| Oracle® Communications EAGLE Database Administration - System Management User's Guide Release 46.8 F11885 Revision 1 |
![]() Previous |
![]() Next |
This section presents the procedure for updating the HIPR2 generic program load (GPL). The HIPR2 GPL is used by the High-Speed IMT Packet Router 2 (HIPR2) card to control the IMT bus and resides on the fixed disk. The HIPR2 card resides only in slots 9 and 10 in each shelf in the EAGLE.
This section presents the procedure for loading the HIPR2 GPL onto the EAGLE as a trial version from a removable media, then making the trial version of the HIPR2 GPL the approved version.
If any card is not running the approved version of the GPL shown in the RELEASE column of the rtrv-gpl output, the indicator ALM is displayed next to the GPL version in the RUNNING column of the rept-stat-gpl output, and next to the GPL version in the APPROVED column in the rtrv-gpl output.
The removable media that contains the HIPR2 GPL to be loaded on to the EAGLE is required.
Refer to Maintenance and Administration Subsystem for information about the control cards.
If E5-based control cards are installed in the EAGLE, continue the procedure with 2.
rept-stat-db command.This is an example of the possible output.
rlghncxa03w 09-07-01 15:25:40 GMT EAGLE5 41.1.0
DATABASE STATUS: >> OK <<
TDM 1114 ( STDBY) TDM 1116 ( ACTV )
C LEVEL TIME LAST BACKUP C LEVEL TIME LAST BACKUP
FD BKUP Y 36 09-06-19 09:38:25 GMT Y 36 09-06-19 09:38:25 GMT
FD CRNT Y 39 Y 39
MCAP 1113 MCAP 1115
RD BKUP - - - - Y 36 09-06-19 09:27:17 GMT
USB BKP - - - - Y 3 09-06-07 01:11:22 GMT
If removable media is installed in the active MASP, continue the procedure with 4.
If removable media is not installed in the active MASP, insert the removable media in the removable media drive in the active MASP. For more information about inserting removable media in the removable media drive, refer to Removable USB Drive. After the removable media has been inserted in the removable media drive in the active MASP, continue the procedure with 4.
rtrv-gpl:gpl=hipr2 command.This is an example of the possible output.
rlghncxa03w 09-07-01 11:34:04 GMT EAGLE5 41.1.0 GPL Auditing ON GPL CARD RELEASE APPROVED TRIAL REMOVE TRIAL HIPR2 1114 132-002-000 132-002-000 132-001-000 132-003-000 HIPR2 1116 132-002-000 132-002-000 132-001-000 132-003-000 HIPR2 1115 ----------- ----------- ----------- -----------
If the version of the HIPR2 GPL shown in the REMOVE TRIAL column of the rtrv-gpl output is not the version that is to be loaded onto the cards, remove the removable media from the active MASP.
Insert the removable media that contains the HIPR2 GPL that is being updated into the removable media drive in the active MASP and repeat this step.
For more information about inserting removable media in the removable media drive, or removing removable media from the removable media drive, refer to Removable USB Drive.
If the version of the HIPR2 GPL shown in the REMOVE TRIAL column of the rtrv-gpl output is the version that is to be loaded onto the cards, continue the procedure with 5.
chg-gpl command and specifying the value for the trial HIPR2 GPL shown in the REMOVE TRIAL column in the output of the rtrv-gpl command used in 4. For this example, enter this command.
chg-gpl:gpl=hipr2:ver=132-003-000
These messages should appear.
rlghncxa03w 09-07-01 11:43:04 GMT EAGLE5 41.1.0 GPL Auditing ON HIPR2 upload on 1114 completed HIPR2 upload on 1116 completed System Release ID table upload 1114 completed System Release ID table upload 1116 completed
If you wish to leave the HIPR2 cards running the trial version of the HIPR2 GPL, continue the procedure with 8.act-gpl command and specifying the value for the trial HIPR2 GPL shown in 5. For this example, enter this command.
