microsConfig.properties file on Portal WebLogic AdminServer and then redeploy the portal using the WebLogic Admin server console:
myInsightRootDir=Drive:/myMicros/myInsight
reportDefPath=Drive:/myMicros/myInsight/org
mySecureDocXDir=Drive:/myMicros/myInsight/secureMyDocX (if you are using the docViewer portlet)
/Weblogic/
Install_version.exe
Install_version.exe.Table 4-5 Oracle WebLogic Application Server Information
| Field | Description |
WebLogic User Name and WebLogic Password |
Create the login credentials for an administrator account on the WebLogic application server. The password must be eight to 20 characters, must not contain special characters, and must include at least one number. |
Local JVM Path |
Verify the folder path to the local Java Development Kit installation. |
WebLogic Admin Server Host Name and WebLogic Admin Server Port |
Enter the name of the server that hosts Portal WebLogic AdminServer. |
App Server Host Name |
Enter the hostname of the Reporting and Analytics WebLogic application server. |
Node Manager port |
Enter the port used by the Node Manager, typically 9556. |
Make sure the filepath includes the following components: folder_path/file_name.extension
Normal: Review the install folder, features, and disk space requirements.
Advanced: Review and edit individual variables in the installation files, then review the install folder, features, and disk space requirements.
Parent topic: Enterprise Back Office on Multiple Servers
root\temp\MM_Log.log
root\temp\MMInstaller.log
root\myMicros\Uninstall_myMicros\Logs\myMicros_Install_datetime.log
HOSTNAME is the name of the host server.
appServ1 is the default name of the Reporting and Analytics application server instance. If you changed the default name when you installed Reporting and Analytics, that name appears instead of the default.
beasvc_bifoundation_<HOSTNAME>_appServ1.
Oracle WebLogic NodeManager (<Path to Oracle Middleware wlserver installation>)
wlsvc bifoundation_domain_<HOSTNAME>_appServ1
Oracle Weblogic bifoundation_domain NodeManager
Related Topics
Parent topic: Installing Reporting and Analytics
