| Oracle® Communications EAGLE Database Administration - System Management User's Guide Release 46.6 E93319 Revision 1 |
![]() Previous |
![]() Next |
This procedure is used to update the following GPLs: SS7IPGW, IPGWI, SLANHC, SS7HC, SS7EPM, IPLHC, IPGHC, ATMHC, and IPSG. These names are used as the value of the gpl parameter of the chg-gpl, act-gpl, rept-stat-gpl, and rtrv-gpl commands.
Signaling links are assigned to cards running the following GPLs: SS7IPGW, IPGWI, SS7HC, SS7EPM, IPLHC, IPGHC, ATMHC, and IPSG. The signaling link GPLs are assigned to the card types shown in Table 3-1.
Table 3-1 SS7 LIM Card Types
| GPL | Card Type |
| atmansi, atmhc |
limatm (cards running the atmhc GPL must be E5-ATM cards) |
| atmitu, atmhc |
lime1atm (cards running the atmhc GPL must be E5-ATM cards) |
| ss7ipgw, ipgwi, iplhc, ipghc, ipsg |
dcm (cards running the iplhc, ipghc, or ipsg GPLs must be E5-ENET cards) |
| ss7hc |
lime1, limt1 (these cards can be HC MIMs or E5-E1T1 cards) |
Data links are assigned to cards running the SLANHC GPLs. The data link GPLs are assigned to the card types shown in Table 3-2.
Table 3-2 Data Link Card Types
| GPL | Card Type |
| slanhc | dcm (these cards must be E5-ENET, E5-ENET-B, or SLIC cards) |
The card types shown in Table 3-1 and Table 3-2 are the values used for the type parameter of the ent-card command.
The cards running the SS7HC GPL are E5-E1T1-B cards. E5-E1T1-B cards are single-slot cards that can support up to 32 signaling links. These cards are either LIM-E1 or LIM-T1 cards. The rtrv-card output shows these cards running either the SS7ANSI or CCS7ITU applications, but the rept-stat-card and rept-stat-gpl output shows that these cards are actually running the SS7HC GPL.
The cards running the SS7EPM GPL are E5-E1T1 cards which are single-slot cards that can support up to 32 signaling links. The E5-E1T1 cards are either LIM-E1 or LIM-T1 cards. The rtrv-card output shows these cards running either the SS7ANSI or CCS7ITU applications, but the rept-stat-card and rept-stat-gpl output shows that these cards are actually running the SS7EPM GPL.
The cards running the IPLHC and IPGHC GPLs are E5-ENET, E5-ENET-B and SLIC cards supporting IP signaling links. The rtrv-card output shows this card running either the IPLIM or IPLIMI applications, but the rept-stat-card and rept-stat-gpl output shows that these cards are actually running the IPLHC GPL. The IPGHC GPL allows the E5-ENET card to support SS7IPGW (ANSI IP Gateway) or IPGWI (ITU IP Gateway) signaling links. The rtrv-card output shows this card running either the SS7IPGW or IPGWI applications, but the rept-stat-card and rept-stat-gpl output shows that these cards are actually running the IPGHC GPL.
The cards running the ATMHC GPL are cards that can contain the ATM high-speed signaling links on E5-ATM cards. The rtrv-card output shows these cards running either the ATMANSI or ATMITU applications, but the rept-stat-card and rept-stat-gpl output shows that these cards are actually running the ATMHC GPL.
The cards running the SLANHC GPLs are the STPLAN cards supporting the STPLAN feature. E5-SLAN cards run the SLANHC GPL. The rtrv-card output shows these cards running the STPLAN application, but the rept-stat-card and rept-stat-gpl output shows that these cards are actually running the SLANHC GPLs.
If the GPL is being updated to a new version, a removable media containing the GPL being updated is required.
If any card is not running the version of the GPL shown in the RELEASE column of the rtrv-gpl output, the indicator ALM is displayed next to the GPL version in the RUNNING column of the rept-stat-gpl output, and next to the GPL version in the APPROVED column in the rtrv-gpl output.
Canceling the REPT-STAT-SLK and RTRV-SLK Commands
Because the rept-stat-slk and rtrv-slk commands used in this procedure can output information for a long period of time, the rept-stat-slk and rtrv-slk commands can be canceled and the output to the terminal stopped. There are three ways that the rept-stat-slk and rtrv-slk commands can be canceled.
F9 function key on the keyboard at the terminal where the rept-stat-slk or rtrv-slk commands command were entered.canc-cmd without the trm parameter at the terminal where the rept-stat-slk or rtrv-slk commands were entered.canc-cmd:trm=<xx>, where <xx> is the terminal where the rept-stat-slk or rtrv-slk commands were entered, from another terminal other that the terminal where the rept-stat-slk or rtrv-slk commands were entered. To enter the canc-cmd:trm=<xx> command, the terminal must allow Security Administration commands to be entered from it and the user must be allowed to enter Security Administration commands. The terminal’s permissions can be verified with the rtrv-secu-trm command. The user’s permissions can be verified with the rtrv-user or rtrv-secu-user commands.For more information about the canc-cmd command, go to Commands User's Guide.
Figure 3-2 Updating the Signaling Link and Data Link GPLs
Sheet 1 of 5
Sheet 2 of 5
Sheet 3 of 5
Sheet 4 of 5
Sheet 5 of 5
