Introduction
References
This procedure details the steps necessary to install the Backup Management VM in the Storage Host (RMS1) and backing up the data from the Management VM in Storage host (RMS2) in to Backup Management VM in Storage host (RMS1). After the first Storage Host is reinstalled we will use below procedure to create Backup Management VM in this Storage Host. Management VM in first Storage host (RMS1) is backup for the Management VM in second Storage host (RMS2).
Expectations
Table 3-12 Procedure to Install Backup Bastion Host
| Step # | Procedure | Description |
| 1.
Create the Backup Management VM in Storage Host (RMS1) |
| 2.
Backup the Cluster directory in Backup Management VM |
The Backup Management VM is created to provide HA, i.e. if the Management VM is failed and not available, then backup Management VM is used. After Backup Management VM is created in a first Storage Host(RMS1), copy all the configs, SSH keys from the Management VM(Second Storage Host RMS2) to Backup Management VM(first Storage Host RMS1).
<cluster_name> is the directory created in /var/occne for installing the OS in all the host servers. |
