18Workflow and Method Reference for Order Management Interface
Some features of the order management interface are based on Siebel workflows. You can modify these workflows to suit your own business model using Siebel Business Process Designer. For more information, see Siebel Business Process Framework: Workflow Guide.
This chapter explains the Siebel workflows used by the order management interface, and the methods called by these workflows. This chapter does not include workflows for asset-based ordering, which are covered in Workflow Reference for Employee Asset-Based Ordering.
This chapter covers the following topics:
Order Management Interface Workflow Reference
The order management interface uses the following workflows:
Workflows for creating a quote or order:
Workflows for validating a quote, order, or agreement:
Workflows for approving a quote, order, or agreement:
Account - New Order Workflow
Account - New Order Workflow, shown in the following figure, creates a new Quote for the current Account. It then navigates to Order Entry - Detail Orders View.
It is triggered by the Accounts Screen, Account List applet menu.
Workflow Description
This workflow does the following:
Create New Order. Creates an order
Goto Order View. Calls a Sub-process called Goto_Order, which navigates to Order Entry - Detail Orders View
Account - New Quote Workflow
Account - New Quote Workflow, shown in the following. creates a new Quote for the current Account. It then navigates to Quote Item Detail View.
It is triggered from the Accounts screen, Account List applet menu.
Create New Quote. Creates a quote
Goto Order View. Calls a sub-process called Goto_Quote, which uses Interactive workflow step to navigate to Quote Item Detail View.
Contact - New Order Workflow
Contact - New Order Workflow, shown in the following figure, creates a new Order for the current Contact. It then navigates to the Order Entry screen, Detail Orders View.
It is triggered from the Contacts screen, Contact List applet menu.
Create New Order. Creates an order for a contact.
Contact - New Quote Workflow
Account - New Quote Workflow, shown in the following figure, creates a new Quote for the current Account. It then navigates to the Quote Item Detail View.
It is triggered from the Contacts Screen, Contact List applet menu.
Goto Quote View. Calls a sub-process called Goto_Quote, which uses interactive workflow step to navigate to Quote Item Detail View.
Goto_Quote Workflow
Goto_Quote workflow, shown in the following figure, navigates to Quote Item Detail View
It is triggered by the Account - New Quote and Contact - New Quote workflows.
This sub-process uses an interactive workflow step to navigate to Quote Item Detail View.
Goto_Order Workflow
Goto_Order workflow, shown in the following figure, navigates to Order Entry - Detail Orders View.
It is triggered by the Account - New Order and Contact - New Order workflows.
This sub-process uses an interactive workflow step to navigate to Order Entry - Detail Orders View.
Verify Header (Quote) Workflow
Verify Header (Quote) workflow, shown in the following figure, is used to verify a quote, verify a promotion, and verify line items of a quote. It displays promotion violations, data validation rule violations, and complex product violations.
It is triggered when the user clicks the Verify button in a quote header or selects Verify from the menu of the quote line item applet.
Verify Promotion. Calls the ISS Promotion Verify SubProcess workflow to verify promotion status.
Data Validation. Calls the ISS Validation (Quote) workflow to verify Data Validation Rules.
Validate CP All. Calls the VORD Validate Complex Product All (Quote) workflow to validate all complex products under the Quote.
Display Messages. Displays all messages generated by the earlier steps.
ISS Validation (Agreement) Workflow
ISS Validation (Agreement) workflow, shown in the following figure, validates the Agreement according to the Rule Set definition for the agreement in Administration - Data Validation.
It is triggered by the VerifyItem signal, which is called by the Agreement screen, Verify applet menu.
