| Oracle® Communications EAGLE Database Administration - System Management User's Guide Release 46.8 F11885 Revision 1 |
![]() Previous |
![]() Next |
This procedure is used to update these GPLs: GLS, SCCPHC, and IPSHC. These names are used as the value of the gpl parameter of the chg-gpl, act-gpl, rept-stat-gpl, and rtrv-gpl commands.
These GPLs are assigned to the card types shown in Table 3-3.
Table 3-3 Service GPL Card Types
| GPL | Card Type |
| sccphc | dsm (these cards must be E5-SM4G/E5-SM8G cards) |
| iphsc | ipsm (these cards must be E5-ENET-B or SLIC cards) |
| glshc | tsm (these cards must be E5-TSM cards) |
The card types shown in Table 3-3 are the values used for the type parameter of the ent-card command.
If the GPL is being updated to a new version, a removable cartridge containing the GPL being updated is required.
If any card is not running the version of the GPL shown in the RELEASE column of the rtrv-gpl output, the indicator ALM is displayed next to the GPL version in the RUNNING column of the rept-stat-gpl output, and next to the GPL version in the APPROVED column in the rtrv-gpl output.
Refer to Maintenance and Administration Subsystem for information about the control cards.
rept-stat-db command.This is an example of the possible output.
rlghncxa03w 09-03-01 15:25:40 GMT EAGLE5 40.1.0
DATABASE STATUS: >> OK <<
E5TDM 1114 ( STDBY) E5TDM 1116 ( ACTV )
C LEVEL TIME LAST BACKUP C LEVEL TIME LAST BACKUP
FD BKUP Y 36 09-02-19 09:38:25 GMT Y 36 09-02-19 09:38:25 GMT
FD CRNT Y 39 Y 39
E5MCAP 1113 E5MCAP 1115
RD BKUP - - - - Y 36 09-02-19 09:27:17 GMT
USB BKP - - - - Y 3 09-02-07 01:11:22 GMT
If removable media is installed in the active MASP, continue the procedure with 4.
If removable media is not installed in the active MASP, insert the removable media in the removable media drive in the active MASP. For more information about inserting removable media in the removable media drive, refer to Removable USB Drive. After the removable media has been inserted in the removable media drive in the active MASP, continue the procedure with 4.
rtrv-gpl command with the gpl parameter value equal to the GPL being updated. These are examples of the possible output. rtrv-gpl:gpl=vsccp
rlghncxa03w 09-03-01 11:34:04 GMT EAGLE5 40.1.0 GPL Auditing ON GPL CARD RELEASE APPROVED TRIAL REMOVE TRIAL VSCCP 1114 132-002-000 132-002-000 132-001-000 132-003-000 VSCCP 1116 132-002-000 132-002-000 132-001-000 132-003-000 VSCCP 1115 ----------- ----------- ----------- -----------
If the version of the GPL shown in the REMOVE TRIAL column of the rtrv-gpl output is not the version that is to be loaded onto the cards, remove the removable media from the active MASP.
Insert the removable media that contains the GPL that is being updated into the removable media drive in the active MASP and repeat this step.
For more information about inserting removable media in the removable media drive, or removing removable media from the removable media drive, refer to Removable USB Drive.
If the version of the GPL shown in the REMOVE TRIAL column of the rtrv-gpl output is the version that is to be loaded onto the cards, continue the procedure with 5.
chg-gpl command and specifying the value for the trial GPL shown in the REMOVE TRIAL column in the output of the rtrv-gpl command. For this example, enter this command.
chg-gpl:gpl=vsccp:ver=132-003-000
These messages should appear.
rlghncxa03w 09-03-01 11:43:04 GMT EAGLE5 40.1.0 GPL Auditing ON VSCCP upload on 1114 completed VSCCP upload on 1116 completed System Release ID table upload 1114 completed System Release ID table upload 1116 completed
act-gpl command and specifying the value for the trial GPL shown in 5. For this example, enter this command.
