9Running the Database Configuration Wizard to Perform Upgrade Tasks
This chapter describes how to run the Database Configuration Wizard to perform the midtier tasks for an upgrade. Also review the topics in the chapter in Siebel Database Upgrade Guide that describes how to upgrade the Siebel database, and perform any applicable topics before starting your upgrade.
Refer to the roadmap for your upgrade in How to Perform a Siebel Database Upgrade for a complete list of all the tasks you must perform to upgrade to the current release of Siebel CRM. This chapter contains the following topics:
Example of a Siebel Development Environment Upgrade Flow
This topic presents the flow of steps in part of a typical development environment upgrade. The steps are extracted from an actual driver file. To perform an upgrade, the Upgrade Wizard reads the steps in a driver file and performs the commands the steps contain. The driver file type used in this example is as follows:
Upgrade: Siebel 15.0 to Siebel 17.0
Environment: Development
Upgrade mode: upgrep
Multilingual: No
Upgrading the Siebel Database Schema (upgrep) is a two-step process, where you select each of the following upgrade processes in turn:
zSeries Staging of Files for Upgrade:
master_upgrep_dev_150_mf_m.ucfzSeries Seed/Repository Upgrade:
master_upgrep_dev_150_mf.ucf
The following table lists the steps in the driver file for zSeries Staging of Files for Upgrade.
Table Example of Steps in a Development Environment Upgrep Staging of Files
| Step | Script or Input File | Description |
1. Generate the DDL file for the staging database. |
strgupgd |
Generates the DDL file for the staging database. |
2. Copy files into the output directory. |
strgupgd |
Runs the extract and merge process to create the storage control file. The database administrator must perform operations using the files in the $GenDDLDirectory directory. Once the operations are completed, resume the Upgrade Wizard operations by submitting the following command line on the midtier computer: $GenDDLDirectory\upg_restart |
3. Restart the midtier file generation process. |
strgupgd |
Restarts the midtier file generation process for the upgrade. If all necessary mainframe tasks completed successfully, click YES to continue, otherwise click NO to terminate this process. If you choose NO, you can resume Upgrade Wizard operations by submitting the following command line on the midtier computer: $GenDDLDirectory\upg_restart |
4. Generate the DDL for the additive schema changes. |
Ddlimp2 |
For the DB2390 staging database, run the ddlimp file to generate the schema.additive.sql file. |
5. Copy files into the output directory. |
strgupgd |
Generates a set of files in the $GenDDLDirectory directory. The database administrator must transfer these files from the $GenDDLDirectory directory to the mainframe using the ftp_pause1.txt and perform all required tasks on the DB2 host commands. Once completed, you can resume Upgrade Wizard operations by submitting the following command line on the midtier computer: $GenDDLDirectory\upg_restart |
6. Restart the midtier file generation process. |
strgupgd |
7. Generate the DDL for temporary tables. |
ddlimp |
Creates the temporary tables for the z/OS upgrade. |
8. Generate the DDL for Siebel tables. |
ddlimp |
Creates the schema for the z/OS upgrade. |
9. Copy files into the output directory. |
strgupgd |
Generates a set of files in the $GenDDLDirectory directory. The database administrator must transfer these files from the $GenDDLDirectory directory to the mainframe using the ftp_pause2.txt and perform all required tasks on the DB2 host commands. Once completed, you can resume Upgrade Wizard operations by submitting the following command line on the midtier computer: $GenDDLDirectory\upg_restart |
10. Restart the midtier file generation process. |
strgupgd |
11. Generate the DDL for Siebel indexes. |
ddlimp |
Creates the indexes for DB390 development upgrade. |
12. Copy files into the output directory. |
strgupgd |
Generates a set of files in the $GenDDLDirectory directory. The database administrator must transfer these files from the $GenDDLDirectory directory to the mainframe using the ftp_pause3.txt and perform all required tasks on the DB2 host commands. |
The following table lists the steps in the driver file. The Script or Input File column in the table lists the SQL file or input file that is executed in each step. The Comment column provides a brief explanation of what the SQL file or input file does.
