| Oracle® Communications EAGLE Database Administration - System Management User's Guide Release 46.6 E93319 Revision 1 |
![]() Previous |
![]() Next |
This procedure is used to change the characteristics of a user on the EAGLE using the chg-user command. This procedure can only be performed if you have been assigned the command class “Security Administration.” If the user ID does not exist in the database, the user’s characteristics cannot be changed.
Thepid parameter can be specified for this procedure on all terminals (1 - 40) if the Eagle OA&M IP Security Enhancements feature is on. If this feature is on, the entry YES is shown for terminals 17 through 40 in the SECURE column in the rtrv-trm output. The output of the rtrv-ctrl-feat command also shows if this feature is on or off. If this feature is off, the pid parameter can be specified for this procedure only on terminals 1 through 16. If you wish to use the Eagle OA&M IP Security Enhancements feature, and the feature is not on, performActivating the EAGLE OA&M IP Security Enhancement Controlled Feature to enable and activate this feature.The chg-user command uses these parameters.
:uid – The ID of a user in the database
:nuid – New user ID – The new ID of the user specified by the uid parameter.
:pid – Password ID (only required if changing the password of a user) – The password of the user specified by the uid parameter.
:all – The user has access to all commands in all command classes.
:dbg – The user has access to all commands in the command class “Debug.”
:link – The user has access to all commands in the command class “Link Maintenance.”
:sys – The user has access to all commands in the command class “System Maintenance.”
:sa – The user has access to all commands in the command class “Security Administration.”
:pu – The user has access to all commands in the command class “Program Update.”
:db – The user has access to all commands in the command class “Database Administration.”
:cc1 - :cc8 – Eight configurable command classes. These parameters specified whether or not the user has access to the commands in the specified configurable command class. The value of these parameters consist of the configurable command class name (1 alphabetic character followed by 2 alphanumeric characters), and either yes or no. The command class name and the yes or no values are separated by a dash. For example, to assign a user the permission to use the commands in configurable command class db1, the cc1=db1-yes parameter would be specified.
To specify any configurable command classes, the Command Class Management feature must be enabled and turned on. Enter the rtrv-ctrl-feat command to verify whether or not the Command Class Management feature is enabled. If the Command Class Management feature is not enabled or turned on, perform Activating Controlled Features to enable and turn on the Command Class Management feature. Up to 32 configurable command classes can be assigned to users. When the Command Class Management feature is enabled and turned on, the configurable command class names are given the names u01 - u32. These command class names, the descriptions of these command classes, and the commands assigned to these command classes can be changed using the Configuring Command Classes.
The chg-user command can assign a maximum of eight configurable command classes to the user each time the chg-user command is performed.
:page – The amount of time, in days, that the specified user’s password can be used before the user must change their password.
If the page parameter is not specified with the ent-user command, the EAGLE uses the value configured for the page parameter specified by the chg-secu-dflt command to determine the age of the user’s password.
:uout – The number of consecutive days that a user ID can remain active on the EAGLE and not be used. When the user ID has not been used for the number of days specified by the uout parameter, that user ID is no longer valid and the EAGLE rejects any attempt to log into the EAGLE with that user ID.
If the uout parameter is not specified with the ent-user command, the EAGLE uses the value configured for the uout parameter specified by the chg-secu-dflt command to determine the number of consecutive days that a user ID can remain active on the EAGLE and not be used
:revoke – Is the specified user ID in service? Any login attempts using a revoked user ID are rejected by the EAGLE. The revoke=yes parameter cannot be specified for a user ID assigned to the security administration command class.
:rstlsl – resets the last successful login date for a user ID to the current date. If the user ID is out of service because the user ID has been idle longer that the value of the uout parameter defined by either the ent-user or chg-secu-dflt commands, this parameter brings that user ID back into service.
This example shows an rtrv-secu-user command output when the Command Class Management feature is enabled and turned on. If the Command Class Management feature is not enabled and activated, the 32 configurable command classes, shown in the following example as fields U01 - U32, are not shown in the rtrv-secu-user command output.
An asterisk (*) displayed after the value in the PAGE or UOUT fields indicates that the system-wide default page or uout parameter values, as configured on the chg-secu-dflt command, is in effect for the user ID.
rlghncxa03w 09-03-01 08:33:48 GMT EAGLE5 40.1.0
USER ID AGE PAGE UOUT REV LINK SA SYS PU DB DBG
frodo 750 0 0 NO YES YES YES YES YES YES
U01 U02 U03 U04 U05 U06 U07 U08 U09 U10 U11 U12 U13 U14 U15 U16
YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES NO
U17 U18 U19 U20 U21 U22 U23 U24 U25 U26 U27 U28 U29 U30 U31 U32
YES YES YES YES YES YES YES YES YES YES YES NO NO NO NO YES
manny 36 60 60 NO YES YES YES YES YES YES
NO NO NO NO YES YES YES YES YES YES YES YES YES YES YES YES
moe 100 30 60 YES YES YES YES YES YES YES
YES YES YES YES YES YES YES YES YES YES YES YES YES NO NO NO
jack 10 30 * 30 * NO YES YES YES YES YES YES
YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES
YES YES YES YES YES YES NO NO NO NO YES YES YES YES YES NO
Figure 4-8 Changing User Information
Sheet 1 of 3
Sheet 2 of 3
Sheet 3 of 3
