You can install Enterprise Back Office in a server cluster, with dedicated servers for certain high-load applications and services. One server hosts the Portal WebLogic AdminServer component. The same server can host Reporting and Analytics or other servers in the environment can host Reporting and Analytics. Only one server in the environment can host the Portal WebLogic AdminServer component.
Install the servers and components in the following order. Make sure each set of instructions is complete before moving to the next server.
Before starting installation, review related documentation and prepare your environment and servers.
Install the Enterprise Back Office database depending on your database type:
