/Weblogic/
Install_version.exe
Install_version.exe to launch the installation wizard.Table 4-1 Oracle WebLogic Application Server Information
| Field | Description |
WebLogic User Name and WebLogic Password |
Create the login credentials for an administrator account on the WebLogic application server. The password must be eight to 20 characters, must not contain special characters, and must include at least one number. |
Local JVM Path |
Verify the folder path to the local Java Development Kit installation. |
WebLogic Admin Server Host Name and WebLogic Admin Server Port |
Enter the hostname and port of the server that hosts Portal WebLogic AdminServer. |
Node Manager port |
Enter the port used by the Node Manager, typically 9556. |
Both passwords can only contain alphanumeric characters. Special characters, symbols, or spaces are not allowed.Make sure the filepath includes the following components: folder_path/file_name.extension
| Oracle Database | Microsoft SQL Server |
Table 4-2 Online Analytical Processing Database Connection
OLAP Login and OLAP Password |
Enter the login credentials for the OLAP database. |
OLAP Server name or IP |
Enter the hostname of the OLAP database. |
OLAP DatabasePort |
Enter the OLAP database server port. |
OLAP DB SID |
Enter the SID for the OLAP database. |
| Connection | Page | Information |
IceWarp Mail Server |
Portal Mail Server |
Enter the Simple Mail Transfer Protocol (SMTP) hostname and port of the server that will host the IceWarp Mail Server, and then enter the mail domain, such as example.com. |
InfoDelivery Service |
InfoDelivery Mail Server |
Enter the hostname of the IceWarp Mail Server, or enter the hostname for the separate InfoDelivery server. Enter the SMTP port. |
RTA Master Server |
Location of Master Server |
Enter the hostname of the RTA Master Server. |
Table 4-3 Reporting and Analytics Configurations
Names of all Portal Application Servers |
Enter the hostnames of all Reporting and Analytics web application servers in a comma-separated list. |
Administrator e-mail address |
Enter the email address, without the domain, of the administrator account. |
What email user will the Portal use to send mail? |
Enter the email address, without the domain, that the Portal uses to send mail. |
What is the password for the email user? |
Enter the password for the portal email user. |
Use HTTPS protocol for portal? |
Select whether the web application uses the HTTPS protocol. This option requires a Secure Socket Layer (SSL) connection and should typically only be selected when the installation environment has an SSL accelerator. |
Password for Messaging Queue |
Enter the login credentials for the messaging queue. This field does not show when performing an upgrade. |
Username and Password for utility user |
Enter the login credentials for the UTIL account created during database installation. |
Username and Password for CE user |
Enter the login credentials for accessing the Microsoft Windows Compact Edition database (CEDB). |
New Line Style for Portal CSV display |
Select whether to use Windows, Unicode, or HTML line styling when using the CSV export while viewing a report. |
Table 4-4 Report Mail Font Configurations
Enable User Font |
Select whether to allow using custom fonts when rendering PDFs. |
Path to user font |
Enter the path to a font, or click Choose and navigate to a font, to set the font used when rendering PDFs. |
Limit detail query days |
Enter a date limit for executing audit/analysis detail queries. The Organization configuration can override this setting. |
Limit summary query days |
Enter a date limit for executing audit/analysis summary queries. The Organization configuration can override this setting. |
New Line Style for InfoDelivery CSV format |
Select whether to use Windows, Unicode, or HTML line styling when formatting Report Mail items in CSV. |
Load reports by market segment |
Select whether to load reports dynamically by appending the organization or role market segment to the template name. |
Normal: Review the install folder, features, and disk space requirements.
Advanced: Review and edit individual variables in the installation files, then review the install folder, features, and disk space requirements.
Parent topic: Enterprise Back Office on Multiple Servers
root\temp\MM_Log.log
root\temp\MMInstaller.log
root\myMicros\Uninstall_myMicros\myMicros_Install_datetime.log
beasvc_bifoundation_domain_AdminServer
Oracle WebLogic NodeManager (<Path to Oracle Middleware wlserver installation>)
wlsvc bifoundation_domain_AdminServer
Oracle Weblogic bifoundation_domain NodeManager
Related Topics
Parent topic: Installing Portal WebLogic AdminServer
