Table 47.	 Notification Types That Siebel Open UI Supports
    NotifyBeginNotifys   |
    SWE_PROP_BC_NOTI_BEGIN   |
    Notifies the client business component that the request that Siebel Open UI sent to the Siebel Server resulted in at least one notification from a business component.  |
    NotifyStateChanged   |
    SWE_PROP_BC_NOTI_STATE_CHANGED   |
    Specifies a top-level notification for more than one state change that occurs in the business component level. Siebel Open UI uses the following properties to identify the change and to get the data associated with the change:
Siebel Open UI can provide summary or detailed state information. For more information, see NotifyStateChanged Notification Type.  |
    NotifyGeneric   |
    SWE_PROP_BC_NOTI_GENERIC   |
    Identifies the predefined and custom notifications that the Siebel application must send. Siebel Open UI addresses most predefined generic notifications to a particular applet.  You can use NotifyGeneric to get the exact type for a generic notification. Siebel Open UI provides actual information of the changes as an encoded argument set.   |
    NotifyNewSelection   |
    SWE_PROP_NOTI_SELECTED   |
    Notifies the client business component that a change occurred in the selection status. Siebel Open UI calls NotifyNewSelection two times for each selection status change:
- One time a value of
false for the last row selected
 - One time with a value of
true for the new row that Siebel Open UI is selecting
You cannot use NotifyNewSelection with a multi-select. You can use the following syntax in the property set that Siebel Open UI sends:  SWE_PROP_BC_NOTI_ACTIVE_ROW = index
SWE_PROP_NOTI_SELECTED = Boolean
where:
- index identifies the index of the row that Siebel Open UI is activating or deactivating.
 - Boolean is true or false.
    NotifyNewActiveRow   |
    SWE_PROP_BC_NOTI_NEW_ACTIVE_ROW   |
    Notifies the client business component that a change occurred on an active row of the corresponding business component on the Siebel Server. Siebel Open UI usually uses NotifyNewSelection with NotifyNewActiveRow.  You can use the following syntax:  SWE_PROP_BC_NOTI_ACTIVE_ROW = row
where:
- row identifies the row that Siebel Open UI is activating or deactivating.
    NotifyDeleteRecord   |
    SWE_PROP_BC_NOTI_DELETE_RECORD   |
    Notifies the business component in the client that Siebel Open UI deleted a record from the current set of records on the Siebel Server. Siebel Open UI might use this notification two times for a single record deletion.  You can use the following syntax in the property set that Siebel Open UI sends:  SWE_PROP_BC_NOTI_ACTIVE_ROW = index
bUp = Boolean
where:
- index identifies the index of a record that resides in the current set of records that Siebel Open UI is deleting.
 - Boolean is one of the following values:
- true. Shift records up after the delete.
 - false. Shift records down after the delete.
For an example usage of this notification, see Customizing the Presentation Model to Handle Notifications.   |
    NotifyDeleteRecordSet   |
    SWE_PROP_BC_NOTI_DELETE_WORKSET   |
    Notifies the business component in the client that Siebel Open UI is deleting a record from the current set of records in the client. Does not correspond to a method invoke. Siebel Open UI sends a separate notification for each record that it deletes. You can use the following syntax in the property set that Siebel Open UI sends: index:index
NumRows/nr:number
where:
- index identifies the start index of the record that Siebel Open UI is deleting.
 - number identifies the number of rows that Siebel Open UI must delete.
For more information, see Using Notifications with Operations That Call Methods.   |
    NotifyInsertWorkSet   |
    SWE_PROP_BC_NOTI_INSERT_WORKSET   |
    Notifies the business component in the client that Siebel Open UI is inserting a new record in the current set of records in the client.  You can use the following syntax in the property set that Siebel Open UI sends:  index:index_value
SWE_FIELD_VALUE_STR:child
SWE_PROP_VALUE_ARRAY:array
where:
- index identifies the index of the record that Siebel Open UI is inserting.
 - child identifies the child property set that contains the record data.
 - array is an array that contains the field values of the record that Siebel Open UI is inserting. This array must use the same sequence that the business component uses when it lists these field values.
    NotifyNewData   |
    SWE_PROP_BC_NOTI_NEW_DATA   |
    Notifies the business component in the client that Siebel Open UI is modifying the current set of records. Siebel Open UI sends this notification only if it modifies a record. It does not send this notification if it only modifies a field value.   |
    NotifyNewPrimary   |
    SWE_PROP_BC_NOTI_NEW_PRIMARY   |
    Sets the primary record in a multi-value group. The RepopulateField notification calls NotifyNewPrimary.