Table Example of Steps in a Development Environment Upgrep Seed Repository
| Step | Script or Input File | Comment |
Verify repository name |
rename_existing_repositories.sql |
Renames Siebel Repository to Prior Customer Repository. |
Preparation of prior customer repository |
The SWT to OD Conversion Utility converts Siebel Web Templates to an Object Definition Layout. Converted Web templates are stored in the database. The Repository Sanitization Utility searches the entire repository for unreferenced repository objects. Unreferenced repository objects are deactivated if they are not used by any application. |
Import Siebel seed data |
Prior to importing seed data, dataimp deletes existing seed data. The seedupg* files contain filters that dataimp uses to prevent deleting seed data that you have modified or seed data meeting specified criteria. Unmodified seed data has a last update date (LAST_UPD) of 1980-01-01. Dataimp does not delete records where LAST_UPD is later than this date. |
Upgrade data after seed data import |
upg_data_afterseed.sql |
For customers who have not converted to UTC time, sets the UTC value in S_SYS_PREF to False. For customers who have converted to UTC time, the script takes no action. |
Upgrade data after seed data import SIA |
upg_data_afterseed_sia.sql |
Set system preference for codepage for DB |
set_codepage.sql |
Sets the database codepage in the S_SYS_PREF. |
Update version component information |
upd_upgcomp.sql |
Updates the S_UPG_COMP table with the product release level. The S_UPG_COMP table stores version information for application executable programs. |
Encryption Upgrade |
Siebel Business Applications allow customers to encrypt sensitive information stored in the Siebel database, for example, credit card numbers, Social Security numbers, birth dates. This information cannot be viewed without access to Siebel Business Applications. Sensitive data can be encrypted by using AES (Advanced Encryption Standard). This utility identifies the RC2 encrypted columns and upgrades their data to the AES. This utility updates the logical layer of data for columns which are candidates for encryption. |
Export prior customer repository |
repimexp utility |
Exports the existing prior customer repository to create the new customer repository. |
Import Prior Siebel, New Siebel, and New Customer repositories |
repimexp utility |
Imports the prior Siebel repository, new Siebel repository, and the new customer repository in parallel to the repository tables. |
Install SQL packages |
seeduver.sql |
Verifies that versions are set correctly in S_APP_VER. |
ifstrg.sql |
Sets storage parameters for Siebel Enterprise Integration Manager tables. |
ifindxstrg.sql |
Sets storage parameters for Siebel Enterprise Integration Manager table indexes. |
pkgseq.sql |
Adds a suffix to row IDs in the S_SEQUENCE table. Ensures that row IDs are unique. |
pkgldel.sql |
Defines s_txn_log_del_proc. Procedure periodically deletes transactions from S_DOCK_TXN_LOG. Also deletes rows from S_DOCK_TXN SET. Prevents need for large rollback segment. |
trgreset.sql |
Ensures that denormalized rows in S_TERR have correct values. |
ddlseq.sql |
Sets sequence numbers for specified tables. |
pkgvis.sql |
Creates function that modifies how Oracle optimizer does visibility check. |
Fix column alignment for custom objects |
AlignApplet.jar |
Applet alignments are executed based on the data type of the field. Alignments, which can be one of the following, are executed across the entire Repository for a similar look and feel of fields:
Create temporary indexes for merge performance |
crt_temp_indexes_merge.sql |
Creates temporary indexes to improve the merge performance. |
Take backup of DB and update DB stats |
None |
Pauses the Siebel Upgrade Wizard to enable a database backup and the execution of database statistics before the merge. |
Execute Incremental Repository Merge |
siebdev |
Starts the incremental repository merge automatically for Windows. If you are using a Windows computer and Siebel Tools is installed for Siebel Enterprise servers in UNIX environment, then you must perform this step manually. |
Generate Merge Report |
MergeReport.jar |
Generates the hierarchical merge report in HTML format. Also creates the file IRM_Merge*_ERROR.txt in |
Export merge data to CSV |
ExportMrgCSV.jar |
Exports repository-merge log data to a CSV file for business object, business component, applet, view, and Web page object definitions. This data can be compared with the Usage Pattern Tracking (UPT) CSV files to obtain the intersection data, so that you can focus testing on these objects only. The Siebel Upgrade Wizard exports the log data to CSV files in the following folder:
Record Upgrade History |
store_history.sql |
Stores the upgrade history in the S_INST_UPG_HIST table. |
The following table shows the different steps executed by the upgphys process. The Script or Input File column in the table lists the SQL file or input file that is executed in each step. The Description column provides a brief explanation of what the SQL file or input file does.
