Access Company Details (Edit Company Window)
Company detail information is managed in the Edit Company window (also known as the Company Properties window).
To access the window:
- Go to the Company Workspace tab and switch to Admin mode.
- In the toolbar, click File and select Open.
The Edit Company window has the following tabs:
- General: Use this tab to manage several company features, which are described in the next topic. The fields with red asterisks are required.
- Address: Use this tab to enter up to seven company addresses. There must be at least one address entered for the company headquarters.
- Security: Use this tab to set up a file security policy and a password/login policy that your users must follow after they sign into the system.
- Contact: Use this tab to maintain support contact and e-Learning access information for your users. The information entered here appears in the Support window (Contact tab). To access the Support window, click Help in the upper-right corner of the Unifier Essentials window, and select Contact Support from the menu.
- E-Signatures: Use this tab to manage the default e-signature type, DocuSign setup or Adobe Acrobat Sign (Adobe Sign) setup, to use these digital E-signature solutions within Unifier Essentials documents.
- Outgoing E-mails: Use this tab to specify the size (in megabyte [MB]) of attachments allowed in each outgoing email.
- Lobby Administrators: Use this tab to manage the list of company-sponsored users who function as administrators for the Lobby. These users are also known as Organization Administrators and Lobby Administrators.
In This Section
Edit Company (E-Signatures Tab)
Edit Company (Outgoing E-mails Tab)
Edit Company (Lobby Administrators Tab)
Last Published Tuesday, June 4, 2024
