| Bookshelf Home | Contents | Index | PDF | ![]()     |
 Configuring Siebel Open UI > Reference Information for Siebel Open UI > Notifications That Siebel Open UI Supports > Using Notifications with Operations That Call MethodsIt is recommended that you do not use some notifications with an operation that calls a method. For example, if the user paginates to the next page in a set of 10 records, and if you use NotifyInsertWorkSet with the method that calls this pagination, then Siebel Open UI will create 10 separate NotifyInsertWorkSet notifications.  |
| Configuring Siebel Open UI | Copyright © 2018, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