act-gpl:gpl=hipr2:ver=132-003-000
rlghncxa03w 09-07-01 06:54:39 GMT EAGLE5 41.1.0 HIPR2 activate on 1114 completed HIPR2 activate on 1116 completed
rtrv-gpl:gpl=hipr2 command. This is an example of the possible output.
rlghncxa03w 09-07-01 11:34:04 GMT EAGLE5 41.1.0 GPL Auditing ON GPL CARD RELEASE APPROVED TRIAL REMOVE TRIAL HIPR2 1114 132-003-000 132-003-000 132-002-000 132-003-000 HIPR2 1116 132-003-000 132-003-000 132-002-000 -----------
If E5-based control cards are installed in the EAGLE, this is an example of the possible output.
rlghncxa03w 09-07-01 11:34:04 GMT EAGLE5 41.1.0 GPL Auditing ON GPL CARD RELEASE APPROVED TRIAL REMOVE TRIAL HIPR2 1114 132-003-000 132-003-000 132-002-000 132-003-000 HIPR2 1116 132-003-000 132-003-000 132-002-000 132-003-000 HIPR2 1115 ----------- ----------- ----------- -----------
rept-stat-gpl:gpl=hipr2 command. This is an example of the possible output.
rlghncxa03w 09-07-01 11:40:26 GMT EAGLE5 41.1.0 GPL CARD RUNNING APPROVED TRIAL HIPR2 1109 132-002-000 ALM 132-003-000 132-002-000 HIPR2 1110 132-002-000 ALM 132-003-000 132-002-000 HIPR2 1209 132-002-000 ALM 132-003-000 132-002-000 HIPR2 1210 132-002-000 ALM 132-003-000 132-002-000 HIPR2 1309 132-002-000 ALM 132-003-000 132-002-000 HIPR2 1310 132-002-000 ALM 132-003-000 132-002-000 HIPR2 2109 132-002-000 ALM 132-003-000 132-002-000 HIPR2 2110 132-002-000 ALM 132-003-000 132-002-000 Command Completed
init-flash:code=appr command. Caution:
Theinit-flash command cannot be entered if the IMT Rate Change sequence or the Extended Bit Error Rate Test (BERT) is being performed. For this example, enter this command.
init-flash:code=appr:loc=1109
When this command has successfully completed, these messages should appear.
rlghncxa03w 09-07-01 11:11:28 GMT EAGLE5 41.1.0
FLASH Memory Downloading for card 1109 Started.
HIPR2 Downloading for card 1109 Complete.
Command Completed.
Updating more than One HIPR2 Card at the Same Time Multiple HIPR2 cards can be updated at the same time with the init-flash command. The multiple HIPR2 cards being updated must be on the same IMT bus. Specifying card locations XX09 for the sloc and eloc parameters specifies the HIPR2 cards on IMT bus A. Specifying card locations XX10 for the sloc and eloc parameters specifies the HIPR2 cards on IMT bus B.
To update more than one HIPR2 card on the same IMT bus, enter the init-flash command with these parameters along with the code=appr parameter:
sloc – the first card location in the range of card locations
eloc – the last card location in the range of card locations
gpl – hipr2
Thesloc, eloc, and gpl parameters cannot be specified with the loc parameter.For example, to update the HIPR2 cards on IMT Bus B shown in 8 with the approved version of the HIPR2 GPL, enter this command.
init-flash:code=appr:sloc=1110:eloc=2110:gpl=hipr2
To update the HIPR2 cards on IMT bus A shown in 8, the sloc=1109 and eloc=2109 parameters would be specified with the init-flash command.
FLASH Memory Download for cards 1110 - 2110 Started.
rlghncxa03w 09-07-01 13:07:15 GMT EAGLE5 41.1.0
FLASH Memory Download for cards 1110 - 2110 Completed.
