| Oracle® Communications EAGLE Database Administration - System Management User's Guide Release 46.8 F11885 Revision 1 |
![]() Previous |
![]() Next |
This procedure is used to update
GPLs: The GPLs are used as the value of the
gpl parameter of the
chg-gpl,
act-gpl,
rept-stat-gpl, and
rtrv-gpl commands.
Table 3-4 EAGLE Card Applications and GPLs
| Intended Application GPL | Card configuration
(rtrv-card)
Hardware Type Used | Required Flash GPL | |
| APPL | Type | |||
| SCCP64 | VSCCP | DSM | SM8G-B | BLDC64 |
| VSCCP | DSM/SLIC | SLIC | BLSLC64 | |
| IPSG | IPSG | ENET/ENETB | E5-ENET-B | BLMCAP |
| IPSG | ENET/ENETB/SLIC | SLIC | BLSLC32 | |
| IPSG32 | IPSG | SLIC | SLIC | BLSLC32 |
| IPSHC69 | IPS | IPSM | E5-ENET-B | BLDC32 |
| IPS | IPSM | SLIC | BLSL932 | |
| MCPHC69 | MCP | MCPM | E5-MCPM-B | BLDC32 |
| MCP | MCPM | SLIC | BLSL932 | |
| OAMHC69 | OAM | E5-MCAP | E5-MASP | BLDC32 |
| SIP64 | SIPHC | DSM | SM8G-B | BLDC64 |
| SIPHC | DSM/SLIC | SLIC | BLSLC64 | |
| DEIR64 | DEIRHC | DSM | SM8G-B | BLDC64 |
| DEIRHC | DSM/SLIC | SLIC | BLSLC64 | |
| ENUM64 | ENUMHC | DSM | SM8G-B | BLDC64 |
| ENUMHC | DSM/SLIC | SLIC | BLSLC64 | |
| SFAPP | SFAPP | SLIC | SLIC | BLSLC64 |
| ATMHC | ATMITU | LIME1ATM | E5-ATM-B | BLMCAP |
| ATMANSI | LIMATM | E5-ATM-B | BLMCAP | |
| ERTHC | EROUTE | STC | E5-ENET-B | BLMCAP |
| EROUTE | STC | SLIC | BLSLC32 | |
| SS7HC | CCS7ITU | LIME1 | E5-E1T1-B | BLMCAP |
| SLIC | BLSLC32 | |||
| SS7ANSI | LIMT1 | E5-E1T1-B | BLMCAP | |
Updating the BLMCAP GPL for the E5-MASPs is not covered in this procedure. To update the OAMHC GPLs, perform Updating the BLMCAP and OAMHC GPLs .
If the GPL is being updated to a new version, removable media containing the GPL being updated is required.
Canceling the
REPT-STAT-SLK and
RTRV-SLK Commands
Because the
rept-stat-slk and
rtrv-slk commands used in this
procedure can output information for a long period of time, the
rept-stat-slk and
rtrv-slk commands can be canceled and
the output to the terminal stopped. There are three ways that the
rept-stat-slk and
rtrv-slk commands can be canceled.
F9 function key on the keyboard at
the terminal where the
rept-stat-slk or
rtrv-slk commands command were
entered.
canc-cmd without the
trm parameter at the terminal where
the
rept-stat-slk or
rtrv-slk commands were entered.
canc-cmd:trm=<xx>, where
<xx> is the terminal where the
rept-stat-slk or
rtrv-slk commands were entered, from
another terminal other that the terminal where the
rept-stat-slk or
rtrv-slk commands were entered. To
enter the
canc-cmd:trm=<xx> command, the
terminal must allow Security Administration commands to be entered from it and
the user must be allowed to enter Security Administration commands. The
terminal’s permissions can be verified with the
rtrv-secu-trm command. The user’s
rtrv-user or
rtrv-secu-user commands.
For more information about the
canc-cmd command, go to
Commands User's Guide.
Refer to Maintenance and Administration Subsystem for information about the control cards.
If E5-based control cards are installed in the EAGLE, continue the procedure with 2.
rept-stat-db command.