act-gpl:gpl=vsccp:ver=132-003-000
rlghncxa03w 09-03-01 06:54:39 GMT EAGLE5 40.1.0 VSCCP activate on 1114 completed VSCCP activate on 1116 completed
rtrv-gpl command with the gpl parameter value specified in 5 and 6. For this example, enter this command.
rtrv-gpl:gpl=vsccp
rlghncxa03w 09-03-01 11:34:04 GMT EAGLE5 40.1.0 GPL Auditing ON GPL CARD RELEASE APPROVED TRIAL REMOVE TRIAL VSCCP 1114 132-003-000 132-003-000 132-002-000 132-003-000 VSCCP 1116 132-003-000 132-003-000 132-002-000 -----------
If E5-based control cards are installed in the EAGLE, this is an example of the possible output.
rlghncxa03w 09-03-01 11:34:04 GMT EAGLE5 40.1.0 GPL Auditing ON GPL CARD RELEASE APPROVED TRIAL REMOVE TRIAL VSCCP 1114 132-003-000 132-003-000 132-002-000 132-003-000 VSCCP 1116 132-003-000 132-003-000 132-002-000 132-003-000 VSCCP 1115 ----------- ----------- ----------- -----------
rept-stat-gpl command with the gpl parameter value specified in 7. For this example, enter this command.
rept-stat-gpl:gpl=vsccp
rlghncxa03w 09-03-01 11:40:26 GMT EAGLE5 40.1.0 GPL CARD RUNNING APPROVED TRIAL VSCCP 1101 132-002-000 ALM 132-003-000 132-002-000 VSCCP 1102 132-002-000 ALM 132-003-000 132-002-000 VSCCP 1103 132-002-000 ALM 132-003-000 132-002-000 Command Completed
If the GLSHC GPL is being loaded onto the cards, continue the procedure with 16.
If the GPL that is being loaded onto the card is not GLSHC, continue the procedure with 9.
rept-stat-gpl output in 8). The following list shows the steps that are performed for the GPL being updated.
rept-stat-sccp command.This is an example of the possible output.
rlghncxa03w 09-03-01 09:57:31 GMT EAGLE5 40.1.0 CARD VERSION PST SST AST MSU USAGE CPU USAGE ----------------------------------------------------------------------------- 1101 132-002-001 IS-NR Active ----- 47% 81% 1102 132-002-001 IS-NR Active ----- 34% 50% 1103 132-002-001 IS-NR Active ----- 21% 29% ----------------------------------------------------------------------------- SCCP Service Average MSU Capacity = 36% Average CPU Capacity = 56% Command Completed.
Continue the procedure with 16.
Therept-stat-sccp command output contains other fields that are not used by this procedure. If you wish to see all the fields displayed by the rept-stat-sccp command, see the rept-stat-sccp command description in Commands User's Guide.rept-stat-meas command. This is an example of the possible output.
rlghncxa03w 09-03-01 16:43:42 GMT EAGLE5 40.1.0
PST SST AST
MEAS SS IS-NR Active -----
ALARM STATUS = No Alarms
CARD VERSION TYPE PST SST AST
2107 P 132-002-000 EDSM IS-NR Active -----
IP Link A IS-NR Active Available
2108 132-200-000 EDSM IS-NR Active -----
2111 132-002-000 EDSM IS-NR Active -----
CARD 2107 ALARM STATUS = No Alarms
CARD 2108 ALARM STATUS = No Alarms
CARD 2111 ALARM STATUS = No Alarms
rept-stat-card command and specifying the location of the card shown in the rept-stat-gpl output in 8. For this example, enter this command.
rept-stat-card:loc=2301
rlghncxa03w 09-03-01 09:12:36 GMT EAGLE5 40.1.0 CARD VERSION TYPE GPL PST SST AST 2301 132-001-000 IPSM IPS IS-NR Active ----- ALARM STATUS = No Alarms. BPDCM GPL = 132-002-000 IMT BUS A = Conn IMT BUS B = Conn Command Completed.
