Configuring Siebel Business Applications > Reference Materials for Configuring Siebel Business Applications > Properties of Object Types >
Properties of an Application
Table 88 describes properties of the Application object type.
Table 88. Properties of the Application Object Type
Property
Description
Acknowledgement Web Page
The Web page that Siebel CRM displays after the user successfully logs in. If a login occurs after a timeout, then it displays the view that the user attempted to access when the timeout occurred.
Acknowledgement Web View
The view that Siebel CRM displays after the user successfully logs in, except in the following situations:
  • Timeout. If the user logs in after a timeout, then Siebel CRM displays the view that the user attempted to access when the timeout occurred.
  • Explicit login required. Assume the following occurs:
    • An anonymous user logs in to a customer application.
    • The Explicit Login property is set to TRUE for the view that the user attempts to access.
    • The user successfully enters the login credentials.
      In this situation, Siebel CRM displays the view that the user was attempting to access. It does not display the view defined in the Acknowledgement Web View property.
Container Web Page
A Web page that defines the structure of the Siebel application. This page can contain the common user interface components, such as screen bars, view bars, logos, and so on. You can use this page to define the HTML Frame definition document for the Siebel application. Siebel CRM displays all views and, as an option, all pages in the context of the container page. For more information, see About the Container Page.
Error Web Page
The page Siebel CRM displays if an error occurs in the Siebel application.
Login Web Page
The page Siebel CRM displays as the login page.
Logoff Acknowledgement Web Page
The page Siebel CRM displays when the user logs out of the Siebel application.
Sort Web Page
The page Siebel CRM uses to create a dialog to perform an advanced sort on list applet columns.
Configuring Siebel Business Applications Copyright © 2018, Oracle and/or its affiliates. All rights reserved. Legal Notices.