Table Steps That the upgphys Process Executes
1. Check whether the merge and conflict resolution steps are complete |
verify_irm.sql |
Verifies whether the merge and conflict resolution steps are complete. |
2. Drop temporary indexes created for merge performance |
drop_temp_indexes_merge.sql |
Removes all the temporary indexes created to improve the merge performance. |
3. Export schema definition |
None |
Exports the schema definition to the file DBSRVR_ROOT |
4. Generate files to synchronize the physical and logical schema |
schema.ddl |
Applies the schema.ddl and synchronizes the tables and indexes. |
5. Migrate query search controls of list applets into the Siebel database |
SrchCntrlMigration.jar |
This step migrates query search controls of list applets from files into the Siebel database. This step also exports the entire New Customer Repository to:
6. Enable workspace |
EnableWorkspace.exe |
Enables the workspace on the New Customer Repository for repository content. |
7. Encryption Upgrade - Physical |
EncryptionUpgrade.jar |
This step updates the physical layer data for columns which are encrypted with the RC2 algorithm. This updates the data to AES algorithm. |
8. Export repository to a file |
None |
Exports the New Customer Repository to:
This file contains only the required repository data and is used as an input to the production test and production environments. This step also creates a custrep_dev.dat file which contains the entire New Customer Repository as a backup. |
9. Import New Customer Repository as Siebel Repository |
custrep_dev.dat |
Truncates the repository tables and imports the previously exported New Customer Repository as Siebel Repository. |
10. Enable Workspace for Seed data |
Enables the workspace on the New Customer Repository for Seed data (List of Values). |
11. Copy files to the output directory. |
None |
Copies files to the output directory. |
12. Verify repository after upgrade |
The repository is optionally verified after you complete the upgphys process. This step is executed if you selected the option Verify Repository After Upgrade in the Database Configuration Wizard. |
13. Upgrade history |
store_history.sql |
Information Required by the Database Configuration Wizard
Upgrades: All upgrades.
Environments: All environments.
This topic is part of an upgrade process. See How to Perform a Siebel Database Upgrade.
Use this topic to identify the information you must enter when running the Database Configuration Wizard. Make sure you have prepared your upgrade environment, and have collected and verified this information before running the wizard.
The Database Configuration Wizard requests information about the upgrade process you want to perform. It then adds this information to a master upgrade file. The Siebel Upgrade Wizard runs after the Database Configuration Wizard exits. The wizard generates the upgrade SQL files and executes some of the SQL files against the Siebel database. For more information on the Database Configuration Wizard, see About the Siebel Database Configuration Utilities and Database Configuration Wizard.
The following table lists the information that you must enter in the Database Configuration Wizard when performing the upgrade processes. The table on the following page lists additional information the utility requires when you perform a production environment upgrade.
Table Information Required for the Database Configuration Wizard Upgrade Database Option
| Field Name or Menu | Required Information |
Siebel Server Directory |
The absolute path of the directory where the Siebel Server is installed. For UNIX, do not enter the string |
Siebel Database Server Directory |
The absolute path of the directory where the Siebel Database Configuration Utilities are installed, for example |
RDBMS Platform |
Choose IBM DB2 UDB for z/OS. |
Siebel Database Operation |
Choose Upgrade Database. The other menu choices are for database installation and administration. |
Environment Type |
Upgrade Options |
Choose one of the following options:
Upgrade Process |
If you chose the Upgrade Siebel Database Schema option for either a production or development environment, select one of the following:
Siebel Industry Application |
Choose the application you are upgrading from. If you have upgraded to the base Siebel Business Applications as part of upgrading to the new Siebel Industry Applications release, choose Siebel Horizontal Application. |
Current Siebel Version |
Choose the application version you are upgrading from. If you are upgrading within the same Siebel release, choose the application version you are upgrading from based on the following criteria:
If you are currently on Siebel CRM version 8.1.1.11 (SIA) and are migrating to Siebel 2018 or later. |
Siebel Tools Installation Directory Siebel Tools Data Source (Specify both values for Incremental Repository Merge on Windows) |
Database Encoding |
Indicate whether your database uses an ASCII or EBCDIC code page. |
Host/LPAR name where Target database resides DB2 Subsystem name of Target database. |
Schema/Tableowner qualifier name on Target database |
Enter the up to eight-character identifier that designates the Siebel schema for your target database. This is also an authorization ID. The schema qualifier must start with a letter, cannot contain special characters, and must be entered in uppercase. The target database tableowner name can be the same or different to the staging database tableowner name. |
ODBC Data Source Name of Target database |
Verify the ODBC name for connecting to the target Siebel database. The default value of the target database ODBC DSN is the DB2 subsystem name. When you set up the ODBC connection in DB2 Connect, you can use the actual subsystem name for the database alias.
