| Oracle® Communications EAGLE Application Processor Alarms and Maintenance Guide Release 16.3 E96331 |
![]() Previous |
![]() Next |
Oracle now provides 480G drive modules that allow for a larger data capacity. When upgrading from 300G to 480G drive modules, both drive modules should be replaced one after the other. The 480G drive modules will support the existing data capacity and no down time is required. To take advantage of the increased storage capacity of the 480G drive modules, EPAP must be re-installed. For information about increasing the existing data capacity after upgrading to 480G drive modules, see Increasing Data Capacity with 480G Drive Modules.
Procedure - Remove and Replace a Drive Module Assembly
