that the Portal uses to send mail. |
What is the password for the email user? |
Enter the password for the portal email user. |
Use HTTPS protocol for portal? |
Select whether the web application uses the HTTPS protocol. This option requires a Secure Socket Layer (SSL) connection and should typically only be selected when the installation environment has an SSL accelerator. |
Password for Messaging Queue |
Enter the login credentials for the messaging queue. This field does not show when performing an upgrade. |
Username and Password for utility user |
Enter the login credentials for the UTIL account created during database installation. |
Username and Password for CE user |
Enter the login credentials for accessing the Microsoft Windows Compact Edition database (CEDB). |
New Line Style for Portal CSV display |
Select whether to use Windows, Unicode, or HTML line styling when using the CSV export while viewing a report. |
Table 5-5 Report Mail Font Configurations
Enable User Font |
Select whether to allow using custom fonts when rendering PDFs. |
Path to user font |
Enter the path to a font, or click Choose and navigate to a font, to set the font used when rendering PDFs. |
Limit detail query days |
Enter a date limit for executing audit/analysis detail queries. The Organization configuration can override this setting. |
Limit summary query days |
Enter a date limit for executing audit/analysis summary queries. The Organization configuration can override this setting. |
New Line Style for InfoDelivery CSV format |
Select whether to use Windows, Unicode, or HTML line styling when formatting Report Mail items in CSV. |
Load reports by market segment |
Select whether to load reports dynamically by appending the organization or role market segment to the template name. |
Normal: Review the install folder, features, and disk space requirements.
Advanced: Review and edit individual variables in the installation files, then review the install folder, features, and disk space requirements.
WebLogic Domain folder.
oracle.bi.enterprise folder, select mail.server, and then click Delete.
root\temp\MM_Log.log
root\temp\MMInstaller.log
root\myMicros\Uninstall_myMicros\myMicros_Install_datetime.log
root\Program Files\Oracle\Inventory\logs\ for error messages.Primary OBI server hostname:7001/console and log in using the WebLogic administrator account credentials created during the installation.beasvc_bifoundation_domain_AdminServer
beasvc_bifoundation_domain_bi_server1
Oracle Process Manager (hostname_ORCLRNA)
Oracle WebLogic NodeManager(path to Oracle Middleware wlserver installation)
root\myMicros\Oracle\Middleware\instances\hostname_ORCLRNA\bin\Figure 5-2 Primary OBIEE opmnctl Status
Related Topics