This is an example of the possible output.
rlghncxa03w 09-03-01 15:25:40 GMT EAGLE5 40.1.0
DATABASE STATUS: >> OK <<
E5-MASP 1114 ( STDBY) E5-MASP 1116 ( ACTV )
C LEVEL TIME LAST BACKUP C LEVEL TIME LAST BACKUP
FD BKUP Y 36 09-02-19 09:38:25 GMT Y 36 09-02-19 09:38:25 GMT
FD CRNT Y 39 Y 39
MCAP 1113 MCAP 1115
RD BKUP - - - - Y 36 09-02-19 09:27:17 GMT
USB BKP - - - - Y 3 09-02-07 01:11:22 GMT
If removable media is installed in the active MASP, continue the procedure with 5.
If removable media is not installed in the active MASP, insert the removable media in the removable media drive in the active MASP. For more information about inserting removable media in the removable media drive, refer to Removable USB Drive. After the removable media has been inserted in the removable media drive in the active MASP, continue the procedure with 5.
rtrv-card:loc<xxxx> command:
rtrv-card:loc=1203
Command Accepted - Processing
eagle1 18-02-20 11:27:40 EST EAGLE 46.6.0.0.0-73.13.0
rtrv-card:loc=1203
Command entered at terminal #13.
CARD TYPE APPL DATA LSET NAME LINK SLC LSET NAME LINK SLC
1203 LIME1 CCS7ITU mgtsitu A 0
rtrv-bip:loc<xxxx> command:
rtrv-bip:loc=1203
eagle1 18-02-20 11:27:49 EST EAGLE 46.6.0.0.0-73.13.0
rtrv-bip:loc=1203
Part Number: 7094646
Revision: 17 Week/Year: 15/2017
Serial Number: 10217152084
Software Match ID: EG - 001 Max Power Rating : 826mA
END OF REPORT
rtrv-gpl command with the
gpl parameter value equal to the
flash
GPL being updated. For
this example, enter this command.
rtrv-gpl:gpl=xxxx
This is an example of the possible output:
tekelecstp 18-01-18 21:23:11 EST EAGLE 46.5.1.5.0-73.10.0 GPL Auditing ON GPL CARD RELEASE APPROVED TRIAL REMOVE TRIAL BLMCAP 1114 143-010-000 143-010-000 143-010-000 ----------- BLMCAP 1116 143-010-000 143-010-000 143-010-000 ----------- BLMCAP 1115 ----------- ----------- ----------- -----------
If the version of the flash
GPL shown in the
REMOVE TRIAL column of the
rtrv-gpl output is not the version
that is to be loaded onto the cards, remove the removable media from the active
MASP.
Insert the removable media that contains the flash GPL that is being updated into the removable media drive in the active MASP and repeat this step.
For more information about inserting removable media in the removable media drive, or removing removable media from the removable media drive, refer to Removable USB Drive.
GPL shown in the
rtrv-gpl output is the version
that is to be loaded onto the cards, continue the procedure with
6.
chg-gpl command and specifying the
value for the flash
GPL shown in the
REMOVE TRIAL column in the output of
the
rtrv-gpl command.
For this example, enter this command.
chg-gpl:gpl=blmcap:ver=002-003-000
These messages should appear.
tekelecstp 18-01-18 21:23:11 EST EAGLE 46.5.1.5.0-73.10.0 GPL Auditing ON BLMCAP upload on 1114 completed BLMCAP upload on 1116 completed System Release ID table upload 1114 completed System Release ID table upload 1116 completed
act-gpl command and specifying the
name and version of the trial flash
GPL specified in
6.
act-gpl:gpl=blmcap:ver=002-003-000
tekelecstp 18-01-18 21:23:11 EST EAGLE 46.5.1.5.0-73.10.0 BLMCAP activate on 1114 completed BLMCAP activate on 1116 completed
gpl parameter value specified in
7.
rtrv-gpl:gpl=blmcap
If E5-based control cards are installed in the EAGLE, this is an example of the possible output.
rept-stat-gpl output, that the flash
GPL will be loaded
onto using the
rept-stat-card command and
specifying the location of the card.