rtrv-trm command. The IP terminals are shown by the terminal numbers 17 through 40. The rtrv-trm output shows the location of the IPSM associated with the IP terminals. This is an example of the possible output.
rlghncxa03w 10-07-01 16:02:08 GMT EAGLE5 42.0.0 TRM TYPE COMM FC TMOUT MXINV DURAL 1 VT320 9600-7-E-1 SW 30 5 99:59:59 2 KSR 9600-7-E-1 HW 30 5 INDEF 3 PRINTER 4800-7-E-1 HW 30 0 00:00:00 4 VT320 2400-7-E-1 BOTH 30 5 00:30:00 5 VT320 9600-7-O-1 NONE 30 5 00:00:30 6 VT320 9600-7-O-1 NONE 30 5 00:00:30 7 PRINTER 9600-7-N-2 HW 30 5 00:30:00 8 KSR 19200-7-E-2 BOTH 30 5 00:30:00 9 VT320 9600-7-O-1 NONE 30 5 00:00:30 10 VT320 9600-7-E-1 HW 30 5 00:30:00 11 VT320 4800-7-E-1 HW 30 5 00:30:00 12 PRINTER 9600-7-E-1 HW 30 4 00:30:00 13 VT320 9600-7-O-1 NONE 30 5 00:30:00 14 VT320 9600-7-E-2 SW 30 8 00:30:00 15 VT320 9600-7-N-2 HW 30 5 00:30:00 16 VT320 9600-7-E-2 BOTH 30 3 00:30:00 TRM TYPE LOC TMOUT MXINV DURAL 17 TELNET 3101 60 5 00:30:00 18 TELNET 3101 60 5 00:30:00 19 TELNET 3101 60 5 00:30:00 20 TELNET 3101 60 5 00:30:00 21 TELNET 3101 60 5 00:30:00 22 TELNET 3101 60 5 00:30:00 23 TELNET 3101 60 5 00:30:00 24 TELNET 3101 60 5 00:30:00 25 TELNET 3105 60 5 00:30:00 26 TELNET 3105 60 5 00:30:00 27 TELNET 3105 60 5 00:30:00 28 TELNET 3105 60 5 00:30:00 39 TELNET 3105 60 5 00:30:00 30 TELNET 3105 60 5 00:30:00 31 TELNET 3105 60 5 00:30:00 32 TELNET 3105 60 5 00:30:00 33 TELNET 3111 60 5 00:30:00 34 TELNET 3111 60 5 00:30:00 35 TELNET 3111 60 5 00:30:00 36 TELNET 3111 60 5 00:30:00 37 TELNET 3111 60 5 00:30:00 38 TELNET 3111 60 5 00:30:00 39 TELNET 3111 60 5 00:30:00 40 TELNET 3111 60 5 00:30:00
Thertrv-trm command output contains other fields that are not used by this procedure. If you wish to see all the fields displayed by the rtrv-trm command, see the rtrv-trm command description in Commands User's Guide.rept-stat-trm command. This is an example of the possible output.
rlghncxa03w 09-03-01 15:08:45 GMT EAGLE5 40.1.0 TRM PST SST AST 1 IS-NR Active ----- 2 IS-NR Active ----- 3 IS-NR Active ----- 4 IS-NR Active ----- 5 IS-NR Active ----- 6 IS-NR Active ----- 7 IS-NR Active ----- 8 IS-NR Active ----- 9 IS-NR Active ----- 10 IS-NR Active ----- 11 IS-NR Active ----- 12 IS-NR Active ----- 13 IS-NR Active ----- 14 IS-NR Active ----- 15 IS-NR Active ----- 16 IS-NR Active ----- 17 IS-NR Active ----- 18 IS-NR Active ----- 19 IS-NR Active ----- 20 IS-NR Active ----- 21 IS-NR Active ----- 22 IS-NR Active ----- 23 IS-NR Active ----- 24 IS-NR Active ----- 25 IS-NR Active ----- 26 IS-NR Active ----- 27 IS-NR Active ----- 28 IS-NR Active ----- 29 IS-NR Active ----- 30 IS-NR Active ----- 31 IS-NR Active ----- 32 IS-NR Active ----- 33 IS-NR Active ----- 34 IS-NR Active ----- 35 IS-NR Active ----- 36 IS-NR Active ----- 37 IS-NR Active ----- 38 IS-NR Active ----- 39 IS-NR Active ----- 40 IS-NR Active ----- Command Completed.
