Select the Data Source
From the drop-down, select the Data Source.
In the user column, provide the database user to the corporate schema. Currently, the only user to be assigned at the FM Sender is FIDELIO.
After providing the password, add additional database users. Click +, to add the users.
Click Apply to save the settings and launch the FM Sender application.
If any settings are modified or new queue entries are added, the Interface must be restarted for these settings to take effect.Activity Status
The Activity Status shows the activity status of Fleet Management Sender.Table 13-1 Activity Status
| Activity Status | Description |
| Direction |
The transfer tables are divided in various groups for ease of transfer settings. Each direction above shows different set of tables. The Settings of tables are explained later in the Settings tab. |
| Status |
The status of the direction group which is being transferred. |
| Last Transferred Date |
The last date on which the data was transferred for that Direction Group. |
| Next Transfer At |
The next scheduled date and time on which the next transfer would take place for that Direction Group. |
Table 13-2 Columns of the Data Grid
| Columns | Description |
| Destination |
Receiving end of the transferred data. |
| Direction Group |
The direction group of data which is being transferred. |
| Ship |
Ship number. |
| Table |
Table which is being transferred from the visible direction group. |
| Transferred On |
Date along with time on which the table is transferred. |
| Batch |
Each transfer table is divided into batches for transfer. The batch number getting transferred with respect to total number of batches shows up here. |
| Records |
Number of records transferred of the batch. |
| Remarks |
Any error/warning or remark of the batch being transferred is shown. |
The other tab shows Log reader of the Sender is used for debugging by the support team.Settings
The settings tab shows direction groups, their transfer timings and MSMQ (Microsoft Message Queuing) level information. Direction groups can be added/edited and configured from here.Table 13-3 Direction Groups
| Name | Description |
| ShipToShore |
All Fleet Management tables that need to be transferred once a day. Set to transfer at 5 AM daily. |
| Setup data |
All tables that get frequently changed and /or impact business and need to be transferred more than once a day. Set to transfer every 3 hours. |
| Lob data |
All tables with Blob/picture fields are transferred separately as they take more time to transfer. They are also set to transfer once a day. Set to transfer at 6 AM daily. |
| Trans-tables |
Contain the transfer setting related tables. These tables are used by support team for investigation problems. Set to transfer at 8 AM daily. |
Config Settings
Click Config Settings to open the Config Settings screen. The General settings are thread level settings of the interface.Table 13-4 SMTP Details
| SMTP Details | Description |
| Server IP Address |
IP address of the email server. |
| Server Port |
The default is 25, please change in case it is different for your mail system. |
| Email From |
From identifier of the email sender. For example, Test FM Sender. |
| Email To |
Email address of the receiving group/person. |
| Attach Error File |
Checking the Attach Error File would attach the error file to the email and the email would be sent to the defined email addresses. |
| Schema Info |
Gives the information of the database schema sender is sending data from. |
