| Oracle® Communications EAGLE Database Administration - System Management User's Guide Release 46.6 E93319 Revision 1 |
![]() Previous |
![]() Next |
This procedure updates the BLMCAP and OAMHC GPLs on the E5-MCAP cards in card locations 1113 and 1115 as a trial version from the removable media, then making the trial version of these GPLs the approved version of these GPLs. The E5-MCAP card in card locations 1113 and 1115 is used in combination with the TDM to form the Maintenance and Administration Subsystem Processor (MASP).
chg-gpl,
act-gpl, and
flash-card commands.
Caution:
Theflash-card command cannot be entered
if the IMT Rate Change sequence or the Extended Bit Error
Rate Test (BERT) is being performed.
The OAMHC GPL is updated using the
chg-gpl command.
Caution:
This procedure can be performed only on EAGLEs that contain E5-based control cards. Refer to Maintenance and Administration Subsystem for more information about the control cards.If any card is not running the version of the
GPL shown in the
RELEASE column of the
rtrv-gpl output, the indicator
ALM is displayed next to the
GPL version in the
RUNNING column of the
rept-stat-gpl output, and next to the
GPL version in the
APPROVED column in the
rtrv-gpl output.
Removable media containing the BLMCAP and OAMHC GPLs that are being updated is required.
Refer to Maintenance and Administration Subsystem for information about the control cards.
If E5-based control cards are installed in the EAGLE, continue the procedure with 2.
rept-stat-db command.
This is an example of the possible output.
eagle1 16-09-09 17:51:57 MST EAGLE 46.4.0.0.0-69.6.0
DATABASE STATUS: >> OK <<
TDM 1114 ( STDBY) TDM 1116 ( ACTV )
C LEVEL TIME LAST BACKUP C LEVEL TIME LAST BACKUP
FD BKUP Y 1 - - Y 1 - -
FD CRNT Y 93 Y 93
MCAP 1113 MCAP 1115
RD BKUP - - - - Y 1 - -
USB BKP - - - - - - - -
If removable media is installed in the active MASP, continue the procedure with 4.
If removable media is not installed in the active MASP, insert the removable media in the removable media drive in the active MASP. For more information about inserting removable media in the removable media drive, refer to Removable USB Drive. After the removable media has been inserted in the removable media drive in the active MASP, continue the procedure with 4.
rtrv-gpl command with the
gpl parameter value equal to the
GPL being updated.
Perform these substeps.
rtrv-gpl:gpl=blmcap
eagle1 16-09-09 18:28:48 MST EAGLE 46.4.0.0.0-69.6.0
GPL Auditing ON
GPL CARD RELEASE APPROVED TRIAL REMOVE TRIAL
BLMCAP 1114 139-005-000 139-005-000 139-005-000 -----------
BLMCAP 1116 139-005-000 139-005-000 139-005-000 139-008-000
BLMCAP 1115 ----------- ----------- ----------- -----------
rtrv-gpl:gpl=oamhc
eagle1 16-09-09 18:30:03 MST EAGLE 46.4.0.0.0-69.6.0
GPL Auditing ON
OAMHC 1114 139-006-000 139-006-000 ----------- -----------
OAMHC 1116 139-006-000 139-006-000 139-008-000 139-008-000
OAMHC 1115 ----------- ----------- ----------- -----------
If the version of either
GPL shown in the
REMOVE TRIAL column of the
rtrv-gpl output is not the version
that is to be loaded onto the cards, remove the removable media from the active
MASP.
Insert the removable media that contains the GPLs that are being updated into the removable media drive in the active MASP. If 3 was performed, repeat this step. If 3 was not performed, repeat this procedure from 3.
For more information about inserting removable media in the removable media drive, or removing removable media from the removable media drive, refer to Removable USB Drive.