LOC 1110 : PASSED
LOC 1210 : PASSED
LOC 1310 : PASSED
LOC 2110 : PASSED
ALL CARD RESULTS PASSED
Command Completed.
init-mux command with the loc parameter. Caution:
Theinit-mux command cannot be entered if the IMT Rate Change sequence or the Extended Bit Error Rate Test (BERT) is being performed. For this example, enter this command.
init-mux:loc=1109
If more than one HMUX card was specified in 9, re-initialize the IMT bus containing the cards specified in 9 by entering init-mux command and specifying the IMT bus (the bus parameter) containing the cards specified in 9. Specifying card locations XX09 for the sloc and eloc parameters in 9 requires that IMT bus A is re-initialized. Specifying card locations XX10 for the sloc and eloc parameters in 9 requires that IMT bus B is re-initialized.
init-mux:bus=a
When this command has successfully completed, this message should appear.
rlghncxa03w 09-07-01 11:11:28 GMT EAGLE5 41.1.0 Command Completed.
Executing this command produces two alarms: 0002 - Card is not running approved GPL, indicating that the version of the HIPR2 GPL running on the card is not the approved version, and 0004 - Card is running non-activated GPL, indicating that the new version of the HIPR2 GPL running on the card has not been activated.rept-stat-card command. If more than one card was specified in 9 and 10, enter the rept-stat-card command for each specified card. For this example, enter this command.
rept-stat-card:loc=1109:mode=full
rlghncxa03w 09-07-01 11:11:28 GMT EAGLE5 41.1.0 CARD VERSION TYPE GPL PST SST AST 1109 132-003-000 HIPR2 HIPR2 IS-NR Active ----- ALARM STATUS = No Alarms TRIAL VERSION = 132-003-000 FPGA VERSION = 022-005 Command Completed.
If the version number of the HIPR2 GPL shown in therept-stat-card command output is different than the version specified5 in, contact the Customer Care Center. Refer to My Oracle Support (MOS) for the contact information.act-flash command. Caution:
Theact-flash command cannot be entered if the Extended Bit Error Rate Test (BERT) is being performed.For this example, enter this command.
act-flash:loc=1109
FLASH Memory Activation for card 1109 Completed.
Command Completed.
Activating the HIPR2 GPL on more than One HIPR2 card at the Same Time
If more than one HIPR2 card was specified in 9, enter the act-flash command with these parameters:
gpl – hipr2
Thesloc, eloc, and gpl parameters cannot be specified with the loc parameter.For example, to activate the HIPR2 GPL on the HIPR2 cards on IMT Bus B shown in 8 with the trial version of the HIPR2 GPL, enter this command.
act-flash:sloc=1110:eloc=2110:gpl=hipr2
To activate the HIPR2 GPL on the HIPR2 cards on IMT bus A shown in 8, the sloc=1109 and eloc=2109 parameters would be specified with the act-flash command.
FLASH Memory Activation for cards 1110 - 2110 Started.
FLASH Memory Activation for cards 1110 - 2110 Completed.
LOC 1110 : PASSED
LOC 1210 : PASSED
LOC 1310 : PASSED
LOC 2110 : PASSED
Command Completed.
rlghncxa03w 09-07-01 11:40:26 GMT EAGLE5 41.1.0 GPL CARD RUNNING APPROVED TRIAL HIPR2 1109 132-003-000 132-003-000 132-002-000 HIPR2 1110 132-002-000 ALM 132-003-000 132-002-000 HIPR2 1209 132-002-000 ALM 132-003-000 132-002-000 HIPR2 1210 132-002-000 ALM 132-003-000 132-002-000 HIPR2 1309 132-002-000 ALM 132-003-000 132-002-000 HIPR2 1310 132-002-000 ALM 132-003-000 132-002-000 HIPR2 2109 132-002-000 ALM 132-003-000 132-002-000 HIPR2 2110 132-002-000 ALM 132-003-000 132-002-000 Command Completed
Figure 3-5 Updating the HIPR2 GPL
Sheet 1 of 5
Sheet 2 of 5
Sheet 3 of 5
Sheet 4 of 5
Sheet 5 of 5
