| Oracle® Communications EAGLE Application Processor Alarms and Maintenance Guide Release 16.3 E96331 |
![]() Previous |
![]() Next |
Alarm Type: TPD
Caution:
When changing the server’s network routing configuration it is important to verify that the modifications will not impact the method of connectivity for the current login session. It is also crucial that this information not be entered incorrectly or set to improper values. Incorrectly modifying the server’s routing configuration may result in total loss of remote network access.Severity: Minor
OID: 1.3.6.1.4.1.323.5.3.18.3.1.3.7
Alarm ID: TKSPLATMI75000000000000040
Recovery
syscheck again. If the alarm has not been cleared, go to 6savelogs to gather all application logs, (see Saving Logs Using the EPAP GUI).
