Table 49.	 NotifyStateChanged Notification Type
    activeRow   |
    Identifies the active row of the business component. You can use ar (active row) to abbreviate activeRow.   |
    bCanDelete   |
    Returns a Boolean value that includes one of the following values:
- 0. The business component can delete a field.
 - 1. The business component cannot delete a field.
You can use cd (can delete) as an abbreviation for bCanDelete.   |
    bCanInsert   |
- 0. The business component can insert a field.
 - 1. The business component cannot insert a field.
You can use ci (can insert) as an abbreviation for bCanInsert.   |
    bCanInsertDynamic   |
- 0. The business component can insert a dynamic field.
 - 1. The business component cannot insert a dynamic field.
You can use cud (can insert dynamic) as an abbreviation for bCanInsertDynamic.   |
    bCanMergeRecords   |
- 0. Merge is available in multi select mode.
 - 1. Merge is not available in multi select mode.
You can use cm (can merge) as an abbreviation for bCanMergeRecords.   |
    bCanQuery   |
- 0. The business component can query a field.
 - 1. The business component cannot query a field.
You can use cq (can query) as an abbreviation for bCanQuery.   |
    bCanUpdate   |
- 0. The business component can update a field.
 - 1. The business component cannot update a field.
You can use cu (can update) as an abbreviation for bCanUpdate.   |
    bCanUpdateDynamic   |
- 0. The business component can update a dynamic field.
 - 1. The business component cannot update a dynamic field.
You can use cud (can update dynamic) as an abbreviation for bCanUpdateDynamic.   |
    bCommitPending   |
- 0. A commit is pending on the business component.
 - 1. A commit is not pending on the business component.
You can use cp (commit pending) as an abbreviation for bCommitPending.   |
    bDelRecPending   |
- 0. A delete is pending on the business component.
 - 1. A delete is not pending on the business component.
You can use dp (delete pending) as an abbreviation for bDelRecPending.   |
    bExecuted   |
- 0. Siebel Open UI finished processing the business component records.
 - 1. Siebel Open UI did not finish processing the business component records.
You can use ex (executed) as an abbreviation for bExecuted.   |
    bHasAssocList   |
    Determines whether or not the business component is an association business component. An association business component is a type of business component that includes an intertable.   |
    bInMultiSelMode   |
- 0. The business component is in multiselect mode.
 - 1. The business component is not in multiselect mode.
You can use ms (multiselect) as an abbreviation for bInMultiSelMode.   |
    bInQueryState   |
- 0. The business component is in a query state.
 - 1. The business component is not in a query state.
You can use qs (query state) as an abbreviation for bInQueryState.   |
    bInverseSelection   |
- 0. An inverse of selection is occurring on the business component.
 - 1. An inverse of selection is not occurring on the business component.
You can use is (inverse selection) as an abbreviation for bInverseSelection.  |
    bNewRecPending   |
- 0. A new record is pending on the business component.
 - 1. A new record is not pending on the business component.
You can use np (new record pending) as an abbreviation for bNewRecPending.   |
    bNotifyEnabled   |
- 0. The business component is not enabled for notifications.
 - 1. The business component is enabled for notifications.
You can use n (enabled) as an abbreviation for bNotifyEnabled.   |
    NumRows   |
    Returns the number of rows that Siebel Open UI has currently identified. You can use nr (number of rows) as an abbreviation for NumRows.   |
    NumRowsKnown   |
    Returns the number of rows that Siebel Open UI has currently identified for a search specification. You can use nrk (number of rows known) as an abbreviation for NumRowsKnown.   |
    NumSelected   |
    Returns the number of rows that are currently in multiselect mode. You can use ns (number selected) as an abbreviation for NumSelected.   |