If the versions of the GPLs shown in the
rtrv-gpl output are the versions
that are to be loaded onto the cards, continue the procedure with
5.
chg-gpl command and specifying the
value for the trial BLMCAP and OAMHC GPLs shown in the
REMOVE TRIAL column in the output of
the
rtrv-gpl command (in
4).
chg-gpl:gpl=blmcap:ver=139-008-000
These messages should appear.
eagle1 16-09-09 18:47:55 MST EAGLE 46.4.0.0.0-69.6.0
BLMCAP upload to 1116 completed
BLMCAP upload to 1114 completed
System Release ID table upload to 1116 completed
System Release ID table upload to 1114 completed
chg-gpl:gpl=oamhc:ver=139-008-000
eagle1 16-09-09 18:48:30 MST EAGLE 46.4.0.0.0-69.6.0
OAMHC upload to 1116 completed
OAMHC upload to 1114 completed
act-gpl command and specifying the
name and version of the trial BLMCAP
GPL specified in
Substep a in
5.
Enter this command.
act-gpl:gpl=blmcap:ver=139-008-000
eagle1 16-09-09 18:48:53 MST EAGLE 46.4.0.0.0-69.8.0
BLMCAP activate on 1116 completed
BLMCAP activate on 1114 completed
rtrv-gpl command. Perform these
substeps.
rtrv-gpl:gpl=blmcap command.
eagle1 16-09-09 18:49:10 MST EAGLE 46.4.0.0.0-69.8.0
GPL Auditing ON
BLMCAP 1114 139-008-000 139-008-000 139-005-000 -----------
BLMCAP 1116 139-008-000 139-008-000 139-005-000 139-008-000
rtrv-gpl:gpl=oamhc command.
eagle1 16-09-09 18:49:10 MST EAGLE 46.4.0.0.0-69.8.0 GPL Auditing ON GPL CARD RELEASE APPROVED TRIAL REMOVE TRIAL OAMHC 1114 139-008-000 139-008-000 139-005-000 139-008-000 OAMHC 1116 139-008-000 139-008-000 139-005-000 139-008-000 OAMHC 1115 ----------- ----------- ----------- -----------
rept-stat-gpl:gpl=blmcap
command.
eagle1 16-09-09 18:49:10 MST EAGLE 46.4.0.0.0-69.8.0 GPL Auditing ON GPL CARD RUNNING APPROVED TRIAL BLMCAP 1113 139-005-000 ALM 139-008-000 139-005-000 BLMCAP 1115 139-005-000 ALM 139-008-000 139-005-000 Command Completed
The
flash-card command will load
only the BLMCAP GPLs whose approved versions are different from the versions
that the card is running. The version of the BLMCAP GPL that the card is
running is shown in the
RUNNING column in the
rept-stat-gpl output. The
approved version of the BLMCAP GPL is shown in the
APPROVED column of the
rept-stat-gpl output. If the
running and approved versions of a BLMCAP GPL are the same, the
flash-card command will not
load that BLMCAP GPL.
rept-stat-gpl:gpl=oamhc command.
eagle1 16-09-09 18:49:10 MST EAGLE 46.4.0.0.0-69.8.0 GPL CARD RUNNING APPROVED TRIAL OAMHC 1113 139-005-000 ALM 139-008-000 139-005-000 OAMHC 1115 139-005-000 ALM 139-008-000 139-005-000 Command Completed
rtrv-trm command.
All the SEAS terminals must be placed out of service
in order to load the BLMCAP and OAMHC GPLs onto the E5-MCAP cards. The SEAS
terminals are shown in the output with the entry
SEAS in the
TYPE field. This is an example of
the possible output. In this example, the SEAS terminals are terminals 18 and
27.