Note: To find the name of your ODBC data source, navigate to the Start menu, then select Settings, Control Panel, and then ODBC data source. Click the System DSN tab and you will find the name of your ODBC data source.
To find the name of your ODBC data source on UNIX, type: |
Valid/Authorized Target database user name or group name |
Enter the target database user name for the Siebel administrator of the target database. For further information on the database user name, see Granting a Siebel User Upgrade Authorization. |
Valid/Authorized Target database password |
Enter the password associated with the username of the Siebel administrator of the target database. |
Host/LPAR name where the Staging database resides |
The host or LPAR name of the staging database. The staging and target Host/LPAR names can be the same or different. |
DB2 Subsystem name where the Staging database resides |
The DB2 subsystem name of the staging database. You must specifydifferent DB2 subsystem names for the target and staging databases. |
Schema/Tableowner qualifier name for Staging database |
Enter the up to eight-character identifier that designates the Siebel schema for your staging database. This is also an authorization ID. The schema qualifier must start with a letter, cannot contain special characters, and must be entered in uppercase. The staging database tableowner name can be the same or different to the target database tableowner name. |
Authorized TSO account ID used to connect and FTP files to Enterprise Server(s) |
Enter your TSO account ID. This account ID must have the authorization to allocate and create data sets on the z/OS host. |
Dataset High-level Qualifier for all Host (Staging and Target) dataset names |
Specify the high-level qualifier you want to use for the z/OS upgrade data sets. Follow your organization’s naming standards. |
Security Group ID / Grantee. |
Enter the user ID of the group to whom schema access is granted, for example, |
Storage Group for Temporary Indexes |
Enter the name of the storage group provided by the database administrator for the staging database (the default value is |
Storage Control File |
Enter the path and name of the storage control file you want to use as follows:
Primary Quantity for Temporary Index Space |
Enter the minimum amounts of primary and secondary index space allocated for temporary indexes generated during the upgrade. |
Secondary Quantity for Temporary Index Space |
DDL Commit Frequency |
Enter the DDL commit frequency for your upgrade. |
Output Directory |
Accept the default output directory name or enter a new directory name.
Note: When the upgrade process is complete, this directory contains all of the files necessary to create the staging database or run the upgrade. These files must be manually applied by the database administrator.
Verify Repository after upgrade |
Indicate whether you want to execute Verify Repository steps during upgphys. To perform upgphys separately, select the Verify Repository after Upgrade option in the database server configuration. |
Upgrep log directory |
If you select the Verify Repository After Upgrade option, enter the log directory of the upgrep process. The log directory is of the form |
Log Output Directory |
Accept the default output directory for upgrade log files name or enter a new directory name. |
Select runupg option |
Indicate whether you want to run the operation that you configured or run it at another time. |
Additional Information Required for Production Upgrades
If you are upgrading from Siebel CRM version 7.5.3, when you perform a production environment upgrade, you are prompted to enter the additional information shown in the following table when you run the Database Configuration Wizard in Prepare for Production Upgrade mode.
Note that several screens request information about the Siebel database in the development environment, not the production environment.
Table Additional Information Required for Production Upgrades
| Screen Name | Required Information |
ODBC Data Source Name for Development Database |
Windows only. The ODBC name for connecting to the development environment Siebel database. If you are upgrading without a development environment, this is the ODBC of the reference database. |
Database User Name for Development Database Database Password for Development Database |
Account name and password of the Siebel administrator of the Siebel database in the development environment. |
Siebel Schema Qualifier for Development Database |
Enter the up to eight-character identifier that designates the Siebel schema for your development database. This is also an authorization ID. The schema qualifier must start with a letter, cannot contain special characters, and must be entered in uppercase. |
Repository Name for Development Database |
Enter the name of the upgraded Siebel Tools repository in the development environment database. Typically, this is Siebel Repository. |
About Running the Database Configuration Wizard on Windows
Platforms: Windows only.
