| Siebel CRM Fundamentals Guide Siebel Innovation Pack 2017, Rev. A E52425-01 |
![]() Previous |
![]() Next |
View PDF |
You can create records in the application using several methods, such as clicking a button or choosing an option from a menu. When you create a record, a new record appears, containing fields to complete.
The procedures in this topic show how to create records using some of the options in the Siebel application. You can use the method that you prefer, or the method that is available.
Some records contain read-only fields. Read-only fields are fields in which you cannot enter data. You might not have user privileges that allow you to enter data in the read-only field, or the data in the field might be automatically populated by the Siebel application.
Note: Not all users can create new records. Your ability to create new records depends on the responsibilities your Siebel administrator gives to you. |
To create a record
Do one of the following:
In the list or form, click Add or New (the plus (+) or double plus (++) icon).
In the list or form, click Menu (the cogwheel icon), and then click New Record.
In the list or form, click Edit, and then select New Record from the application-level menu.
A new record appears.
Enter the appropriate data, and save the record.
Related Topics