eagle1 16-09-09 18:49:10 MST EAGLE 46.4.0.0.0-69.8.0 TRM TYPE COMM FC TMOUT MXINV DURAL 1 VT320 9600-7-E-1 SW 30 5 99:59:59 2 KSR 9600-7-E-1 HW 30 5 INDEF 3 PRINTER 4800-7-E-1 HW 30 0 00:00:00 4 VT320 2400-7-E-1 BOTH 30 5 00:30:00 5 VT320 9600-7-O-1 NONE 30 5 00:00:30 6 VT320 9600-7-O-1 NONE 30 5 00:00:30 7 PRINTER 9600-7-N-2 HW 30 5 00:30:00 8 KSR 19200-7-E-2 BOTH 30 5 00:30:00 9 VT320 9600-7-O-1 NONE 30 5 00:00:30 10 VT320 9600-7-E-1 HW 30 5 00:30:00 11 VT320 4800-7-E-1 HW 30 5 00:30:00 12 PRINTER 9600-7-E-1 HW 30 4 00:30:00 13 VT320 9600-7-O-1 NONE 30 5 00:30:00 14 VT320 9600-7-E-2 SW 30 8 00:30:00 15 VT320 9600-7-N-2 HW 30 5 00:30:00 16 VT320 9600-7-E-2 BOTH 30 3 00:30:00 TRM TYPE LOC TMOUT MXINV DURAL 17 TELNET 1303 60 5 00:30:00 18 SEAS 1201 60 5 00:30:00 19 TELNET 1303 60 5 00:30:00 20 TELNET 1303 60 5 00:30:00 21 TELNET 1303 60 5 00:30:00 22 TELNET 1303 60 5 00:30:00 23 TELNET 1303 60 5 00:30:00 24 TELNET 1303 60 5 00:30:00 25 TELNET 1203 60 5 00:30:00 26 TELNET 1203 60 5 00:30:00 27 SEAS 1203 60 5 00:30:00 28 TELNET 1203 60 5 00:30:00 39 TELNET 1203 60 5 00:30:00 30 TELNET 1203 60 5 00:30:00 31 TELNET 1203 60 5 00:30:00 32 TELNET 1203 60 5 00:30:00 33 TELNET 1208 60 5 00:30:00 34 TELNET 1208 60 5 00:30:00 35 TELNET 1208 60 5 00:30:00 36 TELNET 1208 60 5 00:30:00 37 TELNET 1208 60 5 00:30:00 38 TELNET 1208 60 5 00:30:00 39 TELNET 1208 60 5 00:30:00 40 TELNET 1208 60 5 00:30:00
Thertrv-trm command output contains
other fields that are not used by this procedure. If you wish to see all the
fields displayed by the
rtrv-trm command, see the
rtrv-trm command description in
Commands User's Guide.
If SEAS terminals are shown in the
rtrv-trm command output, continue
the procedure with
10.
rept-stat-trm command with the
terminal number of the SEAS terminals.
For this example, enter these commands.
rept-stat-trm:trm=18
eagle1 16-09-09 18:49:10 MST EAGLE 46.4.0.0.0-69.8.0 TRM PST SST AST 18 IS-NR Active ----- Command Completed.
rept-stat-trm:trm=27
eagle1 16-09-09 18:49:10 MST EAGLE 46.4.0.0.0-69.8.0 TRM PST SST AST 27 IS-NR Active ----- Command Completed.
rmv-trm command with the number of
the terminal displayed in
10
whose state is not OOS-MT-DSBLD.
The
force=yes parameter must be used
when placing the last SEAS terminal out of service. For this example, enter
these commands.
rmv-trm:trm=18
rmv-trm:trm=27:force=yes
If the status of the SEAS terminals shown in the
PST field in
10
is
OOS-MT-DSBLD (out-of-service maintenance disabled), the terminal
is already out of service and the
rmv-trm command does not need to
be executed for that terminal.
This message should appear when each of these commands have successfully completed.
eagle1 16-09-09 18:49:10 MST EAGLE 46.4.0.0.0-69.8.0 Inhibit message sent to terminal eagle1 16-09-09 18:49:10 MST EAGLE 46.4.0.0.0-69.8.0 Command Completed.
chg-trm command, the
type=none parameter, and with the
values of the SEAS terminals used in
11.
chg-trm:trm=18:type=none
chg-trm:trm=27:type=none
This message should appear when these commands have successfully completed.
eagle1 16-09-09 18:49:10 MST EAGLE 46.4.0.0.0-69.8.0 CHG-TRM: MASP B - COMPLTD
To determine which
MASP is active,
enter the
rept-stat-db command. This is an
E5TDM 1114 ( STDBY) E5TDM 1116 ( ACTV )
FD BKUP Y 36 09-02-19 09:38:25 GMT Y 36 09-02-19 09:38:25 GMT
FD CRNT Y 39 Y 39
E5MCAP 1113 E5MCAP 1115
RD BKUP - - - - Y 36 09-02-19 09:27:17 GMT
USB BKP - - - - Y 3 09-02-07 01:11:22 GMT
The output of the
rept-stat-db command shows which
MASP is active with
the indicator
( ACTV ) following the
TDM card location.