This workflow calls the Validate method of the Data Validation Manager Business Service. This workflow validates the Agreement according to the Rule Sets that are defined in Administration - Data Validation view. For more information, see Validate Method.
| Name | Business Object | Data Type | Comments |
Error Code |
Service Agreement |
String |
The Error Code that is returned if an error occurs. |
Error Message |
Service Agreement |
String |
The Error Message that is returned if an error occurs. |
Object Id |
Service Agreement |
String |
The Row ID of the current object. |
Process Instance Id |
Service Agreement |
String |
The Row ID of the current workflow process. |
Return Code |
Service Agreement |
String |
The Return Code that is defined in the Rule Set. |
Return Message |
Service Agreement |
String |
The Return Message that is defined in the Rule Set. |
Siebel Operation Object Id |
Service Agreement |
String |
The Row ID of the Siebel Operation Object. |
Store Messages |
Service Agreement |
String |
Variable to determine if the validation messages must be stored in the validation tables. |
Validation Ruleset Name |
Service Agreement |
String |
The name of the Rule Set that is defined in the Data Validation Administration screen. |
ISS Validation (Order) Workflow
ISS Validation (Order) workflow, shown in the following figure, validates the Order according to the Rule Set definition in Administration - Data Validation view for orders.
It is triggered by the VerifyItem signal, which is called by the Verify applet menu item of the Order Header menu.
This workflow calls the Validate method of the Data Validation Manager Business Service. This workflow validates the Order according to the Rule Sets that are defined in Administration - Data Validation. For more information, see Validate Method.
Process Properties
Error Code |
Order Entry |
String |
Error Message |
Order Entry |
String |
Object Id |
Order Entry |
String |
Order Entry |
String |
Return Code |
Order Entry |
String |
Return Message |
Order Entry |
String |
Order Entry |
String |
Store Messages |
Order Entry |
String |
Order Entry |
String |
ISS Validation (Quote) Workflow
ISS Validation (Quote) workflow, shown in the following figure, validates the Quote according to the Rule Set definition for quotes in Administration - Data Validation.
It is triggered from VerifyItem signal which is called by the Verify Applet Menu item on the Quote Header.
This workflow calls the Validate method of the Data Validation Manager Business Service. This workflow validates the Quote according to the Rule Sets that are defined in Administration - Data Validation. For more information, see Validate Method.
Process Properties
Error Code |
Quote |
String |
Error Message |
Quote |
String |
Object Id |
Quote |
String |
Quote |
String |
Return Code |
Quote |
String |
Return Message |
Quote |
String |
Quote |
String |
Store Messages |
Quote |
String |
Quote |
String |
ISS Approval (Quote) Workflow
ISS Approval (Quote) workflow, shown in the following figure, validates approval rules and creates approval items if necessary.
It is triggered when the user selects the Generate Approvals menu item on the Quote Header applet menu. This menu item raises the ApproveItem Signal, which calls this workflow.
Validation Service. Calls the Validate method of the Data Validation Manager Business Service, which validates the Quote according to the Rule Sets that are defined. For more information, see Validate Method.
Exception Found. If the validation service returns a null, then the workflow ends.
Approval Business Service. If it returns a non-null value, then the workflow calls CreateNewApprovalTasks method, which creates a new approval task for the quote. For more information, see CreateNewApprovalTasks Method.
Refresh Applet. Calls the Refresh Business Component method of the SIS OM PMT Service Business Service, which refreshes the Quote, so the approval items appear in the approvals view.
ISS Approval (Order) Workflow
ISS Approval (Order) workflow, shown in the following figure, validates approval rules and creates approval items if necessary.
It is triggered when the user selects the Generate Approvals menu item on the Order Header applet menu. This menu item raises the ApproveItem Signal, which calls this workflow.
Validate. Calls the Validate method of the Data Validation Manager Business Service, which validates the Order according to the Rule Sets that are defined. For more information, see Validate Method.
Approval Bus Service. If it returns a non-null value, then the workflow calls the CreateNewApprovalTasks method of the ISS Approval Bus Service, which creates a new approval task for the Order. For more information, see CreateNewApprovalTasks Method.
Refresh Applet. Calls the Refresh Business Component method of the SIS OM PMT Service Business Service, which refreshes the Order, so the approval items appear in the approvals view.
