Update the Configuration Schema
You can update the configuration parameters in your software with any new parameters included in a subsequent release by updating the schema.
Updating the schema adds any new parameters to each configuration screen.
After you update the software to a subsequent release, the system displays a schema update prompt after first log on to the GUI. If you click Cancel, the system bypasses the update and adds no new parameters. The system displays the update prompt each time you log on to the Web GUI, until you choose to update the configuration schema.