rept-stat-card:loc=2105
tekelecstp 18-01-18 21:23:11 EST EAGLE 46.5.1.5.0-73.10.0 CARD VERSION TYPE GPL PST SST AST 2105 132-003-000 DCM VXWSLAN IS-NR Active ----- ALARM STATUS = No Alarms. BLMCAP GPL = 143-010-000 IMT BUS A = Conn IMT BUS B = Conn SLK A PST = IS-NR LS=lsnsspn2 CLLI=----------- SCCP SERVICE CARD = 1212 SLAN SERVICE CARD = ---- Command Completed.
rtrv-card
Enter the
rtrv-slk command with the card
location specified in
9.
rlghncxa03w 09-07-01 21:16:37 GMT EAGLE5 41.1.0
L2T PCR PCR
LOC LINK LSN SLC TYPE SET BPS ECM N1 N2
1201 A lsn1201a 0 LIMDS0 1 56000 BASIC --- -----
1201 B lsn1201b 0 LIMDS0 1 56000 BASIC --- -----
1201 A1 lsn1201a 1 LIMDS0 1 56000 BASIC --- -----
1201 B1 lsn1201b 1 LIMDS0 1 56000 BASIC — -----
dact-slk command.
For this example, enter these commands.
dact-slk:loc=1201:link=a
dact-slk:loc=1201:link=b
dact-slk:loc=1201:link=a1
dact-slk:loc=1201:link=b1
Caution:
These command examples place the SS7 signaling links on card 1201 out of service. This will interrupt service on the SS7 signaling links on card 1201 and allow the approved flash GPL to be loaded on to card 1201.Caution:
Do not deactivate all the SS7 signaling links in the EAGLE at the same time. Doing so will take all the SS7signaling links out of service and isolate the EAGLE from the network.When each of these commands have successfully completed, this message should appear.
tekelecstp 18-01-18 21:23:11 EST EAGLE 46.5.1.5.0-73.10.0 Deactivate SLK message sent to card
Continue the procedure with 22.
Enter the
rept-stat-dlk command. This is an
rlghncxa03w 06-10-01 17:00:36 GMT EAGLE5 36.0.0 DLK PST SST AST 1303 IS-NR Avail --- 2101 IS-NR Avail --- 2103 IS-NR Avail --- 2105 IS-NR Avail --- 2113 IS-NR Avail --- 2301 IS-NR Avail --- Command Completed.
canc-dlk command.
canc-dlk:loc=2105
Caution:
This command example places the TCP/IP data link on card 2105 out of service. This will interrupt service on the TCP/IP data link on card 2105 and allow the trial flash GPL to be loaded on to card 2105.Caution:
Do not deactivate all the TCP/IP data links in the EAGLE at the same time. Doing so will take all the TCP/IP data links out of service and cause theSTPLAN feature to be disabled.Caution:
If there is only one TCP/IP data link in the EAGLE, placing the card out of service will cause the STPLAN feature to be disabled.When this command has successfully completed, this message should appear.
rlghncxa03w 06-10-01 11:45:18 GMT EAGLE5 36.0.0 Deactivate Link message sent to card. Command Completed.
rept-stat-sccp command.
rlghncxa03w 06-10-01 09:57:31 GMT EAGLE5 36.0.0 CARD VERSION PST SST AST MSU USAGE CPU USAGE ----------------------------------------------------------------------------- 2311 132-002-001 IS-NR Active ----- 47% 81% 3101 132-002-001 IS-NR Active ----- 34% 50% 3103 132-002-001 IS-NR Active ----- 21% 29% ----------------------------------------------------------------------------- SCCP Service Average MSU Capacity = 34% Average CPU Capacity = 54% Command Completed.
Therept-stat-sccp command output
contains other fields that are not used by this procedure. If you wish to see
all the fields displayed by the
rept-stat-sccp command, see the
rept-stat-sccp command description
in
rept-stat-meas command.
