Table 87. Properties That Siebel CRM Commonly Uses with a Screen View
Category Default View |
Defines the default view for a screen view as an Aggregate Category or Detail Category. It is recommended that you define the Category Default View property. If this property is empty, then Siebel CRM lists views alphabetically. If the category for the screen view is Aggregate View or Detail View, then the Category Default View property is read-only. |
Category Name |
Name of the Aggregate Category or Detail Category. This property must be unique in each screen. If the category for the screen view is Aggregate View or Detail View, then the Category Name property is read-only. |
Display in Page |
If Siebel CRM must display the screen view in the page, then you must set the Display in Page property to TRUE. If the category for the screen view is Aggregate Category or Detail Category, then you must set the Display in Page property to TRUE. If no views in the category are included, then Siebel CRM does not display the screen view. |
Display in Site Map |
If Siebel CRM must display the screen view on the Site Map, then the Display in Site Map property must be TRUE. |
Menu Text |
Text that Siebel CRM displays in the Site Map. To modify the text style that it displays in the Site Map, you can use HTML tags in the Menu Text property. For more information, see Modifying the Text Style of a Control or List Column in an Applet. |
Name |
Calculated field. |
Parent Category |
If the Type property is Aggregate Category, then the Parent Category property is empty because no parent exists. If the Type property is Aggregate View, then the Parent Category property might or might not be empty. If the Type property is Detail View or Detail Category, then the Parent Category property must contain a value. |
Type |
Can be one of the following values:
- Aggregate Category
- Aggregate View
- Detail Category
- Detail View
For more information, see About Screen Views. |
View |
If the Type property of the screen view is Aggregate View or Detail View, then you must define the view property. The View property associates the view with the screen view. The View property is read only for Aggregate Category and Detail Category. |
