| Siebel CRM Fundamentals Guide Siebel Innovation Pack 2017, Rev. A E52425-01 |
![]() Previous |
![]() Next |
View PDF |
Figure 3-1 shows the main elements of an example application window using the default web application UI theme. Typically, the main elements of the application window are:
"Application Banner", which contains the following elements: side menu, application-level menu, and menu toolbar.
"Application Toolbar", which contains the following options: New Query, Execute Query, Apply Target List, Save Target List, Site Map, How Do I, Tasks, Reports.
"Second Level View Bar", which appears immediately after the application toolbar.
"Visibility Filter", which appears on a screen or view in the application (provided a visibility filter is available for the screen or view).
"List", which consists of multiple records presented as rows.
"Form", which typically appears after a list and contains the data for the record you select in the list.
"List and Form Toolbar", which appears on lists and forms.