The indicator
( STDBY) following the
TDM card location
shows which
MASP is standby.
For this example, the MASP associated with TDM 1116 is active and the MASP associated with TDM 1114 is standby.
rmv-card command.
For this example, enter this command.
rmv-card:loc=1113
When this command has successfully completed, this message should appear.
eagle1 16-09-09 18:49:10 MST EAGLE 46.4.0.0.0-69.8.0 Card has been inhibited.
flash-card command with the
code=appr parameter.
Caution:
entered if the IMT Rate Change sequence or the Extended Bit
Error Rate Test (BERT) is being performed.
The
flash-card command will load only
those BLMCAP
different from the versions that the card is running. The version of the BLMCAP
rept-stat-gpl output. The approved
GPL is shown in the
running and approved versions of an BLMCAP
GPL are the same,
the
flash-card command will not load
that BLMCAP
GPL.
flash-card:code=appr:loc=1113
When this command has successfully completed, these messages should appear.
Flash Card: FLASH GPL(s) required to be downloaded on card 1113
BLMCAP : Running version 134-015-000 Expected version 134-016-000
Flash Card: Downloading BLMCAP on card 1113
Flash Card: Card(s) will reset after the flash GPL download.
Flash Card: Card 1113 download BLMCAP complete.
Flash Card: FLASH GPL(s) required to be activated on card 1113
BLMCAP : Running inactive version 134-016-000
Flash Card: Activating BLMCAP on card 1113
Flash Card: Card 1113 activation BLMCAP complete.
Command Completed.
The E5-MCAP card specified in the
flash-card command will be
re-initialized when the BLMCAP
GPL download is
complete.
rst-card command.
The
rst-card command also loads the
approved version of the BLMCAP and OAMHC GPLs onto the card.
rst-card:loc=1113
eagle1 16-09-09 18:49:10 MST EAGLE 46.4.0.0.0-69.8.0 Card has been allowed.
rept-stat-card command.
rept-stat-card:loc=1113
eagle1 16-09-09 18:49:10 MST EAGLE 46.4.0.0.0-69.8.0 CARD VERSION TYPE GPL PST SST AST 1113 139-008-000 E5MCAP OAMHC IS-NR Active ----- ALARM STATUS = No Alarms. BLMCAP GPL version = 139-008-000 IMT BUS A = Conn IMT BUS B = Conn CURRENT TEMPERATURE = 30C ( 86F) PEAK TEMPERATURE: = 33C ( 92F) [02-01-05 07:18] Command Completed.
If the versions of the BLMCAP or OAMHC GPLs shown in therept-stat-card command output are
not the versions specified in
6,
contact the Customer Care Center. Refer to
My Oracle Support (MOS)
for the contact information. The reminder of this procedure should not be
performed.
init-card command specifying the
location of the
E5-MCAP card making up
active
MASP. For this
example, enter the
init-card:loc=1115 command. This
eagle1 16-09-09 18:49:10 MST EAGLE 46.4.0.0.0-69.8.0 Init Card command issued to card 1115
After this step has been performed, repeat steps
14,
15,
16,
and
17
using the card location specified in this step as the
loc parameter value in these
steps. After these steps have been performed, continue the procedure with
either
19
or
21
based on the following conditions:
NONE in
12
to the terminal type
SEAS with the
chg-trm command and the
type=seas parameter.
The terminal type is shown in the
TYPE field in the
rtrv-trm command output in
9.
chg-trm:trm=18:type=seas
chg-trm:trm=27:type=seas
rst-trm command with the number of
the terminals specified in
19.
rst-trm:trm=18
rst-trm:trm=27
eagle1 16-09-09 18:49:10 MST EAGLE 46.4.0.0.0-69.8.0 Allow message sent to terminal eagle1 16-09-09 18:49:10 MST EAGLE 46.4.0.0.0-69.8.0 Command Completed.
Figure 3-1 Updating the BLMCAP and OAMHC GPLs
Sheet 1 of 3
Sheet 2 of 3
Sheet 3 of 3