Run the Database Configuration Wizard to upgrade the Siebel database. The wizard collects information, populates a master configuration file, and calls the SQL generator to create SQL commands. The Siebel Upgrade Wizard then uses the configuration file and SQL commands to generate upgrade files that are applied on the mainframe, and to make upgrade changes to the Siebel database. For more information about the Database Configuration Wizard, see About the Siebel Database Configuration Utilities and Database Configuration Wizard.
Requirements:
Collect the information that the Database Configuration Wizard requires. See Information Required by the Database Configuration Wizard.
(Incremental Repository Merge Only) If you are performing an incremental repository merge and your Siebel Server is installed on Windows, then start the Siebel Database Configuration Wizard from the computer where Siebel Tools is installed. The merge process automatically starts Siebel Tools to execute the incremental repository merge.
Install the new release’s languages packs for all deployed languages. For further information on multilingual upgrades, see the topic on upgrade planning for multilingual Siebel deployments in Siebel Database Upgrade Guide.
Running the Database Configuration Wizard Under Windows
This topic describes the standard procedure to follow to run the Database Configuration Wizard under Windows.
To run the Database Configuration Wizard under Windows
Ensure that no server tasks except the Siebel Gateway Name Service are running in the background.
To verify, navigate to Start, Settings, Control Panel, and then Services.
Note: The Database Configuration Wizard runs in live mode only so you must be connected to the Gateway Name Server to run it. For further information on Siebel Configuration Wizard running modes, see Siebel Installation Guide for the operating system you are using.From the Start menu, select All Programs, Siebel Enterprise Server 8.x, and then Database Server Configuration.
The first screen of the Database Configuration Wizard appears.
Enter the information you are prompted for in each screen, and click Next to continue.
On the Summary screen, review the configuration values you entered on the previous screens. To change any of the values, click Back to return to the screen with the parameter you want to change. If the values are correct, click Next to continue.
Depending on the option you chose on the Select Runupg Option screen, do one of the following:
If you selected the No it will apply configuration changes later option, click OK to finish. The configuration information is saved in a master file located in
SIEBEL_ROOT\binbut the Upgrade Wizard is not launched. You can restart the configuration and run the Upgrade Wizard later. See Starting the Siebel Upgrade Wizard.If you selected the Yes apply configuration changes now option, the configuration information you entered is saved. Click OK to launch the Siebel Upgrade Wizard; it calls the SQL generator to create or populate SQL scripts.
After configuration is complete, click Exit to exit the Configuration Wizard.
You can also launch the Database Configuration Wizard from the command line. For information on the command line syntax and on the available options, see Siebel Installation Guide for Microsoft Windows.
About Running the Database Configuration Wizard Under UNIX
Platforms: UNIX only.
Run the Database Configuration Wizard to upgrade the Siebel database. The wizard collects information, populates a master configuration file, and calls the SQL generator to create SQL commands. The Siebel Upgrade Wizard then uses the configuration file and SQL commands to generate upgrade files that are applied on the mainframe, and to make upgrade changes to the Siebel database. For more information on the Database Configuration Wizard, see About the Siebel Database Configuration Utilities and Database Configuration Wizard.
Requirements:
This topic describes the standard procedure to follow to run the Database Configuration Wizard under UNIX.
To run the Database Configuration Wizard under UNIX
Verify that the Siebel Server is stopped.
The Database Configuration Wizard runs in live mode only so you must be connected to the Gateway Name Server to run it. For further information on Siebel Configuration Wizard running modes, see Siebel Installation Guide for UNIX.
Navigate to the SIEBSRVR_ROOT directory, and source either the dbenv.sh or the dbenv.csh file, according to the type of shell you use:
Korn or Bourne shell
. ./dbenv.sh
Tip: Make sure there is a space between the initial period and./dbenv.sh.C shell
source dbenv.csh
Review the values of the
$SIEBEL_ROOTandLANGUAGEenvironment variables and verify that they are correct. If necessary, reset the values as follows:Set the
LANGUAGEvariable to the language in which the Database Configuration Wizard prompts appear, for example,enufor U.S. English.Set the
$SIEBEL_ROOTvariable to the path of your Siebel Server installation directory, for example,home/siebel/sba8x/siebsrvr.