rmv-trm command. If the last in service SEAS terminal is assigned to the card containing the terminals that are being inhibited in this step, the force=yes parameter must be specified for that terminal.
For this example, enter these commands.
rmv-trm:trm=17
rmv-trm:trm=18
rmv-trm:trm=19
rmv-trm:trm=20
rmv-trm:trm=21
rmv-trm:trm=22
rmv-trm:trm=23
rmv-trm:trm=24
Caution:
Placing these terminals out of service will disable any sessions running on these terminals.If the status of any of the terminals shown in the PST field in 14 is OOS-MT-DSBLD (out-of-service maintenance disabled), that terminal is already out of service and the rmv-trm command does not need to be executed for that terminal.
This message should appear when each of these commands have successfully completed.
rlghncxa03w 09-03-01 15:08:45 GMT EAGLE5 40.1.0 Inhibit message sent to terminal rlghncxa03w 09-03-01 15:08:45 GMT EAGLE5 40.1.0 Command Completed.
Place the card, selected from the outputs of 8, 10, 11, or 12, out of service using the rmv-card command. If there is only one of these cards running these GPLs in service (GLSHC), the force=yes parameter must be specified with the rmv-card command.
rmv-card:loc=1101
Caution:
Do not place all the cards running the same GPL in the EAGLE out of service at the same time. Doing so will cause all traffic carried by these cards to be lost and disable the feature associated with these cards.Caution:
If there is only one in service card running the GPL being updated in the EAGLE, placing the card out of service will cause the traffic carried by this card to be lost and disable the feature associated with this card.When this command has successfully completed, this message should appear.
rlghncxa03w 09-03-01 11:11:28 GMT EAGLE5 40.1.0 Card has been inhibited.
rst-card command. The rst-card command also loads the approved version of the GPL onto the card.
rst-card:loc=1101
rlghncxa03w 09-03-01 11:11:28 GMT EAGLE5 40.1.0 Card has been allowed.
rept-stat-gpl command with the gpl parameter value equal to the gpl parameter value specified in 8. If any card is not running the release version of the GPL, shown in the RELEASE column of the rtrv-gpl output in 7, the indicator ALM is displayed next to the GPL version in the RUNNING column of the rept-stat-gpl output. For this example, enter these commands.
rlghncxa03w 09-03-01 11:40:26 GMT EAGLE5 40.1.0 GPL CARD RUNNING APPROVED TRIAL VSCCP 1101 132-003-000 132-003-000 132-002-000 VSCCP 1102 132-002-000 ALM 132-003-000 132-002-000 VSCCP 1103 132-002-000 ALM 132-003-000 132-002-000 Command Completed
If the IPSHC GPL is not being updated in this procedure, continue the procedure with 21.rst-trm command. For this example, enter these commands.
rst-trm:trm=17
rst-trm:trm=18
rst-trm:trm=19
rst-trm:trm=20
rst-trm:trm=21
rst-trm:trm=22
rst-trm:trm=23
rst-trm:trm=24
rlghncxa03w 09-03-01 15:08:45 GMT EAGLE5 40.1.0 Allow message sent to terminal rlghncxa03w 09-03-01 15:08:45 GMT EAGLE5 40.1.0 Command Completed.
Figure 3-3 Updating the Service GPLs
Sheet 1 of 7
Sheet 2 of 7
Sheet 3 of 7
Sheet 4 of 7
Sheet 5 of 7
Sheet 6 of 7
Sheet 7 of 7