ISS Approval (Agreement) Workflow
ISS Approval (Agreement) workflow, shown in the following figure, validates approval rules and create approval items if necessary.
It is triggered when the user selects the Generate Approvals menu item on the Agreement Header applet menu. This menu item raises the ApproveItem Signal, which calls this workflow.
Validation Service. Calls the Validate method of the Data Validation Manager Business Service. For more information, see Validate Method.
Approval Bus Service. If it returns a non-null value, then the workflow calls the CreateNewApprovalTasks method of the ISS Approval Bus Service. For more information, see CreateNewApprovalTasks Method.
Refresh Applet. Calls the Refresh Business Component method of the SIS OM PMT Service Business Service, which refreshes the Agreement, so the approval items appear in the Approvals view.
ISS Post Approval Workflow (Quote) Workflow
ISS Post Approval Workflow (Quote) workflow, shown in the following figure, checks whether any additional approvals are needed.
It is triggered when a user approves an Quote to see if additional approvals are needed.
Calls the SetApprovalDecision method. This will set the status of the current approval item and check to see if additional approval is needed.
Process Properties
ActionLIC |
Quote |
String |
The Language Independent Code for the Action Field |
Approval Level Name |
Quote |
String |
The name of the Approval Level that is defined in the Approval Administration screen. |
Error Code |
Quote |
String |
Error Message |
Quote |
String |
InboxItemId |
Quote |
String |
The Row ID of the current Universal Inbox Item. |
InboxTypeName |
Quote |
String |
The Universal Inbox Type. |
Object Id |
Quote |
String |
Obsolete. |
ObjectId |
Quote |
String |
OwnerInfoId |
Quote |
String |
The Row ID of the approver. |
Quote |
String |
Returned Status |
Quote |
String |
The Status of the Approval Item. |
SendEmail |
Quote |
String |
Variable to determine if email is sent to the person who needs to approve the current item. |
SeqNum |
Quote |
String |
The Sequence Number for the current approval level. |
Quote |
String |
StageId |
Quote |
String |
The Row ID of the current Approval Stage. |
ISS Post Approval Workflow (Order) Workflow
ISS Post Approval Workflow (Order) workflow, shown in the following figure, checks whether any additional approvals are needed.
It is triggered when a user approves an Order to see if additional approvals are needed.
Calls the SetApprovalDecision method of the ISS Approval Bus Service Business Service. This will set the status of the current approval item and check to see if additional approval is needed.
Process Properties
ActionLIC |
Order Entry |
String |
Order Entry |
String |
Error Code |
Order Entry |
String |
Error Message |
Order Entry |
String |
InboxItemId |
Order Entry |
String |
InboxTypeName |
Order Entry |
String |
Object Id |
Order Entry |
String |
Obsolete. |
ObjectId |
Order Entry |
String |
OwnerInfoId |
Order Entry |
String |
Order Entry |
String |
Returned Status |
Order Entry |
String |
SendEmail |
Order Entry |
String |
SeqNum |
Order Entry |
String |
Order Entry |
String |
StageId |
Order Entry |
String |
ISS Post Approval Workflow (Agreement) Workflow
ISS Post Approval Workflow (Agreement) workflow, shown in the following figure, checks whether any additional approvals are needed.
It is triggered when a user approves an Agreement to see if additional approvals are needed.
Process Properties
ActionLIC |
Service Agreement |
String |
Service Agreement |
String |
Error Code |
Service Agreement |
String |
Error Message |
Service Agreement |
String |
InboxItemId |
Service Agreement |
String |
InboxTypeName |
Service Agreement |
String |
Object Id |
Service Agreement |
String |
Obsolete. |
ObjectId |
Service Agreement |
String |
OwnerInfoId |
Service Agreement |
String |
Service Agreement |
String |
Returned Status |
Service Agreement |
String |
SendEmail |
Service Agreement |
String |
SeqNum |
Service Agreement |
String |
Service Agreement |
String |
StageId |
Service Agreement |
String |
Order Management Interface Methods Reference
The following methods are called by the order management interface workflows:
Validate Method
This method validates a quote, order, or agreement according to the Rule Sets that are defined in Administration - Data Validation.