    NotifyNewRecord   |
    SWE_PROP_BC_NOTI_NEW_RECORD   |
    Notifies the client business component that Siebel Open UI is creating a new record in the current set of records on the Siebel Server. You can use the following syntax in the property set that Siebel Open UI sends:  SWE_PROP_BC_NOTI_ACTIVE_ROW = index
bInsertBefore = Boolean
where:
- row identifies the index of the record that Siebel Open UI is creating.
- true. Place the new record before the previous active row.
 - false. Place the new record after the previous active row.
For a similar usage of this notification, see Customizing the Presentation Model to Handle Notifications.   |
    NotifyNewRecordData   |
    SWE_PROP_BC_NOTI_NEW_RECORD_DATA   |
    Sets the do populate flag.
    NotifyNewDataWorkSet   |
    SWE_PROP_BC_NOTI_NEW_RECORD_DATA_WS   |
    Updates a record in the current set of records.   |
    NotifyNewFieldData   |
    SWE_PROP_BC_NOTI_NEW_FIELD_DATA   |
    Notifies the client business component that Siebel Open UI modified a field value on the Siebel Server, and that Siebel Open UI communicated this modification to the client through the NotifyNewDataWorkset notification.  You can use the following syntax in the property set that Siebel Open UI sends:  SWE_PROP_NOTI_FIELD = field
where:
- field identifies the name of the field that Siebel Open UI is modifying.
    NotifyNewDataWorkset    |
    SWE_PROP_BC_NOTI_NEW_DATA_WS   |
    Notifies the client business component of a field value that Siebel Open UI modified for a field that resides on the Siebel Server. You can use the following syntax in the property set that Siebel Open UI sends:  SWE_PROP_NOTI_FIELD = field
SWE_PROP_FIELD_VALUES = child
where:
 - child identifies the name of the child property set that contains the modification details.
You can use the following syntax in the child property set:  SWE_PROP_FIELD_ARRAY:string1
SWE_PROP_VALUE_ARRAY:string2
where:
- string1 is an encoded string that identifies the field index.
 - string2 is an encoded string that identifies the field value.
    NotifyNewFieldList   |
    SWE_PROP_BC_NOTI_NEW_FIELD_LIST   |
    Refreshes the entire view internally.
    NotifyNewRecordDataWS   |
    Updates the values in the record set. Siebel Open UI updates the dirty flag during previous notifications.
    NotifyChangeSelection   |
    SWE_PROP_BC_NOTI_CHANGE_SELECTION   |
    Sets the update conditionals flag and the row counter.
    NotifyEndNotifys   |
    SWE_PROP_BC_NOTI_END   |
    Notifies the client business component that Siebel Open UI is ending the notification, and that no more server notifications exist for the current transaction.   |
    NotifyBeginQuery   |
    SWE_PROP_BC_NOTI_BEGIN_QUERY   |
    Notifies the client business component that Siebel Open UI started a query on the business component on the Siebel Server.   |
    NotifyNewQuerySpec   |
    SWE_PROP_BC_NOTI_NEW_QUERYSPEC   |
    Siebel Open UI uses the NotifyNewQuerySpec notification if the user refines a query. If the business component search specification is empty, then NotifyNewQuerySpec clears all field search specifications.   |
    NotifyNewFieldQuerySpec   |
    SWE_PROP_BC_NOTI_NEW_FIELD_QUERYSPEC   |
    Notifies the client business component that Siebel Open UI is doing one of the following to query the fields of the current business component on the Siebel Server:
- Using a default query specification
 - Starting or running a query
This situation can occur through a predefined or custom configuration, or in reply to a query that the user performs.  You can use the following syntax in the property set that Siebel Open UI sends:  SWE_PROP_NOTI_FIELD = fieldSWE_PROP_VALUE = search specification"
where:
- field identifies the name of the field that Siebel Open UI is querying.
 - search specification identifies a query specification that is defined on this field.
    NotifyEndQuery   |
    SWE_PROP_BC_NOTI_END_QUERY   |
    Notifies the client business component that Siebel Open UI is ending a query on the business component on the Siebel Server. This situation can occur if the ExecuteQuery method or the UndoQuery method runs.   |
    NotifyExecute   |
    SWE_PROP_BC_NOTI_EXECUTE   |
    Notifies the client business component that Siebel Open UI is running a business component on the Siebel Server. You can use the following syntax in the property set that Siebel Open UI sends:  srt = sort specifications
where:
- sort specification identifies the sort specification that Siebel Open UI runs.
 - search specification identifies the search specification that Siebel Open UI runs.
    NotifyScrollAmount   |
    SWE_PROP_BC_NOTI_SCROLL_AMOUNT   |
    Sets the scroll folder and the amount for a mobile swipe operation.
    NotifyPageRefresh   |
    SWE_NOTIFY_PAGE_REFRESH   |
    Updates the urltogo with the URL that Siebel Open UI uses to refresh a view. Siebel Open UI gets this URL from a subsequent executeurltoGo notification.