rlghncxa03w 09-02-01 16:43:42 GMT EAGLE5 40.0.0
PST SST AST
MEAS SS IS-NR Active -----
CARD VERSION TYPE PST SST AST
2107 P 132-002-000 EDSM IS-NR Active -----
IP Link A IS-NR Active Available
2108 132-002-000 EDSM IS-NR Active -----
2111 132-002-000 EDSM IS-NR Active -----
CARD 2107 ALARM STATUS = No Alarms
CARD 2108 ALARM STATUS = No Alarms
CARD 2111 ALARM STATUS = No Alarms
To determine which MASP is active, enter the
rept-stat-db command. This is an
rlghncxa03w 06-10-01 16:07:48 GMT EAGLE5 36.0.0 DATABASE STATUS: >> OK << E5-MASP 1114 ( STDBY) E5-MASP 1116 ( ACTV ) C LEVEL TIME LAST BACKUP C LEVEL TIME LAST BACKUP - -------- --------------------- - -------- --------------------- FD BKUP Y 35 05-03-01 10:19:18 GMT Y 35 05-03-01 10:19:18 GMT FD CRNT Y 106 Y 106 E5-MDAL 1117 - -------- RD BKUP Y 106 05-02-31 20:27:53 GMT
The output of the
rept-stat-db command shows which
MASP is active with the indicator (ACTV) following the E5-MASP card location.
The indicator (STDBY) following the E5-MASP card location shows which MASP is
standby.
For this example, the MASP associated with E5-MASP 1116 is active and the MASP associated with E5-MASP 1114 is standby.
rtrv-trm command.
If the application GPL running on the card is
IPS, the Telnet
terminals associated with the card shown in
9
must be taken out of service. The Telnet terminals are shown in the output with
the entry
TELNET in the
TYPE field.
This is an example of the possible output. In this example, the SEAS terminals are terminals 27 and 36. The Telnet terminals that must be taken out of service are terminals 17 to 24.
rlghncxa03w 10-07-01 16:02:08 GMT EAGLE5 42.0.0 TRM TYPE COMM FC TMOUT MXINV DURAL 1 VT320 9600-7-E-1 SW 30 5 99:59:59 2 KSR 9600-7-E-1 HW 30 5 INDEF 3 PRINTER 4800-7-E-1 HW 30 0 00:00:00 4 VT320 2400-7-E-1 BOTH 30 5 00:30:00 5 VT320 9600-7-O-1 NONE 30 5 00:00:30 6 VT320 9600-7-O-1 NONE 30 5 00:00:30 7 PRINTER 9600-7-N–2 HW 30 5 00:30:00 8 KSR 19200-7-E-2 BOTH 30 5 00:30:00 9 VT320 9600-7-O-1 NONE 30 5 00:00:30 10 VT320 9600-7-E-1 HW 30 5 00:30:00 11 VT320 4800-7-E-1 HW 30 5 00:30:00 12 PRINTER 9600-7-E-1 HW 30 4 00:30:00 13 VT320 9600-7-O-1 NONE 30 5 00:30:00 14 VT320 9600-7-E-2 SW 30 8 00:30:00 15 VT320 9600-7-N–2 HW 30 5 00:30:00 16 VT320 9600-7-E-2 BOTH 30 3 00:30:00 TRM TYPE LOC TMOUT MXINV DURAL SECURE 17 TELNET 1201 60 5 00:30:00 yes 18 TELNET 1201 60 5 00:30:00 yes 19 TELNET 1201 60 5 00:30:00 yes 20 TELNET 1201 60 5 00:30:00 yes 21 TELNET 1201 60 5 00:30:00 yes 22 TELNET 1201 60 5 00:30:00 yes 23 TELNET 1201 60 5 00:30:00 yes 24 TELNET 1201 60 5 00:30:00 yes 25 TELNET 1203 60 5 00:30:00 yes 26 TELNET 1203 60 5 00:30:00 yes 27 SEAS 1203 60 5 00:30:00 yes 28 TELNET 1203 60 5 00:30:00 yes 29 TELNET 1203 60 5 00:30:00 yes 30 TELNET 1203 60 5 00:30:00 yes 31 TELNET 1203 60 5 00:30:00 yes 32 TELNET 1203 60 5 00:30:00 yes 33 TELNET 1205 60 5 00:30:00 yes 34 TELNET 1205 60 5 00:30:00 yes 35 TELNET 1205 60 5 00:30:00 yes 36 SEAS 1205 60 5 00:30:00 yes 37 TELNET 1205 60 5 00:30:00 yes 38 TELNET 1205 60 5 00:30:00 yes 39 TELNET 1205 60 5 00:30:00 yes 40 TELNET 1205 60 5 00:30:00 yes
Thertrv-trm command output contains
other fields that are not used by this procedure. If you wish to see all the
rtrv-trm command, see the
rtrv-trm command description in
rept-stat-trm command.
