1. Preface
This document contains notes and installation steps needed to install WebServices. Oracle Financial Services Lending and Leasing relies on several pieces of Oracle software in order to run and this document is in no way meant to replace Oracle documentation supplied with the WebServices product or available via Oracle technical support. The purpose of this document is only meant to supplement the Oracle documentation and to provide Oracle Financial Services Lending and Leasing specific installation instructions.
For recommendations on security configuration, refer Security Configuration Guide.
It is assumed that anyone installing Oracle Financial Services Lending and Leasing will have a thorough knowledge and understanding of WebServices.
This guide covers the following processes.
1.1 Prerequisites
  1. Download and Install the Oracle WebLogic Server 12c Version 12.2.1.0.0 from http://www.oracle.com/technetwork/middleware/weblogic/downloads/wls-main-097127.html). They are available from the following sources:
  1. It is assumed that the Oracle Financial Services Lending and Leasing DB is installed and configured, before running the WebServices installer.
1.2 Audience
This document is intended for system administrators or application developers who are installing Oracle Financial Services Lending and Leasing Application.
1.3 Conventions Used
Term
Refers to
Application
