Table 48.	 NotifyGeneric Notification Type
    SWEICanInvokeMethod   |
    Enables the refresh button.
    SWEICtlDefChanged   |
    Modifies the definition for a control. You can customize Siebel Open UI to dynamically modify the definition that a control uses. For example, modifying a definition from JavaScript text box to a JavaScript combo box.   |
    SWEIPrivFlds   |
    Specifies a list of private fields. For example, the Find controls that Siebel Open UI displays in a dialog box. A private field is a type of field that only allows the record owner to view the record. For more information, see Siebel Object Types Reference.   |
    SWEICanUpdate   |
    Specifies to display data-driven, read-only behavior.
    SWEICanNavigate   |
    If a list applet displays zero records, and if the user adds a new record, then the SWEICanNavigate subtype displays the drilldown links.   |
    SWEIRowSelection   |
    Sends the set of selected rows that exist in the current set of records to a list applet. You can use the following syntax in the decoded array: argsArray[0] = applet name
argsArray[1-x] = value
where:
- applet name identifies the name of the applet where Siebel Open UI sends the notification.
 - value is one of the following:
- 1. Indicates selected.
 - 0. Indicates not selected.
    SWEAInvokeMethod   |
    Adds an operation in the life cycle that the InvokeMethod method uses. For example, assume you configure an OK button in an association applet, and that this button closes a dialog box. You can use the SWEAInvokeMethod subtype to configure this button to make a subsequent call to the CreateRecord method if the user clicks OK.  You can use the following syntax in the decoded array:  argsArray[0] = applet
argsArray[1] = method
where:
- applet identifies the name of the applet that Siebel Open UI calls during the first operation.
 - method identifies the name of the subsequent method that Siebel Open UI calls.
For more information, see InvokeMethod Method for Presentation Models.   |
    DeletePopup   |
    Deletes a popup applet. The DeletePopup subtype does not close an applet in the user interface. You can use ClosePopup to close an applet.
    SetPopupBookmark   |
    Sets the context for a popup bookmark to use the state of the parent applet that resides on the Siebel Server.
    GetQuickPickInfo   |
    Sends the values of a picklist to an applet. You can use the following syntax in the decoded array:  argsArray[0] = placeholder
argsArray[1] = view
argsArray[2] = applet
argsArray[3] = identifier
argsArray[4] = control
argsArray[5-x] = string
where:
- placeholder is a placeholder array that you can you use.
 - view identifies the name of the view where Siebel Open UI displays the picklist.
 - applet identifies the name of the applet where Siebel Open UI displays the picklist.
 - identifier identifies the HTML identifier of the control that requested the picklist values.
 - control contains one of the following values:
- true. Picklist is associated with the control.
 - false. Picklist is not associated with the control.
 - string contains the values of the picklist.
    BegRow   |
    Sends the starting row that the Object Manager uses to display the current row in the client. You can use the following syntax in the decoded array:  argsArray[0] = applet name
argsArray[1] = value
where:
 - value contains the value of the beginning row.
    GetCurrencyCalcInfo   |
    Gets a currency notification from the currency metadata.
    GetCurrencyCodeInfo   |
    Gets a currency notification from specific currency data.   |
    CloseCurrencyPickApplet   |
    Sends a notification to close a currency applet.   |
    ClosePopup   |
    Notifies an applet that Siebel Open UI is closing a popup that is currently open on this applet. You can use the following syntax in the decoded array:  argsArray[0] = applet
where:
- applet identifies the name of the applet.