rlghncxa03w 06-10-01 15:08:45 GMT EAGLE5 36.0.0 TRM PST SST AST 1 IS-NR Active ----- 2 IS-NR Active ----- 3 IS-NR Active ----- 4 IS-NR Active ----- 5 IS-NR Active ----- 6 IS-NR Active ----- 7 IS-NR Active ----- 8 IS-NR Active ----- 9 IS-NR Active ----- 10 IS-NR Active ----- 11 IS-NR Active ----- 12 IS-NR Active ----- 13 IS-NR Active ----- 14 IS-NR Active ----- 15 IS-NR Active ----- 16 IS-NR Active ----- 17 IS-NR Active ----- 18 IS-NR Active ----- 19 IS-NR Active ----- 20 IS-NR Active ----- 21 IS-NR Active ----- 22 IS-NR Active ----- 23 IS-NR Active ----- 24 IS-NR Active ----- 25 IS-NR Active ----- 26 IS-NR Active ----- 27 IS-NR Active ----- 28 IS-NR Active ----- 29 IS-NR Active ----- 30 IS-NR Active ----- 31 IS-NR Active ----- 32 IS-NR Active ----- 33 IS-NR Active ----- 34 IS-NR Active ----- 35 IS-NR Active ----- 36 IS-NR Active ----- 37 IS-NR Active ----- 38 IS-NR Active ----- 39 IS-NR Active ----- 40 IS-NR Active ----- Command Completed.
rmv-trm command.
To place the SEAS terminals out of service in this example, enter these commands.
rmv-trm:trm=27
rmv-trm:trm=36:force=yes
Caution:
Placing the SEAS terminals out of service will disable the SEAS feature on the EAGLE.To place the Telnet terminals out of service in this example, enter these commands.
rmv-trm:trm=17
rmv-trm:trm=18
rmv-trm:trm=19
rmv-trm:trm=20
rmv-trm:trm=21
rmv-trm:trm=22
rmv-trm:trm=23
rmv-trm:trm=24
Caution:
Placing the Telnet terminals out of service will disable any Telnet sessions running on these terminals.If the status of any of the terminals shown in the
PST field in
19
is
OOS-MT-DSBLD (out-of-service maintenance disabled), the terminal
is already out of service and the
rmv-trm command does not need to
be executed for that terminal.
This message should appear when each of these commands have successfully completed.
rlghncxa03w 06-10-01 15:08:45 GMT EAGLE5 36.0.0 Inhibit message sent to terminal rlghncxa03w 06-10-01 15:08:45 GMT EAGLE5 36.0.0 Command Completed.
chg-trm command, the
type=none parameter, and with the
values of the SEAS terminals used in
20.
chg-trm:trm=27:type=none
chg-trm:trm=36:type=none
This message should appear when these commands have successfully completed.
rlghncxa03w 06-10-01 11:11:28 GMT EAGLE5 36.0.0 CHG-TRM: MASP B - COMPLTD
rmv-card command.
Caution:
Multiple cards running the same flash GPL can be updated at the same time with theinit-flash command (25).
This requires that the cards in the locations specified with the
init-flash command in
25
are out of service. All the cards running one of these application GPLs (OAMHC
or BLMCAP ) can be placed out of service. However, it is recommended that only
some of the cards running a specific application GPL are placed out of service.
Placing all the cards running a specific application GPL out of service will
cause the traffic carried by these cards to be lost and disable the features
supported by these cards.
Caution:
If the EOAM GPL is being updated, the card being placed out of service must be the E5-MASP associated with the standby MASP. Both cards running the EOAM GPL cannot be placed out of service at the same time.Caution:
If there is only one card running these application GPLs (OAMHC or BLMCAP), shown in theGPL column in the
rept-stat-card output in
9,
in the
will cause the traffic carried by this card to be lost and disable the feature
that this card supports.
rmv-card:loc=2105
If more than one card running the same flash GPL is to be updated in 25, repeat this step for those cards.When this command has successfully completed, this message should appear.
rlghncxa03w 06-10-01 11:11:28 GMT EAGLE5 36.0.0 Card has been inhibited.