Navigate to the config subdirectory of the SIEBEL_ROOT directory, for example,
/siebel/sba8x/config.Start the Database Configuration Wizard by running the following command:
install_path/config/config -mode dbsrvr
In this path, install_path is the installation path for the installed Siebel Enterprise Server software.
For a description of the command line syntax and options, see Siebel Installation Guide for UNIX.
When the first Database Configuration Wizard screen appears, enter the information you are prompted for in this screen, and click next to continue.
Enter the information you are prompted for in all subsequent screens. Use the Next and Back buttons to navigate between screens.
After you have entered all the requested information, the utility displays the Summary screen listing all the values you have entered.
To amend any of the configuration values, click Back to return to the appropriate screen and make changes. Otherwise, click Next.
You are prompted as to whether or not you want to execute the configuration:
Click Yes, and the configuration information is saved in a master file located in
$SIEBEL_ROOT/binbut the Upgrade Wizard is not launched. To start the Upgrade Wizard, see Starting the Siebel Upgrade Wizard.Click No, and the configuration information you entered is not saved.
The Siebel Upgrade Wizard executes the upgrade of the Siebel database. It takes a master configuration file as input. This file contains environment information and a driver filename. The Upgrade Wizard executes the steps in the driver file to perform the upgrade.
As the Upgrade Wizard performs the steps in the driver file, it lists the steps in a state log. The state log is located in \siebsrvr\LOG\process\state where process is the upgrade process, for example upgrep_dev_811 (upgrade from 8.1.1, upgrep process, development environment).
If the Upgrade Wizard encounters an error and exits during an upgrade, you can restart it after correcting the error. The Upgrade Wizard reads the state log and continues the upgrade from the last successfully completed step.
When you run the Database Configuration Wizard under Windows, you are prompted to indicate whether or not you want to start the Upgrade Wizard. When you run the Database Configuration Wizard under UNIX, you must start the Upgrade Wizard manually. For more information on the Siebel Upgrade Wizard, see About the Siebel Upgrade Wizard and Driver Files.
Requirements for Starting the Siebel Upgrade Wizard After Errors
If the Siebel Upgrade Wizard stops due to errors, verify that you have met these requirements before restarting the wizard:
Carefully review the relevant log files to make sure that your upgrade has completed successfully up to that point.
If you are continuing a previous and incomplete schema upgrade, do not change the Log Output Directory that you previously selected.
If problems with your environment prevent the upgrade from restarting, you must restore the database from the prior base version (the version from which you are upgrading).
If you have to restore your database and restart the upgrade, delete or store the upgrade log files. The files are located in the following directory:
Windows:
SIEBEL_ROOT\log\PROCESS\outputUNIX:
$SIEBEL_ROOT/log/PROCESS/outputAlso delete the
state.logfile. It is located in the following directory:Windows:
SIEBEL_ROOT\log\PROCESS\stateUNIX:
$SIEBEL_ROOT/log/PROCESS/state
Use this procedure to start the Upgrade Wizard. See Restarting the Siebel Upgrade Wizard After Pauses for the procedure to restart the Upgrade Wizard after it has paused and Stopping the Siebel Upgrade Wizard for the procedure to stop the Upgrade Wizard.
Navigate to the following directory:
Windows:
SIEBEL_ROOT\binUNIX:
$SIEBEL_ROOT/binEnter the following command from the command line:
Windows:
siebupg /m master_UPGRADEOPTION_ENVIRONMENT_VERSION_MasterFileType.ucfUNIX:
srvrupgwiz /m master_UPGRADEOPTION_ENVIRONMENT_VERSION_MasterFileType.ucfwhere
UPGRADEOPTION_ENVIRONMENT_VERSION_MasterFileTypeis the portion of the upgrade configuration filename that lists the upgrade process, the upgrade environment, the Siebel release from which you are upgrading, and the master file type. The file is located inSIEBEL_ROOT\bin(UNIX:$SIEBEL_ROOT/bin). See About the Siebel Database Configuration Utilities and Database Configuration Wizard for further information.Note: Specify eithermf_mormffor the MasterFileType value depending on whether you want to start the manual or automatic portion of an Upgrade Wizard process.The following table lists examples of filenames for an upgrade from Siebel CRM version 8.1.1
Upgrade Option Master File Generated Development environment upgrep
master_upgrep_dev_811_mf_m.ucf
master_upgrep_dev_811_mf.ucf
Development environment upgphys
master_upgphys_dev_811_mf.ucf
Production environment upgrep and upgphys
master_upgrep_prod_811_mf_m.ucf
master_upgrep_prod_811_mf.ucf
To begin the upgrade, click OK (Windows) or click Enter (UNIX).