Arguments
| Input Argument | Type | Property Name | Comments |
Rule Set Name |
Process Property |
None |
Store Messages |
Process Property |
Store Messages |
This flag determines whether the validation messages are stored in the table. |
| Output Argument | Type | Property Name | Comments |
Return Code |
Output Argument |
Return Code |
Returns the error code. Depending on the code, the workflow determines whether approval is needed. |
Return Message |
Output Argument |
Return Message |
Returns the error message from the validation engine |
SetApprovalDecision Method
This method sets the status of the current approval item and checks to see if additional approval is needed. This method is part of the ISS Approval Bus Service Business Service.
Arguments
ActionLIC |
Process Property |
ActionLIC |
Approval status. Values are Approved, Rejected. |
InboxItemId |
Process Property |
InboxItemId |
ID of the current Inbox Item to be approved or rejected. |
InboxTypeName |
Process Property |
InboxTypeName |
Inbox Type defined in the Administration inbox screen; for example, Quote, Sales Order, Agreement, and so on. |
ObjectId |
Process Property |
ObjectId |
Row ID of the item to be approved; for example, the Quote ID, Order ID, and so on. |
OwnerInfoId |
Process Property |
OwnerInfoId |
Login ID of the person who is approving or rejecting the Inbox Item. |
SendEmail |
Process Property |
SendEmail |
Determines whether to send an email to the approver. Values are TRUE, FALSE. |
SeqNum |
Process Property |
SeqNum |
Sequence Number of the current Approval Stage. |
StageId |
Process Property |
StageId |
This method creates a new approval task for a quote, order, or agreement. This method is part of ISS Approval Business Service.
Arguments
Approval Level Context |
Process Property |
Added to accommodate Self-Service applications. Contains the Account ID. |
Approval Item ID |
Process Property |
Object Id |
Row ID of the item that needs to be approved; for example, Quote ID, Order ID, and so on. |
Process Property |
Name of the Approval Item that is defined in the Administration - Application screen, Approval Admin view. |
Inbox Type |
Process Property |
Inbox Type |
Inbox Type that is defined in the Administration Inbox screen; for example, Quote, Sales Order, Agreement, and so on. |
Line Item # |
Process Property |
Line Item # |
Not currently used. |
Line Item Name |
Process Property |
Line Item Name |
Requesting Buscomp |
Process Property |
Business component that triggers the approval procedure. Used for dynamic drilldown (Quote, Order Entry - Orders, Service Agreement, and so on). |
Return Message |
Process Property |
Return Message |
Return Message defined in the Rule Set in the Administration - Data Validation screen, Rule Set view. |
SendEmail |
Process Property |
SendEmail |
GetApprovalStatus Method
This method returns the approval status for the inbox item. The status is one of the following: Approved, Declined, or In Progress. You must pass in the Approval Level Name, Approval Item ID, Inbox Type, and Object Id. This method is part of ISS Approval Business Service.
Input Arguments
The following table describes the GetApprovalStatus method input arguments.
Approval Item ID |
Process Property |
Approval Identifier |
Process Property |
Approval Item Name |
Inbox Type Name |
Process Property |
Inbox Type Name |
Output Arguments
The following table describes the GetApprovalStatus method output arguments.
Approval Item Status |
Process Property |
Approval Status |
RefreshBusinessComponent Method
This method refreshes the display of a quote, order, or agreement. This method is part of the SIS OM PMT Service Business Service.
Arguments
| Input Argument | Type | Value |
Business Component Name |
Literal |
The name of the business component (such as Approval History - Quote, Approval History - Order, or Approval History - Agreement) |
Business Object Name |
Literal |
The name of the business component (such as Quote, Order Entry (Sales), or Service Agreement). |