If the card is running the OAMHC or BLMCAP
application GPLs, and the card contains the last signaling link in a linkset,
the
force=yes parameter must be
specified.
If you do not wish to reload the TDM clock LCA bitfile, continue the procedure with 25.rept-stat-clk command.
rlghncxa03w 08-06-01 11:34:04 GMT EAGLE5 39.0.0
COMPOSITE PST SST AST
SYSTEM CLOCK IS-NR Active -----
Primary Comp Clk 1114 (CLK A) IS-NR Active -----
Primary Comp Clk 1116 (CLK B) IS-NR Active -----
Secondary Comp Clk 1114 (CLK A) IS-NR Idle -----
Secondary Comp Clk 1116 (CLK B) IS-NR Idle -----
Clock Using Bad
CLK A 9 0
CLK B 0 0
CLK I 0 --
HIGH SPEED PST SST AST
SYSTEM CLOCK IS-NR Idle -----
Primary HS Clk 1114 (HS CLK A) IS-NR Active -----
Primary HS Clk 1116 (HS CLK B) IS-NR Active -----
Secondary HS Clk 1114 (HS CLK A) IS-NR Idle -----
Secondary HS Clk 1116 (HS CLK B) IS-NR Idle -----
HS CLK TYPE 1114 = RS422
HS CLK LINELEN 1114 = LONGHAUL
HS CLK TYPE 1116 = RS422
HS CLK LINELEN 1116 = LONGHAUL
Clock Using Bad
HS CLK A 2 0
HS CLK B 0 0
HS CLK I 0 --
Command Completed
If the
rept-stat-clk output does not show
any high-speed clocks (HIGH SPEED SYSTEM
CLOCK,
Primary HS Clk,
Secondary HS Clk,
HS CLK TYPE, and
HS CLK LINELEN fields), the
EAGLE does not contain any cards that
are capable of using high-speed master timing.
If theHS CLK TYPE and
HS CLK LINELEN values are set to
the system default values (HS CLK TYPE = RS422
and
HS CLK LINELEN = LONGHAUL),
25.
Proceed to 26.
init-flash command with the
code=appr parameter to load the
approved version of the flash
GPL onto the card.
Caution:
Theinit-flash command cannot be
entered if the IMT Rate Change sequence
or the Extended Bit Error Rate Test (BERT) is being performed.
init-flash:code=appr:loc=2105
When this command has successfully completed, these messages should appear.
FLASH Memory Downloading for card 2105 Started.
BPHCAP Downloading for card 2105 Complete.
Command Completed.
Caution:
If reloading the clock LCA bitfile would cause a system clock outage, theforce=yes parameter must be used
with the
init-flash command. A system clock
outage can be caused by either the
EAGLE having only one
E5-OAM (a simplex
MASP configuration)
or if the status of the high-speed clocks, shown in the
rept-stat-clk output in
23,
on the
TDM which is not
being reset is Fault. A system clock outage will result in a loss of traffic on
some or all signaling links.
The following command example loads the flash GPL onto the E5-OAM card and reloads the clock LCA bitfile.
init-flash:initclk=yes:loc=1113:code=appr
FLASH Memory Download for card 1113 Started.
FLASH Memory Download for card 1113 Completed.
init-flash command with these
parameters along with the
code=appr parameter:
sloc – the first
card location in the range of card locations
eloc – the last
gpl – the flash
GPL being updated
Thesloc,
eloc, and
gpl parameters cannot be specified
with the
loc parameter. When the
sloc,
eloc, and
gpl parameters are specified, only
the cards running the flash
GPL specified by the
gpl parameter and within the range
specified by the
sloc and
eloc parameters are updated. All
other cards in the range specified by the
sloc and
eloc parameters are skipped.
Entering this example command will update the cards in the locations 1101 to 2115 running the OAMHC flash GPL with the approved version of the OAMHC GPL.
init-flash:code=appr:sloc=1101:eloc=2115:gpl=blmcap
FLASH Memory Download for cards 1101 - 2115 Started.