The Upgrade Wizard resumes from the point at which it stopped.
Use this procedure to restart the Upgrade Wizard after it has paused to allow you to apply files generated on the midtier to the z/OS host.
To restart the Upgrade Wizard
Navigate to the
DBSRVR_ROOT\DB2390\dboutput\upgradedirectory (Windows) or the$DBSRVR_ROOT/DB2390/dboutput/upgradedirectory (UNIX).Do the following:
Windows: Double-click on the
upg_restart.batfile.UNIX: Run
upg_restart.ksh.
Do not stop the Upgrade Wizard unless you are confident that an error has occurred, and the Upgrade Wizard or a utility it has called is hung. Some SQL commands issued by the Upgrade Wizard or by its utilities can take considerable time to complete.
If you are unsure whether or not the Upgrade Wizard has stopped responding, create a service request (SR) on My Oracle Support. You can log service requests by accessing My Oracle Support (Service Request tab), or by using your existing phone support numbers to contact Oracle Global Customer Support.
Stopping the Upgrade Wizard can have varying effects on the RDBMS. Before restarting the Upgrade Wizard, review the upgrade log files. Run SQL commands as required to resolve errors found in the logs.
The following procedure describes how to stop the Upgrade Wizard in a Windows environment.
To stop the Upgrade Wizard under Windows
Do one of the following:
If the Upgrade Wizard has launched a separate command window in which a utility is running, close the command window. This terminates the utility and stops the upgrade.
In the Upgrade Wizard dialog box, click Cancel.
The Upgrade Wizard will exit when the current upgrade step is completed. There might be a delay while the step completes.
The following procedure describes how to stop the Upgrade Wizard in a UNIX environment.
To stop the Upgrade Wizard under UNIX
If the Upgrade Wizard has started a utility in a child process, stop the child process.
Exit the shell in which the Upgrade Wizard is running.
Locate and stop any orphaned child processes started by the Upgrade Wizard.
After the processes terminate, there might be a delay while the RDBMS executes SQL commands that have already been issued.
Upgrading the Repository and Importing Seed Data
After you have created the staging database, generated the upgrade files, and upgraded the target database, you must upgrade the repository and import seed data.
Run the Database Configuration Wizard to upgrade the repository and import seed data as described in the following procedure.
To upgrade the repository and import seed data
Run the Database Configuration Wizard. See About Running the Database Configuration Wizard on Windows and About Running the Database Configuration Wizard Under UNIX.
Select the following options:
Upgrade Options:
Development environment: Upgrade Siebel Database Schema (upgrep)
Production environment: Upgrade Siebel Database Schema (upgrep + upgphys)
Upgrade Process: zSeries Seed/Repository Upgrade
Make sure you specify values for the target database when prompted for the names of the Host, DB2 subsystem, schema qualifier, ODBC data source, and database user name and password.
Enter configuration information for your environment as described in Information Required by the Database Configuration Wizard. The master UCF file is updated with the environment configuration information.
Start the Siebel Upgrade Wizard. See Starting the Siebel Upgrade Wizard.
Restarting the Seed Data Import and Repository Upgrade
If the Upgrade Wizard stops responding during the Repository Data Upgrade process, restart the process using the following procedure.
To restart the repository upgrade and seed data import process
From the command line, navigate to the
SIEBSRVR\bindirectory (Windows) orSIEBSRVR/bindirectory (UNIX).Run the RUNSTATS utility to update statistics on specified database tables by executing the following commands:
RSTAT390 /u UserId /p Password /c DatabaseName /d TableownerName /a Y /l rstat.log /T S_COLUMN RSTAT390 /u UserId /p Password /c DatabaseName /d TableownerName /a Y /l rstat.log /T S_UK_ATTJOIN
Restart the Upgrade Wizard using one of the methods described in Starting the Siebel Upgrade Wizard.
