The Enterprise Back Office Release 9.1 has four release variations. The main differences are the support for underlying technology stack, the inclusion of Oracle Business Intelligence, and the support for Interactive Reports (Pentaho).
| Topic | Enterprise Back Office 9.1 | Enterprise Back Office 9.1 With Oracle Business Intelligence Enterprise Edition (OBIEE) | Enterprise Back Office 9.1 New Tech Stack with Pentaho | Enterprise Back Office 9.1 New Tech Stack |
Release variations |
Referred to as 9.1 release in this guide. |
Referred to as 9.1 with OBIEE release in this guide. |
Referred to as 9.1 New Tech Stack with Pentaho release in this guide. |
Referred to as 9.1 New Tech Stack release in this guide. |
Initial Release |
April 2019 |
June 2018 |
November 2022 |
March 2023 |
New or existing install |
Can only be used for existing installs |
Must be used for new installs |
Oracle Business Intelligence Enterprise Edition (OBIEE) included |
No |
Yes |
No |
No |
Support for Pentaho Interactive Reports included |
Yes |
Yes |
Yes |
No |
Location where general release media is downloaded. |
My Oracle Support (MOS) |
Oracle Software Delivery Cloud |
Download Package name in Oracle Software Delivery Cloud |
N/A |
N/A |
N/A |
Oracle MICROS eBusiness Suite 9.1.0.0.0 (Oracle MICROS Reporting and Analytics) |
File Name(s) included in Download Package |
N/A |
N/A |
N/A |
V1034346-01.zip Oracle MICROS Enterprise Back Office 9.1.0 New Tech Stack |
File Name(s) in MOS |
N/A |
High-level supported technology stack |
SSL Certificate requirements |
Recommended |
Recommended |
CA-signed certificate required at the time of application install. |
POS compatibility |
Review the Compatibility Matrix |
Patchset availability |
Yes, future Enterprise Back Office patchsets can be applied. |
Required patchsets |
Oracle strongly recommends applying the latest application patchsets and applying all WebLogic and Java security patchsets. Log in to the Support Portal and then click Document 6389 for more information. The Pentaho Patch Installer needs to be applied after 9.1.35 or higher patch. |
Yes, patchset 9.1.35 or higher needs to be applied after installing the general release media from MOS. If Pentaho Interactive Reports are being used, the Pentaho Patch installer needs to be applied Oracle strongly recommends applying the latest application patchsets and apply all WebLogic and Java security patchsets. Log in to the Support Portal and then click Document 6389 for more information. |
Yes, patchset 9.1.35 or higher must be applied after installing the general release media from the Oracle Software Delivery Cloud. Oracle strongly recommends applying the latest application patchsets and apply all WebLogic and Java security patchsets. Log in to the Support Portal and then click Document 6389 for more information. |
Long-term technology support |
No. Support timelines for the underlying tech stack components (operating system, database, WebLogic, and Java) have ended or will end soon. |
Yes. Support timelines for the underlying tech stack components (operating system, database, WebLogic, and Java) extend into 2025 and some components even go beyond that date. |
Parent topic: Release Variations