FLASH Memory Download for cards 1101 - 2115 Completed.
LOC 1101 : PASSED
LOC 1102 : PASSED
LOC 1112 : PASSED
LOC 2105 : PASSED
LOC 2107 : PASSED
LOC 2111 : PASSED
LOC 2112 : PASSED
LOC 2115 : PASSED
ALL CARD RESULTS PASSED
Command Completed.
When the
init-flash command has completed
successfully, the card specified in the
init-flash command is rebooted.
alw-card command.
For this example, enter this command:
alw-card:loc=2105
rlghncxa03w 06-10-01 11:11:28 GMT EAGLE5 36.0.0 Card has been allowed.
rept-stat-card command.
tekelecstp 18-01-18 21:23:11 EST EAGLE 46.5.1.5.0-73.10.0 CARD VERSION TYPE GPL PST SST AST 2105 132-003-000 DCM VXWSLAN IS-NR Active ----- ALARM STATUS = No Alarms. BLMCAP GPL = 143-010-000 + IMT BUS A = Conn IMT BUS B = Conn SLK A PST = IS-NR LS=lsnsspn2 CLLI=----------- SCCP SERVICE CARD = 1212 SLAN SERVICE CARD = ---- Command Completed.
The ’+’ symbol indicates that the flash GPL has not been activated.
If the version number of the OAMHC GPL shown in therept-stat-card command output is
different than the version specified in
9,
contact the Customer Care Center. Refer to
My Oracle Support (MOS)
for the contact information.
act-flash
command.
Caution:
Theact-flash command cannot be
entered if the Extended Bit Error Rate Test (BERT)
is being performed.
act-flash:loc=2105
FLASH Memory Activation for card 2105 Completed.
Command Completed.
GPL was updated in
25,
enter the
act-flash command with these
parameters:
sloc – the first
eloc – the last
gpl – the flash
GPL being activated
Thesloc,
eloc, and
specified with the
sloc,
eloc, and
only the cards running the flash
GPL specified by
the
sloc and
sloc and
Entering this example command will activate the flash GPLs on the cards in the locations 1101 to 2115.
act-flash:sloc=1101:eloc=2115:gpl=blmcap
FLASH Memory Activation for cards 1101 - 2115 Started.
FLASH Memory Activation for cards 1101 - 2115 Completed.
LOC 1101 : PASSED
LOC 1102 : PASSED
LOC 1112 : PASSED
LOC 2105 : PASSED
LOC 2107 : PASSED
LOC 2111 : PASSED
LOC 2112 : PASSED
LOC 2115 : PASSED
Command Completed.
rept-stat-gpl command with the
7.
If any card is not running the release version of
the flash
GPL, shown in the
RELEASE column of the
rtrv-gpl output in
8,
the indicator
ALM is displayed next to the flash
GPL version in the
RUNNING column of the
rept-stat-gpl output. For this
rept-stat-gpl:gpl=oamhc
rlghncxa03w 06-10-01 11:40:26 GMT EAGLE5 46.3.0 GPL CARD RUNNING APPROVED TRIAL OAMHC 1113 132-002-000 ALM 132-003-000 132-002-000 OAMHC 1115 132-002-000 ALM 132-003-000 132-002-000 OAMHC 1303 132-002-000 ALM 132-003-000 132-002-000 OAMHC 1307 132-002-000 ALM 132-003-000 132-002-000 OAMHC 2101 132-002-000 ALM 132-003-000 132-002-000 OAMHC 2103 132-002-000 ALM 132-003-000 132-002-000 OAMHC 2105 132-003-000 132-003-000 132-002-000 OAMHC 2113 132-002-000 ALM 132-003-000 132-002-000 OAMHC 2205 132-002-000 ALM 132-003-000 132-002-000 OAMHC 2207 132-002-000 ALM 132-003-000 132-002-000 OAMHC 2213 132-002-000 ALM 132-003-000 132-002-000 OAMHC 2301 132-002-000 ALM 132-003-000 132-002-000 OAMHC 2303 132-002-000 ALM 132-003-000 132-002-000 OAMHC 2305 132-002-000 ALM 132-003-000 132-002-000 OAMHC 2307 132-002-000 ALM 132-003-000 132-002-000 OAMHC 2311 132-002-000 ALM 132-003-000 132-002-000 OAMHC 3101 132-002-000 ALM 132-003-000 132-002-000 OAMHC 3103 132-002-000 ALM 132-003-000 132-002-000 OAMHC 3105 132-002-000 ALM 132-003-000 132-002-000 OAMHC 3107 132-002-000 ALM 132-003-000 132-002-000 Command Completed
If the flash GPL being displayed by therept-stat-gpl command is the OAMHC
GPL, the output of
the
rept-stat-gpl command will show
any E5-OAM cards that are inserted in the
EAGLE, whether they are configured in
the database or not.