Fixing Column Alignment for Custom Objects
The Fixing Column Alignment for Custom Objects Utility sets the standard for list column header and data alignment based on type of fields they are mapped to across all Siebel applications.
The Fixing Column Alignment for Custom Objects Utility does the following:
List columns mapped to the Currency field type are aligned right (to the far margin).
List columns having icon maps mapped to them are center aligned.
List columns mapped to a Numeric field type are center aligned
List columns mapped to a Boolean field (or CHAR(1)) type are center aligned.
List columns mapped to any other field type are left aligned (to the near margin).
List columns data alignment will be same as its header alignment.
Left (alignment to the near margin) is the default value for data and header in list columns. HTML Width for list columns mapped to Date field type will be 185 by default.
The Fixing Column Alignment for Custom Objects Utility runs as part of the upgrade process. Use the procedures in this topic to manually run the Fixing Column Alignment for Custom Objects Utility.
Running the Fixing Column Alignment for Custom Objects Utility
Windows:
$DbsrvrRoot\common folderUNIX:
$DbsrvrRoot\common folderRun the following command:
java -jar alignapplet.jar /s [Siebel Tool/Server Path, one folder up BIN directory] /c [DSN] /d [Database Type - Oracle, DB2UDB, MSSQL or DB2390 ] /u [Database User] /p [Database Password] /o [Log directory] /t [Table Owner] /v "Prior Customer Repository" /r "New Siebel Repository" /x "New Customer Repository"
Review the AllignApplet log and verify that AlignApplet ran without errors.
Windows:
$SiebelLogDir\AlignApplet.logUNIX:
$SiebelLogDir/AlignApplet.logReview the AllignApplet reports to see the modified objects.
AlignApplet.log. A log of all the steps executed in this program.
AlignAppelt.html. A report detailing the modified objects.
AlignAppletLog.log. A folder that contains all the SQL logs executed during the column alignment process.
Inactivating Unreferenced Repository Objects
The Inactivating Unreferenced Repository Objects Utility identifies the unreferenced objects in the database and deactivates the unreferenced objects. Inactivating Unreferenced Repository Objects Utility finds unreferenced objects for the following Siebel objects:
Screen
View
Applet
Business Object
Business Component
Integration Objects
Link
Pick List
Task Group
Task
The Inactivating Unreferenced Repository Objects Utility runs as part of the upgrade process. Use the procedures in this topic to manually run the Inactivating Unreferenced Repository Objects Utility.
Running the Inactivating Unreferenced Repository Objects Utility
Windows:
java -jar RepCrawler.jar /s [Siebel Tool/Server Path, one folder up BIN directory] /c [DSN] /d [Database Type - Oracle, DB2UDB, MSSQL or DB2390 ] /u [Database User] /p [Database Password] /h [Host Name] /o [Log directory] /t [Table Owner] /r "Siebel Repository"
Review the RepCrawler log and verify that RepCrawler ran without errors.
Windows:
$SiebelLogDir\RepCrawler.logUNIX:
$SiebelLogDir/ RepCrawler.logReview the RepCrawler reports to see the inactive objects.
RepCrawler.html. A report where you can see the inactive objects.
repcrawler.js. A data file in JSON format of all inactive objects used in the HTML report.
RepcrawlerLog.log. A folder that contains all the SQL logs executed during the process of running the Inactivating Unreferenced Repository Objects Utility.
Converting Siebel Web Templates with the SWT to OD Conversion Utility
The SWT to OD Conversion Utility runs as part of the upgrade process. Use the procedures in this topic to manually run the SWT to OD Conversion Utility.
Running the SWT to OD Conversion Utility
Windows:
java -jar $DbsrvrRoot\common\SWTClob.jar /s $SiebelRoot /c "$ODBCDataSource" /t $TableOwner /u $TableOwner /p $TablePassword /o $SiebelLogDir /d $DatabasePlatform /r $RepositoryName /j $WebTemplatesDir /w $WSUSerName /x $WorkspaceName /b $BranchedWS /i $WebTemplateName
Review the SWTClob log and verify that SWTClob ran without errors.
Windows:
$SiebelLogDir\SWTClob.logUNIX:
$SiebelLogDir/SWTClob.logFor more information about troubleshooting and verifying the results of the Web template migration process, see Using Siebel Tools.
