Parent topic: Gift and Loyalty
Before installing the Gift and Loyalty application:
Verify that your server meets the system requirements. The Application Server Compatibility and Requirements section in the Oracle MICROS Enterprise Back Office Release Notes contains compatibility and requirement information.
Install the required Java Development Kit version in a folder path that does not contain spaces. For example, do not install Java in the default Program Files path.
For 9.1 or 9.1 with OBIEE: 7001, 9704, and 9556
For the 9.1 New Tech Stack: 7002, 9704, and 9556
Verify that the Gift and Loyalty server can connect to the Gift and Loyalty database server.
Obtain separate Secure Socket Layer (SSL) certificates for the Gift and Loyalty application server. Ensure that the SSL certificate password is alphanumeric and does not contain any special characters.
Disable tunnel adapters. Disabling Tunnel Adapters contains information and instructions for checking for and disabling the adapter.
Parent topic: Installing the Gift and Loyalty Application Server
Follow the instructions to configure Gift and Loyalty settings for all organizations in Enterprise Back Office:
By default, Gift and Loyalty uses the same listening ports as Reporting and Analytics. If you installed Gift and Loyalty on the Reporting and Analytics application sever, change the listening ports to unused ports using the following steps:
Related Topics