act-slk command.
rlghncxa03w 06-10-01 11:55:49 GMT EAGLE5 36.0.0 Activate SLK message sent to card
rept-stat-slk command with the card
location and signaling link.
rept-stat-slk:loc=1201:link=a
rlghncxa03w 06-10-01 13:06:25 GMT EAGLE5 36.0.0 SLK LSN CLLI PST SST AST 1201,A lsnmpl1 ----------- IS-NR Avail ---- ALARM STATUS = No Alarms. UNAVAIL REASON = --
rept-stat-slk:loc=1201:link=b
rlghncxa03w 06-10-01 13:06:25 GMT EAGLE5 36.0.0 SLK LSN CLLI PST SST AST 1201,B lsnmpl2 ----------- IS-NR Avail ---- ALARM STATUS = No Alarms. UNAVAIL REASON = --
rept-stat-slk:loc=1201:link=a1
rlghncxa03w 06-10-01 13:06:25 GMT EAGLE5 36.0.0 SLK LSN CLLI PST SST AST 1201,A1 lsnmpl3 ----------- IS-NR Avail ---- ALARM STATUS = No Alarms. UNAVAIL REASON = --
rept-stat-slk:loc=1201:link=b1
rlghncxa03w 06-10-01 13:06:25 GMT EAGLE5 36.0.0 SLK LSN CLLI PST SST AST 1201,B1 lsnmpl4 ----------- IS-NR Avail ---- ALARM STATUS = No Alarms. UNAVAIL REASON = -- Command Completed.
act-dlk command.
act-dlk:loc=2105
rlghncxa03w 06-10-01 11:55:49 GMT EAGLE5 36.0.0 Activate Link message sent to card.
If the application GPL running on the card is not EOAM, continue the procedure with 38.init-card command specifying the
location of the
E5-OAM card making up
active
MASP.
init-card:loc=1115 command. This
rlghncxa03w 06-10-01 11:11:28 GMT EAGLE5 36.0.0 Init Card command issued to card 1115
After the
init-card command has completed,
repeat this procedure from
22,
specifying the card location used in the
init-card command.
If you did not wish to load the new version of the OAMHC GPL onto the other E5-OAM card running the EOAM application, continue this procedure with either 35 or 38 based on the following conditions:
NONE in
21
to the terminal type
SEAS with the
chg-trm command and the
type=seas parameter.
The terminal type is shown in the
TYPE field in the
rtrv-trm command output in
18.
chg-trm:trm=27:type=seas
chg-trm:trm=36:type=seas
rst-trm command.
rst-trm:trm=27
rst-trm:trm=36
If Telnet terminals were placed out of service in 20, for this example, enter these commands.
rst-trm:trm=17
rst-trm:trm=18
rst-trm:trm=19
rst-trm:trm=20
rst-trm:trm=21
rst-trm:trm=22
rst-trm:trm=23
rst-trm:trm=24
rlghncxa03w 06-10-01 15:08:45 GMT EAGLE5 36.0.0 Allow message sent to terminal rlghncxa03w 06-10-01 15:08:45 GMT EAGLE5 36.0.0 Command Completed.
Figure 3-4 Updating the Flash GPLs
Sheet 1 of 10
Sheet 2 of 10
Sheet 3 of 10
Sheet 4 of 10
Sheet 5 of 10
Sheet 6 of 10
Sheet 7 of 10
Sheet 8 of 10
Sheet 9 of 10
Sheet 10 of 10
